Problem in audio drivers in pc
My head phone does not responds in my pc. But i am able to hear songs in it. Recording is not possible in it.
  • Anonymous Aug 10, 2008
    dosnt make any sound
    Problem Solver:
  • 16 Answers
I'll need more info on this problem: what type of connection do the headphones use? USB? Bluetooth? Classic audio jack?
Solution bellow applies in case of "ordinary" audio jack headphones. Also, check if your headphones have a built-in volume control (usually located on the cable). If that is the case, look for a Microphone On/Off switch if one exists.
Step 1.
Make sure that you've plugged in your headphones in the correct jack. These days, they are usually color-coded so Microphone should go be plugged into a red jack.
Step 2. Run "Volume control ["Start > All Programs > Accessories > Entertainment >Volume Control"] or double click the speaker icon in your System Tray if it's present.
Step 3. In Volume Control, activate "Options > Properties". Find "Microphone" and "Line In" under the "Show the following volume controls:" and activate them. Click ok.
Step 4. Maximize the volume on the "Microphone" and "Line In" slider.
Hope it helps. Rate me. Thanks.
Posted on Feb 18, 2008
Using medion md 96340 with built-in realtek hd audio sound card. in skype video calls the caller can hear very well but called person does not hear at all. skype echo test says-cannot find sound...
Analysis- The call can gear very well - indicates that the speakers / head phones are working fine and the audio drivers are working well
The called person doesnt hear any thing - it indicates that the caller is not able to transmit sound. This can be a microphone related issue. It can also be skype settings issue.
Please answer following questions to analyze the issue better
1. has this ever worked before?
2. Have you tried using the microphone for some other application like recording some audio?
3. Have you tried audio / video calls using some other chat program like gtalk?
4. Are u using any external microphone attached to a head set or is it the laptops inbuilt microphone?
-IAmAraldite
Aug 18, 2011 | Medion MD 96340 Laptop
I am using a logitech headset as well as a creative headset. when i am using it in my home PC the mic in headset is not working. i can hear songs an all from the headset but if i talk in it others cant...
it might be as simple as changing your line in device.
in windows xp go to
Start -> programs -> sounds and audio -> voice
and try and change your recording device to an Logitech device.
Mar 04, 2011 | Computers & Internet
When I use Head phone I can hear but other side cant hear me
Have you checked by doing the following:
1) Go to Control Panel->Sounds and audio devices.
2) Click the Audio tab.
3) Under Sound Recording.
4) Click the Volume button.
5) Adjust the Microphone's volume till you can be heard.
Jan 31, 2011 | Computers & Internet
After reloading window xp iam facing sound problem. when recording karaoke songs. my mic is a few seconds late than head phone. pl help
There is nothing you can really do, sometimes there will will be delays because the computer is having a hard time processing the information and starts to lag.
You can always try re downloading drivers for the audio portion of the computer and seeing if there might be some updates for the mic or the karaoke program you are using.
Nov 04, 2010 | Dell Computers & Internet
How to get recording onto music player on phone
This is a slightly lengthy procedure
First transfer that file to computer and from computer transfer it to the music section in the memory card. It will get registered as a song and thus you can hear it like listening to a song repeatedly.
Then play it in  your music player in your phone and make it repeat.
If you are using an external music player which reads cd then make sure that you write the cd in 'make an audio cd' mode
May 30, 2010 | Samsung SGH-S5230 Cell Phone
Audio not working i can access only my head set .i can hear song only through head set only when i plug out my audio device speaker notworking.no problem for hardware.before i can hear song through only pc...
Double-click the "sound" icon (bottom-right, beside the Windows "clock") to open the "mixer" application.
Be sure that you have not "muted" your external speakers (not the internal PC speaker).
Sep 10, 2009 | Compaq Computers & Internet
Can't hear MIC through HEADPHONES in real time
Hi
i hope that you have the audio drivers installed and working and of course tested with your headphone..best way to do this is to play any song in media player and monitor it on your headphone...
the default settings for most DAW( Digital Audio Workstations) including ACID will be to mute the audio output when recording. This primarily is done to avoid feedbacks during recording. Anyways coming to the point. Since people would like to hear whats been recorded there is a scheme called as direct monitoring. I believe in ACID it is called as "Input Monitoring" and it basically is a small speaker shaped icon that appears next to the Record Arm Button once it is armed. Click on Input Monitoring and make sure its turned ON. Now you can listen while u record.
Hope this helps...contact me if u need further help
Jan 19, 2009 | Compaq Presario Notebook
Audio driver in reason 4 keeps disconecting
Hey, this worked for me!
Edit: Preferences: Page: Audio Then simply change the 'Audio Card Driver' until you can hear reason playing sound.
Jan 10, 2009 | Propellerhead Reason 4.0 - Windows and Mac...
Realtek audio drivers problem
Are you using a "headset" with a microphone attached to it?
Here's something to check:
right click the speaker in your taskbar (bottom right of screen)
Click Adjust Audio Properties..
Click Audio Tab
Look at "Sound Recording" box.. click Volume
Make sure the "select" checkbox is set for the input you're using. (usually Internal MIC or just MIC)
Close window, restart your audio program and you're set to go!
www.techvisitor.com
Nov 21, 2008 | Microsoft Windows XP Professional With...
Sound from my speakers
sounds as if when you connected the recording device may have finnished off the already faulty jack on the PC. Now the PC thinks something is attached but there really isnt. Take it in where it was purchased for repair or replacement.
Nov 12, 2007 | Acer Aspire 5610-4648 Notebook
119 people viewed this question
 Grubhead
Grubhead
