Question about Philips 107E66 17" CRT Monitor
Philips 107E66 Monitor dead, after changing faulty TEA 1507 monitor relay is constant ticking.
  • Anonymous Mar 06, 2009
    no pulse found on fet gate pcb when changing the 1057 ic
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
Vga connector
pls. check vga cable or get another cable there might problem with the cable.
Nov 08, 2013 | Philips 107E66 17" CRT Monitor
Dog led switching, B high
> dog LED switching
> B high
If that is a Japanese "haiku", the number of syllables is wrong, and the number of lines is wrong.
Oct 22, 2010 | Philips 107E66 17" CRT Monitor
I have a samsung monitor SyncMaster93DF it stopped completly with a little sound (tick tick ) i oppened it and found the hot transistor shorted (st2310) i replaced it with bu2527 because i couldnt find the...
try C5804 or J6812 instead of bu2527..replace IRF630 in 50 volt supply line.it may b faulty...bt if problem after that then flyback transformer may b faulty. repalce it with same one.
Sep 05, 2010 | Samsung SyncMaster 793DF 17" CRT Monitor
Pin details
Hope this will help you.
Apr 08, 2010 | Philips 107E66 17" CRT Monitor
Control menue is lock
change its memory ic with the correct programme
Feb 07, 2010 | Philips 107E66 17" CRT Monitor
I HAVE A MONITOR THAT IS HOOKED UP TO MY COMPUTOR IT WILL NOT DISPLAY ANYTHING
Hook up a monitor that works, then change the resolution to one that this "bad" monitor can display.
Dec 13, 2009 | Philips 107E66 17" CRT Monitor
Stnady button flashes no screen.
Have you tried using this monitor on another laptop/PC? It might be your machine and not the monitor.
Also, check the pins on the cable and make sure that they are not damaged or bent.
Hope this helps.
Alan
Mar 25, 2009 | Philips 107E66 17" CRT Monitor
Phillips VGA Cable colour chart
you can use any vga monitor with the same color output and resolution setting just goto craigs list in your town and look for someone throwing one out detach old cable and reapply to your screen by either soder or splicing the wires independently together this is tricky
http://www.lammertbies.nl/comm/cable/VGA-monitor.html
Pin Name Function 1 RED Red video 2 GREEN Green video 3 BLUE Blue video 4 n/c not connected 5 GND Signal ground 6 RED_RTN Red ground 7 GREEN_RTN Green ground 8 BLUE_RTN Blue ground 9 VDC 5 VDC supply (fused) 10 GND Signal ground 11 n/c not connected 12 SDA DDC / I2C data 13 HSYNC Horizontal sync 14 VSYNC Vertical sync 15 SLC DDC / I2C clock
Jun 02, 2008 | Philips 107E66 17" CRT Monitor
My philips monitor is not working so how can i get technical support?
1.How is this powered? From a separate power supply or direct into the monitor. 2.Does the power light come on when switched on. Can you see any movement in shadowy form on the screen? 3. Check the data cable both ends for bent pins. If the moniot is powering up the connect it to another computer to confirm Monitor or Computer? Do all this and answer the questions clearly then come back
Jun 01, 2007 | Philips 107E66 17" CRT Monitor
Philips 107E66 17" CRT Monitor Logo
331 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
