Question about Panasonic NV-FJ620 VHS/S-VHS playback VCR
Problems with recording/rewind/fast forward
Recorder linked thro skybox keeps cutting out when fast forward or rewind ,often wont let you set up to record,producing a whirring noise,cuts out t/v which then comes back after about a minute will do this 2-3 times and then settles down. it will then allow you to play recorded tape but the minute you fast forward/rewind to miss ads goes haywire again. driving me mad!
Any help appreciated
regards geoff
  • 27 Answers
You probably have a bad power supply. But as you will learn, repairing any VCR will cost more than buying a new one.
Posted on Feb 18, 2008
I do not know how to use it, i have the manual, but i do not find it
The recorder takes 2 AAA batteries. Press Menu/Folder (on the right above the jogdial (Stop, Rewind, Fast Forward, Play)) to select the folder to add a new recorded item. (The folders are A,B,C, or S. Folder S will come up with a date and you can select another date for the recording.) Folders A, B and C can hold 100 files each; Folder S has 365 dates which can hold 15 items each.
Press and hold the Menu/Folder button for a second or longer. The Screen should show the Mode menu. Press Play and then the Fast Forward and Rewind buttons to set the recording quality. HQ is the high quality recording and will fill up the available storage on the organizer more rapidly. LP will record for the longest period.
Set the Microphone sensitivity by pressing and holding Menu/Folder. Then press the Fast Forward or Rewind button until Mic appears on the display. Then press Play and use the Fast Forward or Rewind buttons to select Low or High sensitivity. (An external mic often gives better results.)
Once you have set the folder for the next recording and the recording quality and microphone sensitivity, press Rec (center above the jogdial) to start recording. Press Stop to end the recording or Rec to pause it. (It will stop if the Pause is longer than 10 minutes.) Press Display to see how much longer you can record before using up the available storage space.
To play back a record, locate the item in the folder then press Play.
The manual for the Olympus VN-1800 is available from the Olympus support site: http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=841 . The direct link to the English version of the manual is http://www.olympusamerica.com/files/oima_cckb/VN-900_VN-1800_VN-3600_Instructions_EN.pdf .
I hope this helps.
Aug 30, 2011 | Olympus VN-1800 Digital Voice Organizer
I lost the remote control, how can rewind the hsv tape. Thanks.
There should be a rewind button on the front of the main unit (usually indicated by either REW or 2 arrows pointing to the left), this should be next to the fast forward (again indicated by either F-FWD or 2 arrows pointing to the right) as well as PLAY and STOP - for the VCR. The only thing you would need the remote for is to set the clock and/or perform setup for the DVD player as well as timer recording. Try a universal remote which will make fast forward, play, stop, record (to VHS) and rewind easier.
Apr 11, 2011 | JVC DR-MV7 DVD Recorder/VCR
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Dec 07, 2010 | Dictaphone 1740 Desktop Cassette...
Teac HDR2500T Fast Forward/Rewind problem: It
easy, download the software update from the teac website- had the same problem myself
Jan 10, 2010 | Televison & Video
Erasing recorded tapes
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
Apr 20, 2009 | Philips Desktop 720-T Desktop Cassette...
Does not play. will rewind & fast forward
Its most likely the cam gear. Any sony dealer can replace the gear.
Jan 07, 2009 | Sony BM-87DST Desktop Cassette Transcriber...
How do you erase dictation from a Lanier dictaphone?
Dec 17, 2008 | Lanier 260T Desktop Cassette Voice...
Won`t Rewind
Do you still have the remote control? Try with the remote. If this works, the button of the camera is broken and have to be replace by a qualified technician. Good luck!
Sep 27, 2008 | Sony Handycam CCD-TR517 Camcorder
Panasonic NV-FJ620 VHS/S-VHS playback VCR Logo
207 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
