Question about Magic Chef (CSD2610KRW) Top Freezer Refrigerator
SIDE BY SIDE MAGIC CHEF REFRIG
ICE BUILDS ON FREEZER FLOOR
WATER OCCATIONALLY LEAKS ON FLOOR
  • 1 more comment
  • Anonymous Mar 18, 2008
    Water occasionally leaks from the freezer side, appears to be leaking from the rear bottom corner, maybe the valve, I did see a small amount of water on the line where it enters the refrigerator at the back of the ice maker. There was water on the valve also but I'm not sure if it ran down from where the ice maker is.
  • skaha Sep 27, 2008
    Ice builds up on the bottom of the freezer and and slowly thaws and drips onto the floor. If this is the same problem, where do I pour the hot water to thaw the frozen line?
    I know it is not from the icemaker as it has not been attached.
    Thank you
  • cowsedar Apr 15, 2009
    How does one go about defrosting the drain line? Thank you!
Your drain line is frozen. you nee to put hot water down it
Posted on Mar 13, 2008
Magic chef model number CSB2323AR seems to be a defrost problem. Water accumulates at bottom of freezer then ices up. Is there a drain pan on this model?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the lower right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 07, 2011 | Magic Chef Refrigerators
Ice builds up on floor of freezer apparently some leaking as my lamented floor is showing some damage. i have cut off water supply to icemaker and water tap thinking this was problem.
most likely you have a plugged and frozen defrost drain. check behind the bottom basket of your freezer section to confirm this you will find alot of ice build up. to repair you self:
  • unplug refrig.
  • unload freezer section
  • remove rear access cover (on jenn-air's there are 2 screws about mid way up they are painted white and arent very obvious).
  • clear all ice
  • flush drain hole with warm water. ( i use a turkey baster filled with hot water to get best results)
  • reassemble unit
  • reapply power
this should stop your water leak. thanks Peyton
Oct 10, 2010 | Jenn-Air JSD2789GES Side by Side...
Magice Chef side by side builds up ice on freezer floor
it sounds like a defrost element on the evap. if ice builts up and the elemet is not working then it will build ice on the evap and not cool.....
Jul 27, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
My refrige leaks water on the floor from the freezer side on the left. I turned the water off and disconnected the water line. Still once or twice a week the refrige leaks water on the floor.
Sounds like ice build up on the freezer coils. Disconecting the water line doesn't stop regrigerant from flowing through the coils since they are still working. Easiest way would be a hair dryer to melt the built up frozen consensation. After you should see no water on the floor and you can turn the water back on (i assume the water is for your ice water and ice cube tray).
Apr 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Magic Chef Side by Side MOdel RC224RDA
I have the same problem. It turned out to be a problem with the doors. When my kids go to get a snack and close the fridge door (read slam the door) the air pressure pops the seal open on the freezer door causing the ice cubes to begin melting. The bottom items stay frozen (warm air rises). It took me a long time to work this out.
Remove the ice maker tray. Remove the ice blob, being careful to put the u-shaped wire ice-level sensing wire thing, in the up position or the system will dump ice and water all over the freezer. Put all back clean and dry and buy a velcro adhesive strip and install it on top of the freezer door to prevent the door from always blowing open.
Hope this helps
Jul 03, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
Magic chef water running on floor, from under risper, i removed crisper did not see drain hole ice maker not hooked up
leaking from frig side or freezer side? If its freezer side the drain hole is behind back wall. Get you trusty blow dryer out...
Oct 16, 2007 | Maytag MZD2766GES Side by Side...
Water squirting from ice maker
Does it do it all the time or only when the ice maker call for water... you may have a bad water valve 67006531 VALVE, DUAL WATER or a ice dam in you icemaker let me know
Aug 25, 2007 | Magic Chef (CSD2610KRW) Top Freezer...
Magic Chef (CSD2610KRW) Top Freezer Refrigerator Logo
410 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
