Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Furnace I have carrier 8000. We were told the batteries were dead and that was what was causing the furnace to kick off and not run at night, When we get up its 63 degrees but set on 69. If you turn the thermostat off and then on again it will work ok for a few hours. then it happens all over again. you can start it manually but it won't come on by itself, then it runs for a few hours ok and repeats at night it goes off...We repalced the thermostat, but it still is the same.
  • judyann1 Feb 18, 2008
    It turned out to be a sticking gas valve.
  • 86 Answers
Change indoor sirkit board.
Posted on Mar 16, 2008
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have a Carrier Weathermaker 8000 furnace. it will not light.I tested the igniter on my upstairs furnace and it will glow and light that furnace. I can manualy light the furnace with a match. flame sensor...
If you're sure the igniter is good and the controller is sending voltage to gas valve to open, but not to the igniter then, yes, the controller is bad. The only way to know for sure is to remove the igniter's molded plug from the board and test voltage directly at the board. You should get about 100-120 vac to the igniter.
Mar 25, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Flame sensor dirty
Sandpaper lightly scrubbed over the sensor tip to remove any contamination.
Sometimes cleaning is not enough and the sensor must be replaced.
Jan 30, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a new home 1 yr and when the furnace kicks in, I am assuming the fan it makes a noise but as soon as the heat starts the noise is gone, could this be the furnace blower
Check by turning the unit off and turn the fan to on. Do you hear the noise now? The noise your hearing could be coming from your combustion fan assembly instead. Newer furnaces have a in-shot burner and are nosier than the old style of heater.
Jan 04, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Inducer Fan Seems To Be Rattling
what make of furnace check for birds and blockage
unfortunatley when they go there gone the squirrel cage wheel will not come of shaft u will need motor n wheel or a "plug n play housing all in one"
Oct 05, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker 8000 - furnace does not ignite
having a problem with a weather maker 8000. It will not come on at all unless I shut down the switch on the side of the furnace. filters is clean. it will start to light then stop
Dec 10, 2008 | Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
94 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
