I would like to shorten the citizen ladies watch wrist band by removing a couple of links but cannot get the pins to release. Do they unscrew? Any ideas would be much appreciated. Thanks
Look at the inside of the band and there will arrows pointing what direction the to tap the pins out to remove links. Put the watch on a small roll of tape or something similar that keeps the band off the surface you are working on. Gently tap the pin out with a tool that will fit in the pin hole. Remove the pin and determine the number of links to remove. Remove the links and reverse the order in which you took it apart .
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
I've had to get extra links before, especially for ladies SS and gold bands. Sometimes a local dealer will have spares that will fit your watch. But, the best source I've found is Ebay. Let me know if you have the stock band or something else. I'll try to help you locate some extra links, or another replacement band at a modest cost. Thanks, Bill
If it has a clip-style wrist attatchment, you may slightly adjust the pins a couple of inches with a small pin to remove thte sppring and re-insert in another hole. I recommend tweezers and a clean work surface. The spring MAY fly, so ask someone to hold their hands over the area you are working on. If you need more adjustment, go to a jeweler to have links removed /added.
This may seem simple to do but it is literally a ***** of a task. Best to where amplifying glasses and use a ball point pen, not a pin or pencil. Push one side of the pin in while keeping a slight outward pressure on the band. When it releases be care full not to let it fly off into the void(which they can) and then move to where you need the band to be and reinstall using a single edge razor blade. Just carefully align the opposite side (assuming youve alredy put one end in)place the razor blade on center and slide the remaining pin into the hole area pull the blade out slowly and listen for it to click into place.
If it is a metal link band, you can remove a few segments. Segments are connected by split pens. You should see a thinner end and a bigger end; or an arrow on the inside shows where the thinner end should be.
Push the thinner end firmly with a pin or something until the big end pops out the opposite side.Use pliers to remove the pin.
There must be something wrong as ALL watch bands are held together by pins or screws. Did you try to unscrew them? These might be screws instead of pins. And if these are pins, they MUST come out because there is NO other way to shorten the band. I would advise you to find the watchmaker, not the jeweller, and he/she will be able to sort things out. P.S. Not all the bands has pointing arrows on them, so, no worries about that.
Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out. To shorten the band you have to: Extract the pins. Take link(s) off. Join the rest of band together and drive pins back.
All Rolex watch bracelets has screws, not pins. Get small screwdriver and unscrew them.
If there is no screws at all, that means bracelet links had been removed and you have shortest version allready ,or, this is not the real (genuine) Rolex bracelet.
Find your nearest watchmaker to clarify all this.
