Question about Universal Remote Control DIRECTV Universal Remote Control
Direct tv remote control - tv volume
Posted by christi04 on Nov 09, 2007 Report abuse
I'd like to program my new Direct T.V. Remote to my new Samsung TV, to make the volume "SLIDE" up & down instead of manually pushing the "up button over & over & over.....to turn the volume up. How can I do this???
Still need a solution for this problem?
T
I am using a directTV remote with my Samsung LCD TV. I cannot hold the volume button down to rapidly increase or decrease the voume. I have to manually do this. Can anyone help?
  • Anonymous Mar 19, 2008
    need help to program code on sanyo
  • Anonymous Jul 28, 2008
    I cannot rapidly control the volume on my Samsung TV either. Any help?
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
Posted on Jul 29, 2008
Paul is WRONG. I tried another code just now it worked! you can hold the volume button down and adjust volume upor down. I own a samsung and a directv receiver. 5 of them and just programmed them all!
Posted on Jan 18, 2010
There is but i don't know how. i know there is some way because i had the same problem but then i changed the remote for the rc64 and it was working perfectly but then i started to mess with it and now i'm back to where i started i guess there is somo other code that i don't know.
Posted on Jun 18, 2008
    Problem Solver:
  • 14 Answers
Directv remotes do not allow that function. Use the Samsung remote.
Posted on Feb 17, 2008
Direct tv remote programming to operate tv
call directv. they are very helpful with programming remotes.
1-800-247-3288
Mar 07, 2014 | Samsung Televison & Video
My remote was working fine until i moved. I have Direct Tv and the remote from Direct Tv works on guide. I bought a new remote from Magnavox but it doesn't work my tv. what should I try? '
You have to program the remote control to synchronize with TV. If you wish to get moredetails; codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 17, 2013 | Televison & Video
I just installed direct tv and their remote wont let me change volume. if I use the tv remote I lose the programming. Need a code so the tv can be controlled by direct tv's remote.
Hi, post the direct TV remote # and the box model # so I can lookup the info for you. you probably already know directTVs remote programming is built into the menu (codes and all).
You did not mention if the DT remote powers the TV on or off?
post more info if you still need help and I'll try
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Sep 04, 2009 | Proscan 42LA45H 42 in. LCD TV
Direct TV remote quits working - conflict with Samsung LCD?
Turned power saving feature on the TV to low and moved the receiver about four feet away from the TV and the remotes work fine now.
Sep 03, 2009 | Samsung TV Remote Control
Directv remote increases volume slowly
The Direct TV remote has to be programmed properly. See the user manual for the process. The problem is, the user manual tells you to enter a code for the TV, but gives you a long list of codes that may work. So it's simply a problem of trial and error. For me, the first code in the list gave me the same results that you got (having to press volume repeatedly). But when I programmed the 2nd code in the list, pressing and holding the volume worked!.
I can't guarantee it, but I suspect you'll have the same result.
Feb 13, 2009 | Samsung TV Remote Control
Direct TV remote does not control TV on/off or volume.
I have the same setup like you. Direct TV and Emerson LCD TV. The Direct TV remote stores a limited amount of codes and none worked on my TV. Sadly it's not something you can update. They seem to only stick with the popular codes. Welcome to the "head of the curve" like me. lol
Jan 04, 2009 | Televison & Video
Direct tv remote- volume control
You are wanting to make a digital volume control function like an analog one. Can't be done.
Apr 25, 2017 | Universal Remote Control DIRECTV Universal...
Need code to program toshiba tv with Direct tv remote
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Oct 01, 2007 | One For All URC-3021 Remote Control
Televison & Video Logo
4,790 people viewed this question
Top Universal Remote Control Televison & Video Experts
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
