Question about NEC ND-6500A DVD±RW Dual Layer Burner
Burning problem Each time I record music on to disc the first three tracks are fine, then the next three or four crackle and skip. After this the tracks are fine again. I thought it was faulty, cheap discs but I have purchased several brands and the problem remains. I use Nero, Windows Media Playerburn and Winamp burn, all with the same result. In the past I have also used Roxio, again the same result. I don't seem to have this problem burning dvd at all. Is the problem the software or the hardware?
  • telguitar Feb 17, 2008
    Thanks. I tried at slower speed (8x) but no difference. The same problem occurs when playing in car cd player and in home cd player. However, I have £10 cd/radio that plays all tracks okay and they play fine on the notebook NEC
    Most 'stuff' is from utorrent, but I copied a disc I bought and got the same result; tracks 4-6 were crackling and skipping.
Might be bad songs u dl junk from limewire must be least 192 bit rate
Posted on Feb 17, 2008
    Scholar:
  • 110 Answers
Try burning at a slower speed, like 16x or less. If your burner is a CAV-type, it will burn faster as it moves toward the outside of the disk and can be more prone to errors that way.
Also, have you tried playing the burned disk in another player, and did it show the same symptoms?
  • Robert Swanson
    Robert Swanson Feb 17, 2008
    What brand of media have you tried?
  • Robert Swanson
    That's actually incorrect. MP3 encode rates don't matter so much for issues like this. If it sounds good on your pc, and it sounds good in other players, it isn't a bitrate issue. In fact, CD-Audio is only 128kbps, cbr. I'd still suspect an issue with the media being used. You can try slowing the burn down even farther to 4x. If it doesn't get better then, try a more expensive media (Verbatim has worked well in my experience).
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
Sony cdp cx 355 skips on first track
Could be some dust or debris in the unit. Also be careful that you are not putting fingermarks near the hole section of each CD you put in, as the CD plays from the centre out.
Jul 02, 2017 | Sony MegaStorage CDP-CX355 300-Disc CD...
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
I want to know how to track c.d. when recording,I don't have a remote??
If you mean you don't know how to manually mark a track in Manual Mode >>while<< recording on the fly:
Toggle the Auto/Manual button to Manual
Press the SKIP/Search right arrow button for tray B while recording whenever you want to increment the track number.
Pausing or stopping the recording also increments the next track number. There is no way to manipulate the actual number assigned to any track. It is alway PLUS 1 from the last track.
I always use Manual track numbering on my Pioneer machine when recording analog sources because many machines (like yours) will interpret a short silence as a track break. This may not necessarily be what you want to happen.
Feb 24, 2010 | RCA CDRW120 2-Disc CD Recorder
RCA CDRW 140 dual deck CD recorder
READY
Place cd you want to copy in tray A (EVEN WHEN YOU WANT TO GET ONE SONG COPIED )
Blank Disc in tray B .
Program tacks in any desired sequence
Press the TIME SET / PROGRAM button on recorder or remote..."WAIT" appears then "01" flashes to let you know the unit is ready for the first track.
Enter the first track you want to program using the numbers buttons on the remote .
or SKIP / SEARCH button on recorder.
When the track flashes PRESS TIME SET / PROGRAM on remote or recorder.
to select it , "OK " appears
HOPE THIS IS HELP YOU NEED >> GOOD LUCK
I WISH MINE WOULD WORK IS DOWN AND OUT !
Oct 08, 2008 | RCA CDRW120 2-Disc CD Recorder
Frmtread error
how can it solved?? My old mp3's work perfect, now i made a new mp3 cd on the 700 MB space, but it doesnt work anymore.. i get ERROR 23 on my display.. what to do??
Jul 02, 2008 | Pioneer DEH-P3500 CD Player
CD Burning gets stuck
Try this: : Decreasing the burn speed If the drive is not recognizing the disc at all, skip to Step 4. Decrease the CD writer's burn speed by half to increase the likelihood of a successful burn. Decreasing the burn speed is a quick, easy way of increasing successful disc burning sessions, at the expense of taking more time to create a disc. The following steps are for Windows XP only. For Windows 98 and Me, decrease the write speed from within the software that you are using to write discs (RecordNow, Easy CD Creator)
  1. Click Start , and then My Computer .
  2. Right-click the drive icon, and select Properties .
  3. Select the Recording tab and reduce the Current Write Speed by half (for example, from 16x to 8x).
  4. Click OK and close the My Computer window. Try burning a CD. If the drive fails to create the CD, go to the next step.
Step 4: Setting up disc recording in Windows XP If the computer does not have Windows XP, skip to Step 6. If you are using Windows XP, use the following steps to ensure that native burning is enabled:
  1. Place a blank disc into the drive. NOTE: If the error <drive letter> is not accessible. Incorrect function. " opens, close it and continue using these steps to correct this problem.
  2. Click Start , and then My Computer .
  3. Right-click the writable drive icon, and select Properties .
  4. If a Recording tab is shown, select the Recording tab, select Enable CD recording on this drive , and then click OK . Try burning a disc again. Continue to the next Step if you are unable to burn a disc. If a recording tab is not shown, continue using these steps. Figure 2: Enable CD recording on this drive c00368150.gif
  5. Look for a Recording tab: If the Recording tab is not shown, Windows XP has not detected the drive as a recordable device. Use the following sub steps to enable the Recording tab:
    1. Click Start , Run , and type regedit in the Open field.
    2. Backup the registry: Select My Computer from the list, click File , Export , type a name that you will remember, and click Save .
    3. Click OK , and browse to the following registry key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\Drives
    4. Click the Volume key that matches the CD/DVD drive that is capable of writing discs. If only one drive is installed, one volume key is listed. If you have more than one drive, examine the data values (by double-clicking them in the right pane) to find the correct drive.
    5. With the volume key selected in the left pane, double-click the Drive Type value in the right-pane. Figure 3: Drive Type registry value (CDRW) c01367502.jpg
    6. Type the number 1 in the Value Data field if the drive is capable of recording to CDRW discs (including CD-R discs). Type a 2 if the drive cannot write to CDRW discs but can burn CD-R discs. NOTE: A value of 3 indicates that the drive is only capable of reading discs. Changing this value to a 1 or 2 enables Windows to view the drive as a recordable drive.
    7. Click OK , and close Registry Editor.
Jun 20, 2008 | Dell Dimension 4700 PC Desktop
Cdj issues
Are you getting error messages? If you hold down the pause button for 10 seconds on that model , you should get one.
Keep me posted.
Oct 19, 2007 | Pioneer CDJ-100 Turntable
NaNO 2G Skips music Mp3 Sometimes Stops
In a mater in fact it could be the mp3 the mp3 was copy right protected so it skips and doesn?t let you listen to them.
Nov 02, 2006 | Apple iPod nano
NEC ND-6500A DVD&#177;RW Dual Layer Burner Logo
101 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
