Question about Sewing Machines
Tension problems I have cleaned and oiled my machine and cannot seem to figure out why machine tension is still messed up. I have worked with the bobbin case (tightening and loosening it) and it still does not want to sew correctly. thanks JJ
  • MarthaJane Jun 11, 2008
    I am having trouble with my bobbin case being loose after the thread got couaght under it and must have loosened it. I am unable to adjust the tension any longer. Help!
  • cookie52601 Jul 02, 2008
    Bobbin keeps coming out case,
  • Sewing Machines Master
  • 1,388 Answers
To read about the reasons and solutions to this looping on the underside...........start here
Posted on Feb 17, 2008
Brand new machine, do I need to oil it? singer talent 3321 is suppose to be EASY...needle broke, now it will not sew, seems to be stuck and bobbin seems to not work.
1. You need to remove the bobbin case and adjust the tension. The tension should allow the thread to move with a slight tension. Clean the area with a qtip. The bobbin case sits in a an area that is called the race. The race needs one drop of oil. Replace everything.
2. Replace the needle. Make sure it is in the right direction. Thread the top while the foot is up. If the thread gets stuck while threading there is a problem. The thread should move easily while the foot is up. After you thread the machine except the needle you can put the foot down. Now pull on the thread. It should give you a slight amount of tension. Usually four is a good number. If the tension is too tight you can adjust as needed. Now, thread the needle. Hold the thread under the foot while you turn the hand wheel. The bobbin thread should come up.
3. Give your machine a try with a slow speed.
Mar 25, 2017 | Singer Sewing Machines
Bobbin thread bunching up on bottom side od material while sewinginto a mess, while top thread fine. HOW DO I fix this, please.
Hi, this is a lack of lower tension. Check to make sure your bobbin is seated correctly and that you have used the correct thread path. Check the tension by drawing some thread from the bobbin with your hand, if it reels off too easily, the tension hook for the bobbin is too loose, tighten it down a tiny bit with a small screw driver and try again. If the bobbin tension is normal, than the problem may be your upper tension, if it is too tight it can cause your bobbin to snarl. If a tension adjustment does not fix the problem, you may need to seek a specialist.
Oct 06, 2015 | Singer Sewing Machines
New Home ss2015 machine. I am having trouble with the thread tension. I have loops on the bottom. I have cleaned the bobbin case, changed the needle, re-threaded and moved the upper tension all the way up....
try adjusting the top tension to 3 & if it doesn't stop the looping, try 4 but I wouldn't go any higher than 5,, if changing the top tension doesn't help then I suggest taking the machine in to have it serviced. the bottom tension is more difficult to do,, it's also very possible that the top tension dial is messed up & needs replacing. only a sewing machine shop can tell for sure.
Mar 02, 2012 | Sewing Machines
Stitch too tight on top, too loose on bottom
This is a problem with thread tension. The needle thread is too tight and the bobbin thread is too loose. I don't have one of these machines, but there should be either screws or knobs to adjust. Look at your manual. Here's a page I found on bobbin tension.
Aug 06, 2017 | Toyota Sewing Machines
Hi, the tension on my sewing machine doesn't seem to be working. I have it all the way to 9 and the bottom stitch is still a little loose. Any advice?
Tensions on sewing machines really shouldn't be messed with at all, your problem is you don't have the machine threaded correctly nor the thread seated in between the tension disc. Turn your tention tunb back to between 3 and 4 and this should correct the problem
Aug 13, 2010 | Brother Sewing Machines
Husqvarna bottom thread showing through the top
On the far left of the machine is the tension wheel for the bobbin. Sounds like it is way too loose. Should automatically set if you have entered the right type of fabric.
May 08, 2009 | Husqvarna Viking 1
Sewing with drapery material
Switch back to regular thread. Upholstery thread is used for seams that will get lots of stress (as in upholstery; although I use regular thread in upholstery and have no problems). For draperies, regular thread is fine.
Jul 24, 2007 | Husqvarna Viking 1
Sewing Machines Logo
145 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
