Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch WFF1201 cAN YOU TELL ME HOW TO GET INTO THE FILTER ON THIS WASHING MACHINE, HAVE TAKEN FRONT PLATE OFF, UNSCREWED FILTER CAP BUT CANT SEEM TO GET ANY FURTHER
    Sniper:
  • 74 Answers
At the bottom of the machine on the front, there is a plastic cover (remove by turning the plastic screws a quarter turn anti-clockwise and pull off cover). The filter is behind this cover on the left hand side. It is unscrewed by hand anti-clockwise. Tucked into the plastic cover, you should also find the spanner to adjust the feet on the washing machine. good luck and rate me....
Posted on Feb 17, 2008
Leaking washing machine
the seal round the cap on the filter is possibly damaged solution is new filter housing or complete pump assydo not overtighten they are fairly straight forward to fit hope this helps
May 06, 2014 | Candy Washing Machines
Filter on washing machine
down the bottom on the right hand side is a flap,,, open it down and you will be looking at the front end of the pump,, unscrew the plastic screw type and pull it out.. if you cant pull it out after you have unscrewed it ypou will need to tilt the machine on its back and undo the one screw at the bottom near the pump, slide the whole plimpth right and it will clip off,, now undo the 3 screws around the pump,, and the pump will drop down,, you can unscrew it from its housing then empty the **** whats inside it,, then try unscrewing it once all the **** is out... then put it back together the way it came undone.
Oct 19, 2012 | Bosch Logixx WAS2446 Front Load Washer
Unable to unscrew cap on filter on washing machine
You should be unscrewing anti-clockwise to remove it, if it will not come out, then there is probably somethiung stuck in the filter preventing it from pulling out.
Try moving it from side to side as you are unscrewing and pulling.
Mar 17, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch WFF1201 Washing Machine, wont drain
To access the pump filter, remove lower plastic panel at front of washer, there you will see the filter, unscrew filter cover anti clockwise, remove and clean filter.
You will probably find that whatever was causing the clicking noise is something in the filter.
If you can't see anything in it , then have a look inside the pump housing before you replace filter.
Plz rate my solution .
Thanks.
Jan 26, 2009 | Bosch Axxis WFL 2060 Front Load Washer
I want to drain the pump as per the manual for storage
The best way to drain the pump is to lay the drain hose on the floor, and let the water run out that way, if you tilt the washer back, you will get more water out this way..
This is only suitable if the drain hose comes out of bottom of washer.
Plz rate my solution.
Thanks.
Jan 22, 2009 | Bosch WFMC 3200 Front Load Washer
Water leaking from the pump area
you have to completely remove the filter. twist and shake it until you remove it fully. when removed clean filter thoroughly, also use a long nosed pliers to remove any coins etc from filter aperature. clean the filter regularly
Dec 20, 2008 | Bosch Washing Machines
Bosch Maxx WFL2860 filter leaking
unplug the power before you do something leak first check and then clean filter, replace some hose available in appliance center.
Jan 03, 2008 | Bosch Axxis WFL 2060 Front Load Washer
My machine fuses the whole house
water leaking onto the main motor appliance doctor
Feb 01, 2007 | Bosch WFL 2063 Front Load Washer
Bosch WFF1201
Your problem is most likely the door interlock switch which is shorted. Replace the lock by removing the retainer spring around the door boot from the front, then remove door boot on side where lock is and fold back. Remove the two screws holding the lock (some models just clip off) and disconnect plug....make sure power is disconnected. A burning smell on the lock is usually a sure sign of failure, sometimes no indication at all.
Feb 01, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
699 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
