TRIGEM IMPERIAL GV 20030812 MOTHER BOARD
I REPLACED THIS MOBO WITH THE SAME KIND. I ATTEMPTED TO INSTALL WIN XP (OEM) ON A FORMATTED HD.IF THE SETUP SCREEN COMES UP IT WILL HANG WHEN IT BEGIN TO LOAD THE FILES OR IT WILL REBOOT WHILE CHECKING THE STSTEMS HARDWARE CONFIGURATION I CANT EGT IT TO BOOT FROM A STARTUP DISK ALTHOUGH I FIX THE BOOT ORDER TO START FROM THE FLOPPY
I HAVE RELOADED THE DEFAULT SETTINGS AND HAVE ALSO TAKEN THE CMOS BATTERY OUT OVERNITE RARELY I MAY BE ABLE TO LOAD XP AND USE IT BUT WHEN I TURN THE MACHINE OFF FOR ANY EXTENDED AMOUNT OF TIME WHEN I RESTART IT ONE OR ANOTHER OF THE FILES WILL BE MISSING OR CORRUPT IVE USED THIS OS DISK ON ALL MY PC'S AND HAVE NOT HAD A PROBLEM WITH THEM
I TRIED CHANGING THE JUMPER SETTINGS ON THE HD TO NA AVAIL AND WHEN I TRIED ANOTHER HD WITH XP ON IT I GET THE MESSAGE OS NOT FOUND ANY SUGGESTIONS
  • PHAROH Feb 19, 2008
    I TRIED THIS BUT TO NO AVAIL
DID you replace the hard drive as well???
or is it the original HD.
IN intersests of protecting thier own assets(anti piracy)---Microsoft stamps an encoded "Product ID"
on the hard drive to which THEIR software(all you get is a "Right to USE) is installed..
Even if you have the original setup disks-- it most likely does NOT stamp this code(P ID) on ANY hardrive. WHY??
IT was all too easy (for example) for someone to use their 95/98/me setup disk and install it on any number of PCs-- regardless of brands. Hence the need to implement anti piracy protection.
However there ARE hard drive imaging programs that will COPY bit 4 bit your original hard drive data to a new hard drive --- including the encoded P ID. (some are legal--you may have VALID reasons for replacing your hard drive..Some are NOT.. --some people insist on piracy. and thus driving up the cost of ALREADY over priced inefficient software...
My sugestion--- try linux. Iv e been usuing it for 8 years and will NEVER return to MS
linux is faster safer AND yes smarter then anything ever engineered by microsoft...
Linux comes in many "brand names"often called "distribution or distros" It is NOT owned by any single company-- the inventor licensed it under the General public licenses. or GPL.
YOU and I have the rights and privelige to USE COPY Modify(make it BETTER) and even redistubite it.. Provided that we follow the same/similiar GPL.
Be forwarned ..because it is its own operating system You may not be able to use your favorite Microsoft programs and any LOVER of microsoft will strongly discourage you..
FYI using crossplatform software included I have installed my own legal copy of MS office 97--the last ms product i ever bought. I have also had luck installing some games and other software like quicken. But I only did this for the purpose of testing claims made by linux users. Personally I would much rather use any of the hundereds of office suites, financial programs, educational programs etc provided by linux. A thourough ditribution may span as many as 5 dvds (20gb) But most people are comfortable with a single or double cd installation.
Check out http://distrowatch.com/
for a list of popular distributions
or check out my favorite: http://www.pclinuxos.com/
Posted on Oct 21, 2008
    Problem Solver:
  • 10 Answers
This problem came from cpu overheating .u have to replace cooler fan or also came from harddisk cable.
Posted on Feb 17, 2008
Emachines Imperial GV 20030812 Motherboard manual
THE MOST EASY WAY TO CLEAR CMOS JUST REMOVE CMOS-
BATTERY FOR 10-20 SECONDS.IT LOOK LIKE A WATCH-BATTERY.BE CAREFULE WITH THE HOOKS.
Dec 03, 2013 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Where to find manual for motherboard 143159 imperial Gv 20030812?
Good luck. Used to be you could get a mobo manual from e4allupgraders.
The Imperial board is made by TriGem
Started out as TriGem Sambo, is now TG Sambo
The Imperial models were Imperial G, Imperial GL, Imperial GV, and Imperial GLVE, if memory serves.
TriGem Imperial GV - 143159 -20030812
http://www.ebay.com/itm/gateway-emachine-mother-board-imperial-gv-20030812-/111025938736?pt=Motherboards&hash=item19d9a96130
Bad photo, but it does have the mouse Zoom In feature.
CMOS jumper and Clear BIOS Password jumper, down by the Front Panel header; is the same as used on the TriGem Imperial GLVE -129504,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07540&lc=en&cc=us&product=83481
Scroll down to Motherboard Layout (Illustration), and Photo; then down to jumper info.
(By the way.........the BIOS chipset is removable, therefore replaceable)
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
This is PANEL in the illustration. Bottom/Right corner. Uses the same Front Panel pinout, as your Imperial GV uses.
8 pins along in a row.
Starting on the LEFT side going towards the Right;
Pins 1, 2, 3, NO pin 4, 5, 6, 7, and 8.
A) Pin 1 is N/C. Not Connected
(May not even be there for all I know)
B) Pins 2 and 3 are for the Power On LED.
Pin 3 is for the Positive wire.
If the PWR LED is dim when the computer is on, switch the wires around.
C) There is NO Pin 4. At least that is what I make, looking at the Front Panel header pinout. Indicate Pin 1 is N/C, and Pin 4 is N/C.
D) Pins 5 and 6 are for the HarDDrive activity LED light.
Pin 5 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
E) Pins 7 and 8 are for the Power On switch.
HOWEVER, since the motherboard photo on HP Support, and Ebay; is as clear as mud; suggest you do this,
Connect your Power On switch to Pins 7 and 8;
OR,
touch across them briefly with a small flat tip screwdriver.
(Power plugged in)
See if that is correct for the Power On switch. What will happen if it isn't? Nothing. Pressing the Power On button just won't turn the computer on; is all.
Turned the Power Supply (Computer) on?
Good. We can assume the rest of the pinout is correct also.
Want to make sure? Easy.
Take an LED bulb (Power On, or HDD), and touch it's two wires to the Power On LED pins, in the Front panel header.
Stays on? Yep. Power On LED pins.
Blinks? Whoops.
Those are the Harddrive activity LED pins.
Just that easy to check it. With using an LED, you won't harm anything even if the pinout is wrong.
Moving on.........
Using the HP Support page, for that TriGem Imperial GLVE motherboard, the Motherboard Layout is the same as the Imperial GV.
(So is photo, 'natch)
Referring to the layout, and photo;
A) Power cables:
Two
20-pin ATX main power cable, and 4-pin ATX +12 Volt power cable.
General example of a 20-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Note* Color of power cable connector does NOT matter.
Can be Whitish, Yellowish, Black, Sea Foam Blue, or Lactating Mammary Gland Pink. (Made the last two up)
Goes to the motherboard connector immediately above PCI slot 1.
Note the LOCK on the side of the power cable, and corresponding TAB on the motherboard connector.
General example of 4-pin ATX +12 Volt power cable, and connector on motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Power for the Processor
Looking at the motherboard illustration, look at the Northbridge chip; -> Intel 845GL in the middle.
ATX 12V to the left, is where the 4-pin ATX +12 Volt power cable plugs in.
See the aluminum finned Heatsink, sitting on the Northbridge chip?
The whitish/yellowish 4-socket hole square connector, to the Left.
Moving on............
See where it states Primary IDE to the bottom/right in the illustration? Blue IDE connector?
That is where the Harddrive plugs in.
This is a general example of the connector,
http://en.wikipedia.org/wiki/File:PATA-cable.jpg
Note the Locating Lug on the top/middle. This particular style uses two ribs. Some are just a solid block.
The reason I brought it up, is if there is NO Locating Lug on the connector; let me know in a Comment.
I'll tell you how to use the faint Red stripe, on the side of the flat cable; in order to plug it in correctly.
The optical drive (CD/DVD drive) plugs into Secondary IDE.
You can see where a Floppy Drive plugs in.
Above the Processor (CPU) socket to the Right, is where a computer case fan plugs in. PS_FAN.
To the upper Left, is where the Processor fan plugs in.
CPU_FAN
To the left of the ATX Power Connector, (20-pin ATX main power cable; motherboard connector), is the connector for the small audio cable; coming from the optical drive. (CD/DVD drive)
Optical Drive In.
Right next to the round CMOS battery, is the Front Panel USB header.
-> TWO USB ports connect to this header.
(USB)
A 4-pin Peripheral power cable is used for the Harddrive, and Optical Drive.
Misnomered as 'Molex' power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Note the rounded corners. When plugging the power cable in, these rounded corners always go UP.
[Molex was the first maker of the power cable connector.
The name stuck.
Kind of like calling an adjustable open-end wrench a 'Crescent wrench' ]
The motherboard chipset is an Intel 845GV.
This is what Processors (CPU), and Ram Memory are supported,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
Single-Core processors.
Use a Socket 478 processor socket.
Intel Pentium 4, Celeron, or Celeron D.
(Celeron D is NOT a dual core processor)
400 to 533MegaHertz Front Side Bus processor support.
(400/533MHz FSB)
DDR Sdram ram memory that is either 266MegaHertz, or 333MHz.
(PC2100 and PC2700, respectively)
2GB's of it.
1GB for EACH ram memory slot.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 08, 2013 | eMachines Mb, 143159 Imperial_gv 20030812...
I need display driver plz help me imperial 20030812 display drivers downloads
Hi, you can download the driver here:
http://support.gateway.com/us/en/emac/product/default.aspx?tab=2&modelId=1434
If not the right driver search by model and number.
The driver maybe needs to be unziped before installation.
Hope this will help you.
Mar 30, 2011 | E-Machines EMA IMPERIAL GV (845GV) TG3...
I put W 7 32 bit on imperial GV 20030812 but the resolution of the video is not good, can you help please with of controller?
Hi Good day!!! Try to upgrade your direct X click here http://www.microsoft.com/games/en-US/aboutGFW/pages/directx.aspx if still bad maybe your graphic hardware is not compatible for windows 7, by the way what operating system you use before you install windows 7?
Please reply if you have further problems i will assist you more
Thank you for using FixYa
Please accept if my solution helps you
Nov 10, 2010 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Short but rapid beep code when powering up emachine
The beep code most likely is either video card or memory.
If you have a video card or can borrow one that you know it works try it first, if that doesn't resolve your issue try the memory.
You can take the memory out and have it tested to see if it is defective.
Go to this site and get the Beep Codes, http://www.computerhope.com/beep.htm
I hope this helps.
Good Luck.
Feb 26, 2009 | E-Machines eMachines Desktop PC
Ram selection?
Your motherboard supports max of 2 GB PC 2100 RAM. Hope this helps.
Jan 10, 2009 | E-Machines (40-A06600-D201) for M2000S...
Graphic Card
jumper settings for old graphic needs to be disabled or in the bios settings the on board vga settings need to be disabled this will allow the other new card to be ran as the dominent only video card
jumper settings are tricky
but bios settings are easy just find vga and disable on board video thats it save and boot
Jun 04, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Computers & Internet Logo
1,486 people viewed this question
David Payne
David Payne
