Tv wont turn on
I av a funai hd ready tv model :nlc~3204bc stand by light on but wen switch on goes 2 green then turns it self off an blinks red had same prob a few days ago but it came back on wen i checked everythin but done that an still no joy plz help
  • nigelharris1 Oct 22, 2008
    i have a funai hd ready nlc3204bc that will not turn on, the stanby button keeps flashing red
  • GILLETTE22 May 16, 2009
    MY TV TURN OF BY ITSELF. THE RED AND GREEN LIGHT FLASH ON STAND BY MODE. WHAT SHOULD DO. I CALLED COSTCO WHERE I BOUGHT IT THEY TOLD ME TO CALL SAMSUNG DIRECT
I have a nlc-3204bc funai hd ready, the stand by light keeps flashing red on and on, can not switch it on
Posted on Oct 22, 2008
Funai NLC 3204BC an LCD TV had lines running vertically down the screen for sometime. Now has stopped working completely. Is there such a thing as a 'picture board'?
Your vertical lines is coming from molded buffer attach on lcd screen. This is a factory defect becuase the is a micro-dirt create a gap from the semiconductor. Not worthed to fix becuase you need a new panel. For the power absolutely your power had a output of 5 volts which also has a semiconductor issue.
Oct 15, 2013 | Funai Televison & Video
Mitsubishi big screen HD 1080 series model WS-55809. it switched off one day. and when i turn it back on it switches right back off. red light in front. what part do i need to fix it/
That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
Mar 31, 2012 | Mitsubishi WS-55809 55" Rear Projection...
I have a hitachi 55pma550 plasma tv.when I turn on the main switch red light comes on standby. But when I turn on tv the red red light on stand by turns green only for 10 seconds and goes red no picture...
It's most likely the smps. You'll first need to check voltages at CN63, pin #1-(+5v), 3-(+3.3v) and pin 8-(+6v) Also check CNPPS, pin 1-(+30v), 4-(+5v), 8-(+12v), 12-(+10v) absent these values and the power supply is clearly the problem.
Jun 30, 2011 | Hitachi 55PMA550 55 in. HD-Ready Plasma...
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
TV screen turned on for only 10-15 secs then self turn off, followed soon after by the tv power another 10-15 seconds later. if i try this a few times screen wont light up at all.Is it the TV Lamp?
1) Can be dust do a good clean
2)Check for the fuse and change it if needed.
3) Capacitor needs to be changed, you'll have to findout which one.
Hope it helps, good luck
May 19, 2009 | LG RU-52SZ51D 52" Rear Projection...
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Funai mopdel nlc 3204bc
Sorry my tele is a panasonic viera TH-37PA60E
Nov 06, 2008 | Televison & Video
My samsung tv wont turn on, red light keeps flashing on the front.
i had this with my samsung and my mums instead of pressing red power button press either switch from analog tv to digital button or just press a number
Jun 04, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
564 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
