Question about Onkyo TX-SR605 Receiver
Usa to uk
I have just purchased the tx605 from usa. When I changed the plug to uk the amp stand by light came on but would not switch off. I bought a 110v transformer to 240v and the same thing is happening. Does it matter that it is a 120v connection on the amp ? Can someone please advise as this cost me a lot of money, what is the solution please help.
  • mickutd Feb 18, 2008
    Thanks for the help, but the one I have doesn't have a voltage selector, I think it's north American. I purchased a trnsformer and changed the fuse inside on the circuit board, and all is good now.
    Thanks again
  • sudarshanarao
    sudarshanarao Oct 11, 2013
    I had the same problem, fueses are intact. Kindly let m e know where did you purchase the transformer? and how much it costs? Appeciate !!!
  • 1,512 Answers
Hi mick
the unit has a voltage selector switch on the rear. Have you selected the 220v option. this will solve your need for a reduction transformer. If you have just gone ahead and fired it up in 110volt settings.... internal damage may have already occurred.
What is the switch set to now? Let me know
Posted on Feb 18, 2008
I have bought a Braun epilator 7 , Braun type:5377 , in USA and have purchased the charger in the UK which is 100-240 v , do I still need to get a voltage converter to be able to use it in the UK ?
If the charger is 100 to 240VAC, it should work. USA use 110 volt so the charger should be OK with 240. The UK charger will probably have a UK 3 pin plug on it. If you use it in the US, you will have to change the plug again or buy an international adaptor which can be adapted to fit most outlets anywhere in the World.
Apr 19, 2015 | Braun Health & Beauty
UK plug in USA
You need a US to UK transformer if there is not a voltage selector switch on the unit. The motor however may not like being connected to a 60Hz electricity supply. Best contact the manufacturer.
Aug 03, 2014 | Husqvarna Freesia 425
Garmin nuvi 1300 Query
Usually they come preloaded with some maps and you purchase additional ones. Check the manual that came with it or the box and that should tell you which ones it has. Generally speaking a basic unit bought in the UK will come with UK & Ireland preloaded, more expensive unit may have UK, Ireland & Europe and the most expensive may have all three plus USA. It's unlikely you will have 'lost' your USA map. The unit should have a 'drop down' menu which allows you to choose which map to load. Hope this helps!
Jul 26, 2010 | Garmin nuvi 1300 Car GPS Receiver
I bought a Bose sounddock from the usa and Adaptor has a two pin plug but the plug is interchangeable. - so... My question is I need to change the 2 pin part of the plug with a 3 pin uk part - where can i...
You can get a 3 pin plug from many shops, but make sure the voltage rating on the back says it will work on 240V if using in britain as America use 115v electriccal system.
May 20, 2010 | Bose SoundDock Digital Music System for...
Hi i have a desktop of compaq 1520il model having bestec smps.During switch on it was gave a loud sound & it was not working. when i extrct it from cpu unit & connect it with 220v ac back light was...
You connected a desktop computer to 220VAC?
I assume then, this is not within the U.S.A.?
It sounds like your power supply may have failed, which blew your home fuse.
Feb 05, 2018 | HP Bestec ATX-1956D 200w HP Part No...
Will kitchen aid purchased in USA work in australia?
The Australian outlets will zap that blender - you need to purchase a 240V to 120V transformer in order to make it work.
Mar 30, 2009 | KitchenAid KSB560WH 5-Speed Blender
Nintendo DS Lite Purchased in the USA
Remove battery clean contacts on battery and game using pencil eraser. Then try charging. Or replace the battery
Dec 26, 2008 | Nintendo DS Lite Console
Can the format be changed from USA to UK
region codes are different from uk to usa and cannot be changed .can still download games from online to console
Dec 09, 2008 | Microsoft Xbox 360 Console
Using phone 2610 bought in USA to use in the UK
Hi. The 2610 is a tri band phone so it'll work worldwide. You may need to unlock the phone however. Have a look here if you do need to unlock the phone
Nov 25, 2008 | Nokia 2610 Cellular Phone
Converrt USA electronic to european electronics
I have the same mixer and I moved from the States to the UK.  I just bought a really good power step-down converter (has to be step-down rather than a standard adapter, and watch the wattage of the adapter).  It worked fine.
Jan 15, 2008 | KitchenAid KSM50PR Professional Series...
Onkyo TX-SR605 Receiver Logo
188 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
