LG WFT7030TP My washing machine main motor does not turn everything else looks loke it is working but the main motor does not turn i looked at the wires and all of them look in order. the control board is filled with potting liquid in order to keep water out but i dont know where to test to see if there is power going to the motor or not. you dont have a manual for this model. and i cannot find a support centre number or website for lg
    Sniper:
  • 74 Answers
Trouble shooting a washing machine is easy but you have to know the sistem first if the washine machine take water wwell but dont do nothing eals could be a couple of things. The water level switch send curent to the water selenoids when the maching is empty then when the level of water reach the selected level the presure of the water active a presure swithc and the curent go to the timer there the timer send the curent to the motor, as you can see there are a procedure that you have to know to repair a washin machine and some instrument to trace continuity and curent warning disconect the machine frome ac outlet befor service .....good luck and rate me if you survive this riskey adventure...
Posted on Feb 17, 2008
How does a PCB main assembly look like on a LG washing machine
pcb board main is the one thats accessed though the back of the washer behind the panel, the unit is usually at the bottom left side and has loads of wire and plus on it, it controls the motors and the heating element when told by the cyle board, it has switch-relays that turn things on at the times set for the setting you you to wash your items.
May 31, 2017 | LG Washing Machines
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
Apr 03, 2016 | LG Washing Machines
The SE light flashes when turning on the washing machine
Not sure which washing machine you have. But assuming it is an LG SE is a serious fault.
Motor fault detected Can also be caused by be main PCB
This is not a good fault code to see as it will generally be correct and either the washing machine drive motor or the main electronic control PCB is faulty.
  • Check motor
  • Check motor tacho
  • Check all connections and blocks to the motor
  • Check connections on the main control module
  • Check main control module
For more detailed analysis please post make and model of your washing machine in the comments field.
Sep 26, 2014 | Washing Machines
My mahine is a LG :MODEL:WF-+857,CAPACITY:8.5KG,APP:NO:N19973
no idea without a look but i suspect the contacts on the motor armature
Apr 27, 2012 | Bosch Washing Machines
The washing machine is very noisey when on the spin cycle. It makes a clunking noise. It is a new problem and the washing machine is a couple of years old, so it is not something simple like the pins left...
Please shut off the unit, remove the power and then using a good inspection lamp look into the back side/ underside of the washer.
manually turn to see if there is noise, this can come from faulty belts, motor, bearings on motor or the main agitator shaft assembly or even if the drum is out of sync due to poor suspension and support. If so remove and overhaul the unit. a bit of oil or grease can solve in many cases.
Also look for any foreign objects on the drum.
Jun 14, 2011 | LG Washing Machines
Wash & spin is blinking and machine is not working
Possible that the controller is not giving out the voltage to the motor or if so the motor is faulty.
You will need to look from the bottom to the motor for voltage , if there is voltage on motor then check the main capacitor for weakeness. connect one in parallel. If there is no voltage to the motor then the controller board is faulty.
Sep 14, 2010 | LG WFT1071TP Top Load Washer
I HAVE WD-10165F LG WASHING MACHINE, BUT ITS DRUM IS NOT WORKING
Possibly the Main Capacitor is leaked/ burned.Try replacing it with new ones.
To locate it, you can follow the schematics diagram behind the machine.
It's look's like a mini can with cable, sometimes the color is white, and on the body written 25uF/400 VAC, or something like that.
Hope this work, if still won't, contact me for furthure assistant.
Oct 23, 2009 | Washing Machines
LG WM1285 WASHING MACHINE
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
Dec 17, 2017 | LG Washing Machines
Washing Machines Logo
160 people viewed this question
Top Washing Machines Experts
