Question about Car Audio & Video
Sub is unresponsive
I have a fli 12 subwoofer and amplifier package. i think the amp has 200w rms and the subwoofer has 1000w max output. it was all working fine for about a week. however whilst driving the subwoofer was making popping noises occaisionaly, usually when i turned lights on or main beam on. next time i turned the car on however the subwoofer failed to turn on. the LED is not even working. i have checked all fuses and wiring. i dont understand what can have happened?
thanks bill
Unhook the orange wire and also try the remote wire, rerun that too the amp
Posted on Feb 19, 2008
Can i hook this amp to a 2 channle out put stereo?
Sure. Specs are listed below. I think it's designed for regular 2-channel input, isn't it?
Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
  • Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
  • Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
  • THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
  • S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
  • Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
  • Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
  • Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
  • Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
  • Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
  • Differential-Balanced Input Topology: (3 pairs of inputs)
  • Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
  • Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
  • Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
  • Preamp Output: 2-channel (full-range or LP)
  • Bass EQ: Variable boost up to 15db
  • Infrasonic Filter: defeatable 24dB/octave at 30 Hz
  • Left minus Right Ambience Circuit: ambient effect for rear channels
  • Front and rear speaker output connections: accept up to 8ga. wire
  • Dual mono subwoofer output connections: accept up to 8ga. wire
  • +12V and Ground connections: accept up to 4ga. Wire
  • Dimensions: 19.7"L x 9.25"W x 2.36"H
  • Dec 02, 2010 | Jl Audio 500/5 Car Audio Amplifier
    We installed the amp and bass package and the subs are not nowhere near *** powerful we think its the amp and when the remote bass switch when we turn it it doesnt change
    what product brand did you install. do you set the amps x-over and gains a sub sonic filter right
    need to see if the amp is on check led light on amp. make sure your subs ohm load is correct for the amp.
    let us an example fake amp 500x2channel max output 1000watts
    if you wire your subs at 4 ohms you 250x2 rms stereo
    if you wire your subs at 2 ohms you 500x2 rms stereo
    if you wire your subs at 4 ohm mono you get 1000 watts
    if you have the input voltage of 14.4 all the time at the amp
    whats the equipment power
    Oct 14, 2010 | Car Audio & Video
    What size amp do i need to run 4 1000 watt pyle 10's bridged
    well first of all you cant bridge subs... you can bridge an amp... and for 2 they are probablly not 1000 watts, make sure you understand RMS and what the sub can ACTUALLY HANDLE properly... i would get a 1000 to 1500 watt RMS that is RMS RMS RMS RMS amp not one that says 2000 watts MAX POWER cuz thats cheap ****... get a kicker JL hifonic alpine or something in that category that actually tells you the TRUE power output of the amp... then run those 4 subs in a parallel circuit so its like really only having 2 subs. make sure then these subs do not run less then 2 ohms at the terminals while in a parallel, then bridge these subs acting as 2 subs not 4 to your TRUE 1000 watt amp and you should have a good powerful system
    Mar 19, 2010 | Pyle 10'' Subwoofer Tube w/Amplifier Car...
    What speaker componets do need to buy?
    • 1000W max power
    • 165W x 2, 20Hz - 20kHz, @ 0.04% THD + N, at 4 Ohms
    • 200W x 2, 20 - 20kHz, @ 0.15% THD + N, at 2 Ohms
    • 400W x 1, 20Hz - 20kHz, @ 0.1% THD + N, at 4 Ohms
    • OTL (Output Transformerless) circuit
    • Pulse power supply
    • Line & High Level Inputs
    • .3-6V Level Adjustment Control (RCA Pin Jacks) 1.2-12V (High Level Input)
    • 80 Hz, -18dB/octave Low Pass Filter Switch
    And i would say that the best use of this amplifier would be for sub-woofers.
    Feb 19, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
    Will a sony xm-1652z 1000w amp run 2 dvc 4 ohm 800 watt rms subs?and whats yhe best wiring option if so?thx
    IT WILL POWER THE SUBS WITH NO PROBLEM. I WILL NEED TO KNOW WHAT THAT MAX WATT THE SPEAKERS CAN HANDLE BEFORE GIVING PROPER ADVISE. RMS IS RECOMMENDED MINIMUM SETTINGS.
    Feb 21, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
    Support Question about RMS
    you are going to need an amp that can supply the right amount of rms power to make it sound good. these sony subs are rated for 380 watts rms. so in order to find an amp that will supply two, you must multiply that figure by two. so you will need an amp that can supply around 500 to 750 watts continuously (or rms). also you are going to want an amp that is either class d or class ab rated. these amps are built to push subwoofers exclusively and will give you the best efficiency and sound out of your subs. you will also want to get an amplifier is a monoblock amp, and not a stereo amplifier. make sure the amp can put out that rms rating at 2 ohms as two 4 ohm speakers equal 2 ohms wired in parallel. i have a kenwood kac9152d that puts out about 2000 watts max at 2 or 1 ohms (900 watts rms) that i used with my two sony xplod 10's for about 2 years. it was kick ***! now i dont know if you need that much power but they will handle it as long as you dont push them too hard for long periods of time, otherwise you might end up blowing them up! (depending on the box size that is, and the quality of it as well...)
    i have years of car audio installation experience and can help with setting up and wiring any mobile entertainment system you can imagine. may i ask what kind of music you listen to and what kind of box do you have for these subwoofers?
    if you have any questions email me at thadoggma420@hotmail.com
    Jan 22, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
    Sony amp model 1652z
    1000W max power
    <b>
    </b>
    Pulse power supply
    Jan 15, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
    Knocking noise with my kicker compvr 15"
    comp VR 15s are rated @ 500W RMS 1000Peak.
    The lanzar vibe amplifier is 2 x 600W RMS at 4 OHMS 2 x 1200W MAX at 4 OHMS 1 x 2400W MAX at 4 OHMS Bridged 2 x 1000W at 2 OHMS RMS.
    Your subs are single 4 ohm subs.
    If your subs are wired stereo, they both are seeing 600W. (more than the rated RMS)
    Chances are, you have them wired parallel to a 2 ohm mono load - of which that amplifier is not rated. In theory, it will produce about 2000W @ 2 ohm mono for a short period of time.
    Your amplifier is too powerful for your subs. Turn down the gain setting to 3/4 or purchase better subs. Also be sur the subs are inthe proper enclosure. It sounds as if they are excurting past their linear x-max and colliding with the rear bump plate. This will cause damage down the road if left as is.
    Nov 26, 2008 | Kicker CompVR 05CVR84 Car Subwoofer
    Amp getting really hot
    well it is getting hot due to the amp drawing and pushing alot of current. try getting lower gage wiring for power to the amp and lower gage speaker wire.
    Apr 20, 2008 | Power Acoustik PS2-1200 Car Audio...
    Sub power hadling capacity
    Yes. If the rated power is 380W and the Max power is 1000W then it will handle it. Subs fry when clipping occurs. Clipping is when the amplifier is pushed past its capabilities and the output to the sub gets "dirty". The better quality the amp, the safer it will be on your speakers. It is also important to remember that the gain control on the amplifier is NOT a volume control to boot the sound, it is only to match the output from the headunit to the input handling of the amp. Cranking the gain up too much WILL CAUSE CLIPPING.
    Jan 04, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
    Car Audio & Video Logo
    312 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Marvin
    Marvin
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
