A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Short answer - $5 door switch. I've dealt with this at least 3 times in the last 5 years on Frigidaire, Electrolux & Whirlpool dryers. I certainly hope it's the right fix action for you as well. Cheers.
I understand that your new Frigidaire dryer, model# FASG7074NR2, stops at the beginning of the cycle and states that the door is open. I also see that opening the door firmly, closing the door firmly, and unplugging your appliance, the display still reads "Door Open", and will not run. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your dryer and determine why it is stating "Door Open". I hope this is helpful.
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked. 2. Insert key into the ignition (Do NOT Turn) and Pull key out. 3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door. 4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition. 5. Within 3 seconds the power door locks should cycle automatically indicating successful
entry into programming mode. Return to step 1 if the locks do not cycle at this point. 6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
B. Immediately after letting go of the lock and unlock buttons, press the lock button by
itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle once
indicating successful programming. If the door locks do not cycle, or cycle twice.
repeat steps A and B in step 6 as your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new remote. 7. Close drivers door.
YOU MUST HAVE MASTER KEY:
1. Start with key out of the ignition, drivers door is open all others closed and drivers door is unlocked. 2. Insert key into ignition (Do not turn) and pull it out. 3. Perform these steps within 40 seconds. A. Using the power door lock switch on drivers door perform 5 lock/unlock cycles starting with lock. Use an even pace and try to go about one cycle per second. (1 cycle = 1 lock and 1 unlock.) B. Close, then open drivers door. 4. Perform these steps within 40 seconds. A. Using the power door lock switch on drivers door perform 5 lock/unlock cycles starting with lock. Use an even pace and try to go about one cycle per second. (1 cycle = 1 lock and 1 unlock.) B. Insert the key in the ignition cylinder. C. Turn the ignition to ON (Do NOT Start) then back to OFF. D. Turn the ignition to ON (Do NOT Start) then back to OFF. E. Remove the key from the ignition. 5. Within 3 seconds the power door locks should cycle automatically indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point. 6. Perform these steps within 40 seconds. A. Press the lock and unlock buttons on the remote simultaneously for 1 second. B. Immediately after letting go of the lock and unlock buttons, Press the lock button by itself and hold for 2 seconds. Within 3 seconds the door locks should cycle once indicating successful programming. If the door locks don't cycle or cycle twice, repeat steps A and B, your remote has not been accepted. C. Repeat steps A and B in step 6 for each new transmitter. 7. Close drivers door.
