Question about Kenwood KVT-617DVD Car DVD Player
Kenwood KVT-729 dvd
I am having problems trying to set up the audio settings on my head unit. it does not seem to want to play music through the front speakers.there seems to be so many audio settings i dont know where to start. i hope you can help. hear is my email if you could send me a solution id be very greatfull.thanks Andy. Email: andy.g.82@hotmail.co.uk
  • Andyg82 Mar 06, 2008
    i have tried to do that and had no luck.car had no back speakers so was only getin bass from sub and corous from front.iv swapped the channels about abit as a temp solution but still need to get other channels workin properly to put speakers in back.thanx for your help. if u have any other possible solutions please could u let me no thanx andy.
  • Andyg82 Mar 08, 2008
    yeah im ok with hooking up a amp. the most simple answer to my problem, but 1 i never thought of thanx alot. u have been a great help.
    Champion:
  • 227 Answers
I think you are in dual zone mode. Switch back to single zone mode to see if it help. Goodluck.
Posted on Mar 05, 2008
  • hogan doan
    hogan doan Mar 06, 2008
    Maybe your output chip is fried for those channels. It can happen when you just barely let + and - speakers leads touched(no matter how briefly it happened). You can have it replace for about $150 or just simply add an external amp and run those speakers thru your rca out put for less than that and get much better sound. I assume you know how to hook up and install an amp. Goodluck.
My kenwood kvt 729 dvd monitor is not working. The screen remains white with a thin blue line across the screen when powered up. i have reset the unit and checked all wiring. i have audio but no video.is...
Thanks for posting your question, I am here to help!
If you hear sound but no video chances are the screen is indeed the issue now here is what you can do.
  • Check for a replacement screen and put it in yourself.
  • Take the unit to a factory authorized repair center.
  • if there are A/V outputs you can hook up a external screen (most models have this)
The screen is bad because of the following issues:
The back light witch is the white background you see is firing (not a back light issue)
There is a bar running across the screen meaning the LCD is damaged or defective.
Now in rare cases you can go in and check and see if the Ribbon cable is dislodged from the main board, do not shoot the messenger but it happens. Other then that I feel you need a new lcd screen for this unit based on what you told me.
I apologize in advance if I was not clear on my answer to you.
Thanks for using fixya.com
Sincerely
Ed aka rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 27, 2010 | Kenwood (KVT-729DVD) Car Video Player
I have the kvt 617 I have great audio when listening to radio nut anythig else I only have subs it started doing it when i first got it and then it quit and know it is doing it again any idea?
High end kenwoods have a setting, where you can turn off the internal amp in the head unit, if the sub is the only thing that has an external amp hooked to it, and it is playing, that may be your problem. Also, if one of the speakers hooked directly to the Kenwood has a short, bad voice coil, or contacts touching metal, that can cause the amp in the Kenwood to go into protect, and you will loose sound to all the speakers.
Aug 18, 2009 | Kenwood KVT-617DVD Car DVD Player
Kenwood kvt-719dvd A/V interface was lock
On the front of your unit you have a small pin hole (front right hand side) you will need something small to push this in & it will reset the unit . Once the unit is reset you will need to get into your audio settings and set them back up so that everything sounds correctly.
Apr 10, 2009 | Phase Linear UDV9010 Car DVD Player
Kenwood kvt m700- playing cds
The M700 is purely a monitor so you will not be able to control play, pause, stop, skip, FF or RWD. I use my DVD player as a CD player and have to use the DVD remote to change tracks.
Mar 27, 2009 | Kenwood KVT-M700 Car DVD Player
Kenwood kvt-729
did you go to the settings and set up a memory checkpoint?
Jun 27, 2008 | Kenwood KVT-617DVD Car DVD Player
Kenwood KVT-617DVD
hi kenwood go's off when i put it on to dvd
Jan 16, 2008 | Kenwood KVT-617DVD Car DVD Player
Kenwood kvt m700
The unit is clipping which means it's too loud, lower the volume and should be fine.
Jan 15, 2008 | Kenwood KVT-M700 Car DVD Player
NO audio from front speakers?
Have you tried turning the zone off completely? I had a similar problem, but once I released zone it stopped acting weird
Nov 27, 2007 | Kenwood KVT-719DVD 7 in. Car Monitor
Kenwood KVT-617DVD Car DVD Player Logo
200 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
