Question about Blaupunkt IDC-A09 5-Disc CD Changer
Connecting Block Need coloured diagram of ISO connecting block to reconnect the wires in the correct places. Wiring has become detatched from the block.
  • erathcooney Nov 06, 2008
    have a new radio with no connecting block on the wires need diagram of iso connector to install one thanks
  • Anonymous Mar 20, 2014
    iso wire colour
    Novelist:
  • 123 Answers
HI! I`ve got big problems with mine where I think that it want re-syncing, ie reset all the gears and cogs etc. I can`t find a schematic anywhere. Anyway, I`ve just nipped out to our Peugeot 307 and drawn down the wire positions for you. Here they are:-
! ! Dark ! Green ! Red ! Red ! ! !
! Yellow ! ! ! ****** ! ! !
! ! !Green/ ! ! ****** ! ****** !
! ! Yellow ! !Yellow ! !Yellow !White !
NOTE. The wires marked with ******, are twisted together in the loom. THERE ARE TWO RED`S AND TWO YELLOWS.
I hope this sorts your problem. All the best. Ian
Posted on Feb 19, 2008
  • Ian Percy Feb 19, 2008
    I have enclosed a Jpeg image of the plug if this is any use to you. All the best, ian
What are the correct wiring colour codes for the rear lighting circuits, so that I can tow a caravan?
under no circumstances cut any wires
the trailer plug is generic so proper trailer wires will have the correct colors for the plug pin numbers
by using a multimeter or circuit light you can determine which wire in the block is live and then connect the corresponding color in and then to the correct pin number in the plug
probably quicker if you get a tow bar shop to fit the plug for your
takes around 10 minutes to fit the correct harness that they will have
Apr 28, 2017 | 2007 Mitsubishi Outlander LS
I have a peugeot 306 somebody has cut stereo wiring block off so i am looking for wiring diagram preferly coloured coded thanks
Easist way to solve that problem is ,go get enouther harness for it from a auto wrecker from the same kind of car, Then the wires will all match up, Just reconnect one buy one at a time,
Nov 11, 2012 | Peugeot 306 Cars & Trucks
Hi I've just got a Honda cb250n and there now
Hi if you havent already checked the fuse at the starter solenoide 30amp check it first. Next locate the rectifier this will have 3yellow wires these come from the alternator and provide AC voltage to the rectifier which is then converted to DC voltage used for charging the battery, at the rectifier you have green wire/s this is the earth and red wire/s this is the voltage in and out, it is here at the connecting block you must inspect the condition of the wires do not unplug the block simply check for oxidiseing which is visible to the eye and is green in colour, simply twist and pull gently on each of the wires to check for conectivity, if any break off you can bypass the block by removing the wire from each end .next it is not uncommon on the old 250n for the ignition switch to become faulty, using a test light if you dont have one make one up by removing one of your indicators, the coloured wire orange or blue depending on which side you remove is the indicator live wire, at the ignition switch using your test lamp check for 12 volts by placing the coloured wire on the red ignition wire your lamp should light if you have voltage here, if you dont have power trace the wire back and look for breakages in the wire, you could also run a new wire from the battery to the switch and with this connected the switch should opperate normaly
Oct 20, 2011 | 1972 Honda CB 250
I need diagram to wire defy 600s hob and oven , can you help please
Hi Gary The hob connectors have colour coded plug ins. They are starting from right to left the red connector is for the front right plate, the white is for the back right plate, the blue is for the the back left plate and the black is for the front left plate. Now I am not sure of the config in your country but another way to look at this is that The red dot 2000 W (large plate) is connected to the black harness and the red dot 1500 W is connected to the blue harness. The std large plate 1500 W is connected to the white harness and the red harness is for the 1000W small plate. The wiring onto the actual plates should be accrording to the colour codes as follows: The harnesses are all 4 wires and are colour coded blue white ( wiring block 1) , yellow white(block 2), white ( wiring block 3) and the red white block 4. The actual plates are numbered from left to right as 1,2,4,3. But my wiring write up takes it as standard 1 to 4 so do mot worry about the numbers on the plates as some plates have no numbers. Hope this helps.
Nov 09, 2010 | Stoves 1100ESIDLa Electric Kitchen Range
Need to know wiring diagram to fit cd player in to 95 astra van
YOU SHOULD HAVE AN "ISO" CONNECTOR IN THE ASTRA, IF THIS HAS BEEN ROBBED THEN GET A NEW ONE FROM MOTOR FACTORS, INSTRUCTIONS NORMALLY ON PACK
RED SWITCHED LIVE
YELLOW CONSTENT FEED MEMORY
BLACK GROUND
ALL IN 1 BLOCK
2nd block are speakers
SPEAKERS ARE PAIRED BY COLOUR
Dec 05, 2009 | Car Audio & Video
Need a radio wiring diagram for a 2002 ford windstar sport. We're trying to install a 'newer' CD Player ( DEH P3300 ). We have the colours for that but now we need the wiring colours for the van.
The colors from the old head deck should be the same as the ones from your new one, just replace purple with purple, blue with blue, black with black on the side of the chock block facing towards you.
Aug 05, 2009 | Car Audio & Video
Line voltage Tstat installation Dayton D-F79 elctric shop heater
If I understand your post correctly....You state that you are hooking up a 240v heater and towards the end you speak of removing jumpers...W2 terminals..ect. It sounds to me your trying to us a 24v low voltage thermostat instead of a Line voltage thermostat.That's what I'd take a look at.
Dec 16, 2008 | Dayton (3E379) Heater
Wiring diagram
The LEd wires need a wire run from the speaker to the Fuse block in your car. The small Red wire from the LED will be the one that hooks to Swtiched 12 Volts supply on the fuse block so that your Led Turns on when you turn the keyswitch on. The Black wire goes to ground, or to a metal part of your cars body, probably the same point where your Amp is Grounded.
The Octane R10 is a Single Voice Coil or SVC.
AMP+ to Sub+
Amp- to Sub -
Use 12 guage wire.
Nov 07, 2007 | Phoenix Gold Octane-R 10/10d Car Subwoofer
Blaupunkt IDC-A09 5-Disc CD Changer Logo
484 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
