Question about Technics SL-MC6 CD Player
Disconnected wire I have a Technics 110+1 SL-MC-6 cd changer. I was moving the unit and all the c'ds fell back into the unit. I took off the top cover and was able to remove the cd's but a thin wire, (almost looks like picture wire) has come loose it runs behind where the cd's sit in the rack. It is still connected on both sides except now it is slack. It must connect elsewhere I just can not figure out where. Any ideas?
  • Anonymous Apr 13, 2008
    can you tell me where the other wire is connected on the lhs facing machine
    same problem
    Problem Solver:
  • 5 Answers
Ha, you are stuffed.
Actually this wire runs down the side and across the bottom of the CD player cage and back up the other side.
On the way it runs round the front cover release sensor and leaver.
You would probably need to look inside another one to get it right.
Buy a used one one off ebay and copy the path of the wire.
Then you have two working ones.
Posted on Jan 05, 2010
Where can I have the unit repaired. It is stuck in search mode.
might be just a broken drive belt - pretty common on these units. Take the cover off and look at the top of the cd mechanism for the belt.
Feb 08, 2016 | Technics SL-MC7 110-Disc CD Changer
Power it on and just get an off reading
Technics SL-MC4 61-Disc CD Changer Not reading ... - Fixya
www.fixya.com > ... > Technics > Technics SL-MC4 61-Disc CD Changer
Technics SL-MC4 61-Disc CD Changer, not reading cd related issues. Get free ... IHave A Tascam CC-222Mkll Will Not Read CD-R Or CD-RW But Will Read Store Bought CD's. I Have A ... I have just spent $69 for the software to convert it the way I wanted into mp3 format, being a format that I figured . ... Power the unit off.
Technics SL-MC4 61-Disc CD Changer Message center ...
Dec 29, 2015 | Technics SL-MC4 61-Disc CD Changer
Changer states checking disk, error
Possible broken drive belt, that's what caused the same error on my unit. Very easy to replace, just take off the top cover and the motor and belt are readily accessible.
Feb 03, 2014 | Technics SL-MC700 110-Disc CD Changer
When i turn my technics cd player all i see is error
Technics CD Changer SL-MC400
The ERROR Is Cause By The Belt Drive
Remove The Cover And You Can See if
The Belt is Lose or slip of In Any Case
You Must Change That RUBBER DRIVE BELT.
Dec 31, 2013 | Technics SL-MC400 110-Disc CD Changer
There is a thin wire cable with a spring inside unit witch is the cable is broken where do i get a new one
FOrn get it, PEople are trowing them out, Where i live , Ones that work no one want them any more,
Nov 26, 2012 | Technics SL-MC7 110-Disc CD Changer
Technics SL-MC-7 Multi Disk CD Player- When I put a CD in it says
What does it stay? I am (Hooch) Please get a different CD (PLayer) I have (Retired)
Nov 09, 2012 | Technics SL-MC7 110-Disc CD Changer
Tech SL-MC410. Continously displays "Checking Disc"
When the unit is saying "Checking discs" and neither goes further nor turns off (just says "Off" but doesn't), the reason is still the main belt (accessible from the top as soon as you lift the cover) that is too loose. When the belt is way too loose, the unit doesn't move at all, if the belt is little too loose, the player-unit will move a bit, but there is not enough torque on the gears to reach the end position (where the player unit is secured against movements).
May 07, 2012 | Technics SL-MC400 110-Disc CD Changer
Door will not open,get checking disc message
I solvwed the problem by removing the cover and found 2 discs jammed into the same slot. removed them and put them in the proiper slos, put back cover, gently tightening the screws incase it happens again.
technics 110 cd changer. model sl-mc310.
Dec 20, 2009 | Technics Audio Players & Recorders
Looking for a drive belt for a SL MC300 Technics 110 CD changer
A rubber "O" Ring as a belt solved the problem.  At our local hardware store:  1 1/16 OD x 15/16 ID - 1/16" wall  $0.39!
Jan 29, 2009 | Technics SL-MC7 110-Disc CD Changer
Technics SL-MC6 CD Player Logo
155 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
