Question about Whirlpool Calypso GVW9959K Top Load Washer
Washing machine top loading
My machine is is not working, all lights getting on and water is draing continuously, machine buttons not responding, please solve my problem
  • Gary Davd
    Gary Davd May 11, 2010
    are you getting any codes coming up on the display??
No codes are on, all lights are continuously on and water is draining out, wash cycle is not strting
Posted on Feb 18, 2008
Simpson eziset 550 washing machine buttons won't respond.
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
By the way my advice is free cuz God is good!
All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced
Lastly CONTROL BOARD
If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures.
https://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help
http://www.partselect.com/Repair/Washer/Will-Not-Start/
http://www.partselect.com/Repair/Washer/Will-Not-Start Washing Machine Repair Help
Jan 10, 2017 | Refrigerators
Machine won't run on wash and rinse but motor will start and drain the water out
What you hear is the drain pump, remove back panel to see the problem
Mar 31, 2013 | Haier XQJ50-31 Top Load Washer
No spin cycle - cloths soaking wet - motor runs continuously - hot burn smell
if the washer drains the drive cuppler it bad let me know if draing can walk you threw how to replace
Jun 24, 2011 | Roper RAS8445KQ Top Load Washer
Kenmore series 90 bypassing water. doesn't fill instead water flows out the drain tube once it reaches a level just below small load.
raise the drain hose up till the arch is about level with the back control panel. Once you here the water stop draing restart your machine and it should return to normal operation
Jun 03, 2010 | Kenmore 15864/15862 Top Load Washer
Draing water not working.
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
Courtesy jsrock516
May 24, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Standing waterin the door opening seal after each load.
Sometimes small pieces of clothing get into drain system and plug off draing. Check before pump for clog.
Oct 02, 2009 | LG WM-2277HW Front Load Washer
Water not drain all the time
First check for any blockage in the drain hose.Remove it and make sure nothing is obstructing it. Is the hose kinked? If not your propellers on pump are worn and you will need to replace pump.
May 11, 2009 | Kenmore 22422 Top Load Washer
My washer won't stop draing as it fills
Does the washer makes a full cycle properly and only problem is water's constinously draining ? If this is the phenomena, verify that the pipe discharged to the drain hose (the pipe that water going out from the machine)is at washer height up to one foot higher. Goog luck !
May 25, 2006 | GE WBB4500EWW Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
57 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
