Question about Toshiba Satellite A55-S1066 Notebook
Power but not pic
Just got a used a55 s1066..power comes on but there is no image on screen..tried the fn+f3,connected to crt monitor with no success..also...cd rom drive does not work either..What could be problem??
  • goman70357 Apr 27, 2008
    i have toshiba satellite A55-1064 when i power up only the power lite comes on. i have tried fn+f5. nothing. i can hear the fan, no power to the DVD drive or pic on screen
  • 689 Answers
Hi
Fn+F3 is the hotkey for Standby. However you can use Fn+F5 to toggle the display. If Issue persists disconnect the AC adapter and take the battery out then press and hold the power button about 5 seconds. Put back the AC adapter and battery. Turn on the computer. If you need further assistance please post your question.
Good Luck
Posted on Feb 17, 2008
Does Lenovo 3000 Y410 support dual monitors
Yes.
1) Laptop OFF, monitor OFF.
Connect a VGA monitor to the VGA port, on the back of the laptop.
The VGA port is on the right side, as you view the back of the laptop.
This is a basic example of a VGA cable, and a VGA port, (Connector),
http://en.wikipedia.org/wiki/VGA_connector
NOTE* Color does Not matter.
You can use a CRT monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external VGA monitor.
IF not;
Press, and hold down on the Fn key, and at the same time tap once on the F3 key.
No?
There are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down, and tap again on the F3 key.
(The Fn key is down at the bottom LEFT corner of the Keyboard.
The F3 key is at the top of the Keyboard.
The F3 key is the Display Toggle-Over key )
Need more information post in a Comment.
Regards,
joecoolvette
May 18, 2012 | Lenovo 3000 Y410 (59012354) PC Notebook
I accidently removed something from my toshiba satelite A55-S1066. now my screen won't come on. Although I hear it. What do I do?
If you can't see anything as it is booting up then the black light on the display is out, as in broken. Get close to it and look on the edges and see if you see any light. If you see something but no picture your back light is out.
There's a function key, look for a pix of a moniter on one of the f keys. That switches it off and on. Try using an external monitor and see if you have a display. It may be stuck on external monitor if you were using one. Using another monitor will allow you to see and change it to the laptop display.
It could also be that the video chip went out on the motherboard...
Jun 04, 2011 | Toshiba Satellite A55-S1066 Notebook
My HP Pavillion M70 monitor is saying "video cable connected?" when I try to use the monitor. I am trying to output my laptop to the monitor because my laptop screen is wearing out, but I cannot get it to...
go into the BIOS settings and tell it to use the LCD/Monitor as a display.
or
press fn key+(F5 or F7 or F8) 1x or 2x or 3x.....
Fn key combination. The Fn key is located at the lower left of the keyboard, normally between the CTRL and the ALT key. Toshiba uses Fn-F5 to toggle between the laptop LCD and an external display. IBM or Lenovo uses FN-F7, Acer varies with the model, using Fn-F5, Fn-F3, Fn-F8, Sony Fn-F7, Dell Fn-F8, HP or Compaq, Fn-F4. There are variations with the age of the laptop and not all manufacturers have standardized on a key combo across the whole range, but you can usually figure it out from the little graphics on the function keys that line the top of the keyboard.
Aug 25, 2010 | HP Pavilion M70 17" CRT Monitor
Toshiba Satellite 1905-S301 PC Notebook will not
Hi! You may want to toggle the function button designated for turning the monitor on or off. Press FN button together with th efunction button that has a monitor image on it. some system uses F2 of F3 button to do this. (Example: press FN+F3 or FN+F2 button together once while computer is on to turn on system display)
Jun 08, 2010 | Toshiba Satellite 1905-S301 Notebook
Toshiba Satellite A55-s1066 need help Loacting Bios Chip.
you need to remove all at same time and memory modules too, and after remove the cmos battery, try to find a passw clear switch on the motherboard nearby cmos battery.
Feb 14, 2010 | Toshiba Satellite A55-S1066 Notebook
I don't have video on my 400sd4 laptop
If the system is booting up completely and you can hear is starting up then the problem is limited to your video.
First try this
Boot up your system so that it's in windows (listen for start sounds and windows music etc)
once you believe the system is fully booted press and hold the FN key. While holding FN press and release the F3 key one time and then let go of FN. Wait a few second and see if the LCD screen comes on. If it does not try FN-F3 a couple more time, waiting a few second in between.
If that does not work then try plugging in and external monitor to verify that the system is working otherwise. If the external monitor does not come on right away then press Fn-F3 again with it attached to allow the system to send a signal to the external port.
If it works on the external monitor but cannot come on the LCD screen, the that indicates a problen inside your laptop or LCD screen.
Dec 03, 2009 | Gateway 400SD4 Notebook
Connecting Gateway 450 notebook to tv using vga to svideo convert
It is possible that the signal from the portable is not compatible with your convertor or device, however, if you are getting no image at all (not even lines etc.) then the laptop may not be set to send a signal through the VGA port at all.
To toggle the image to the VGA port do the following
  • Press and hold the FN key on your keyboard
  • While holding the FN key, press the F3 key one time
  • Let go of the FN key
  • Wait a few seconds to see if you get anything thing on your external device.
  • If you do not then press FN-F3 a couple more time waiting a few second in between each try.
the Fn-F3 toggle switched between the LCD only, LCD+CRT, and CRT only modes. You may find that it works on the CRT only mode but does not work correctlly with both. When this occurs it's a limitation between the compatibility of the settings requires for both screens, so you would only be able to use each by themselves not together.
Nov 19, 2009 | Gateway 450ROG Notebook
Swithcing from laptop screen to lcd monitor
Hi
Connect the monitor, flat panel, or projector to the laptop's 15-pin video connection on the back of the computer as shown to the right. Once connected, your laptop may automatically switch to the new external display or you may be required to press a sequence of keys in order to switch from the laptop to the external display. video.gif For example, often either Fn + F3, Fn + F5, Fn + F8, or Fn + F9 is pressed to switch between alternate displays. So if your laptop was Fn + F3, pressing and holding both Fn and F3 at the same time would switch between displays. Often, the alternate key pressed in conjunction with the Fn key will be labeled as CRT/LCD and/or have a picture of a monitor on the key or close to the key. Unfortunately, the keys pressed to switch displays is dependent on the model and manufacturer of the laptop. If none of the above key sequences work, consult your laptop documentation or consult your laptop manufacturer.
Some laptops also have the ability to have the display on both the laptop and external display and/or one or the other at a single time. Laptops with this ability can switch between these modes by continuing to press the same function keys until in the mode the user wants.
Feb 01, 2009 | HP Pavilion dv6000z Notebook
My toshiba satellite pro 4600 laptop display screen,,, ummm...accidentally broke.I have a extra home pc monitor,Does my laptop support an external monitor? If so,can i just plug it in and windows will...
It should support it.
If your laptop has a VGA output, connect the VGA cable from that to VGA input on monitor. Then hold down the function (Fn) key and press one of your F2 or F3 or whatever F# keys that has a pic of a monitor on it or it will say lcd/crt in blue lettering on it.
Apr 03, 2008 | Computers & Internet
Toshiba Satellite A55-s1066 wont boot
Check out this Toshiba document - http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=571487xml&sliceId=&dialogID=19454183&stateId=0%200%2019450573 Look about half way down the document to the section that starts with: * If the AC power light is blinking, try the following steps:... See if any of those suggestions help.
Sep 17, 2007 | Toshiba Satellite A55-S1066 Notebook
Toshiba Satellite A55-S1066 Notebook Logo
136 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
