Question about Ecoquest Fresh Air Air Purifier
Ecoquest FreshAir - UV Flickering
Hi - The UV light on my Ecoquest FreshAir purifier is flickering, what should I do? Does the bulb, starter and/or fuse need to be replaced? Let me know, thanks.
Paul
  • Anonymous May 14, 2008
    HI
    change the starter/ capacitor. It will resolve the flickering if the uv lamp is OK.If the lamps is bad you must change both for 40 $ on ebay(lamp and starter /capacitor) Best regards from Montreal
Need change the whole RCI cell since the u.v light is inside the RCI cell.
Posted on May 23, 2009
  • 31 Answers
UV bulbs, or rather the RCI cell needs to be changed every three years in the FreshAir, or when the "Replace RCI cell" appears, whichever comes first. The UV bulb loses its intensity over this period of time.
Eric
Download PDF Manual
Posted on Feb 06, 2009
How do you replace the bulb in a freshair purifier
Make sure you have the starter use with replacement bulb. Usually comes with replacement bulb. Open the back of th unit by removing the cover.
Oct 18, 2012 | Ecoquest Fresh Air Air Purifier
Ecoquest freshair - inside wireing
Black = phase white = Neutral , Strip yellow/green =ground
Aug 11, 2008 | Ecoquest Flair Air Purifier
How to replace your uv light in your fresh air ecoquest air purifier?
1. Unplug the purifier
2. Remove the two screws on the back cover and remove the cover.
3. Remove the two screws on the the top that hold the lint screen and remove the screen.
4. Remove the purification plate by sliding it out.
5. Remove the RCI target plate by sliding it out.
6. Disconnect the purification plate contact lead wires from the purifier plate cage.
7. Remove the two screws at the bottom of the plate cage.
8. Slide the cage forward, lift and remove the cage.
9. Rotate the uv bulb a quarter of a turn and lift it out of the unit.
10. Install the new uv bulb and rotate it a quarter of a turn to lock it.
Perform steps 1-9 in reverse order to reassemble the purifier.
Dec 06, 2010 | Ecoquest Fresh Air Air Purifier
Hi i have a Ecoquest Breeze AT Living Air
that ligth its uv lamp you can replace it your self get parts from ecoquest for the rigth model
Apr 02, 2010 | Ecoquest Breeze AT Living Air Purifier
The blue light of my EcoQuest Fresh Air Purifier flashes
The UV light is a Flourescent like bulb. It has a starter. The starter and bulb can be bought on Ebay for about $20. It is easy to replace.
Mar 31, 2010 | Ecoquest Fresh Air Air Purifier
Fresh Air Display on and NO POWER
possibly a bad control finger control board. had a problem just like that and that repaired it.
Mar 27, 2010 | Ecoquest Fresh Air Living Air Purifier
Flashing UV light
I would jump out on Ebay and get a bulb and starter for around $20-25. Easy to install!
Mar 23, 2010 | Ecoquest Fresh Air Air Purifier
I need replacement parts for my FreshAir. Lamp
E mail to healthytech@triad.rr.com. List the parts you need and the serial number. They'll be glad to help you!
Mar 31, 2009 | Ecoquest Fresh Air Air Purifier
Fresh air flashes
This looks like a control board error. It needs to come in for repair. be careful not to turn it on, the RCI cell ( the blue light in the back) will stop working if it is switched off and on fast.
Call the company 1-800-989-2299 and get an RMA number. If you are under three years, you are still under warranty.
Dutch
Mar 28, 2009 | Ecoquest Fresh Air Air Purifier
EcoQuest Fresh Air Lamp replacement
Its probably the starter. Manual says to replace both lamp and starter at same time.
Jul 19, 2008 | Ecoquest Fresh Air Air Purifier
Ecoquest Fresh Air Air Purifier Logo
1,383 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
