Problem with turning the tv on.
When you turn the tv on by either remote or on the tv it blinks green for about a minute or so then goes off. On its own it starts blinking agan for another minute or so then goes off and stays off. You press the remote and the tv comes on.
Is there a fix for this?
If we live with it will it cause bigger problems?
  • 3 more comments
  • Sweetwood Feb 17, 2008
    The blinks are on the ctr panel.
    After the first sequence of blinks on the ctr panel the same blinking on the ctr panel begins again without any intervention on my part. When the ctr panel finally stops blinking and goes of is when I can turn the tv on and get a picture.
    Mitsubishi Medallion 1080 60" rear projection.
    No I did not disconnect from the power. I will try that now.
    Maklean, per your request my tv is a Mitsubishi Medallion 1080 60 inch rear projection
  • Sweetwood Feb 23, 2008
    The other components on my tv are a surround sound and dvd as well as the cable box and they all seem to work properly.
    I honestly do not know how to determine if my power is clean to the unit.
    Genius:
  • 3,587 Answers
Ok..I hate to dispell all this good advice. is your power clean to this unit?
Posted on Feb 20, 2008
  • Patrick Michaels
    Patrick Michaels Feb 23, 2008
    plug in a 100 watt bulb..and if it stays steady, then you have clean power..if it appears to pulse or vary more than usual(don't look at it more than 30 seconds at a time)
    From what you are relating, your power supply is suspect..can you run the power from another outlet, say across the room, with a 20 foot or better extension cord?
    Genius:
  • 1,665 Answers
Please give me mfg and model number for further information
(The bigger problem suposed to be continuous shut off)
You turn on your TV and 5-10 seconds later, the display is shaking or vibrating for a second or so. It used to only occur when first turned on, but now, the problem occurs 3 times in 30 seconds. Of course, many variations on this general theme are possible.
Some possibilities:
  1. External interference - did you change anything or move your A/V setup recently? Do you have a computer monitor nearby?
  2. Defective circuitry in TV - power supply regulation, deflection, or bad internal connections are possible.
  3. Defective video cable (unlikely) - wiggle the cables to be see if you can induce the problem.
  4. Loose trim magnets of other magnetic components on or near deflection yoke. This is somewhat rare but if the adhesive comes apart, the magnetic fields from the deflection current can cause the parts to vibrate which will result in a jitter or movement of the picture. There may even be audible crackling or snapping sounds associated with this vibration.
Note that many of the sources of electromagnetic interference that are problems with computer monitors like transformers and power lines will not cause noticeable shaking, wiggling, or jiggling on a TV because the power line and vertical scan are at almost exactly the same frequency and any such movement would be very slow.
Posted on Feb 17, 2008
    Genius:
  • 3,422 Answers
Here are few trouble shooting steps you can try:
ONE: Disconnect the power cord for 4 hours. Then when you power it back up the internal soft codes will automatically reset to factory defaults.
TWO: The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
There are several circuits in this model that could do this. the most common are the power supply and the convergence. The only solution will be to get it repaired.
Goodluck...
  • Priya darshan Feb 23, 2008
    Hi again,
    I have already given you the 2 troubleshooting steps.
    The problem is with the power supply and the other convergence as i told you and the only solution is to get it repaired there is no home remedy to fix this problem.
    Main support number: 800-332-2119
    Support FAX: 714) 229-3854
    Email support: CustomerCare@meus.mea.com
  • 770 Answers
When you say it blinks in the screen or in the ctrl panel?? and then when you say it starts on its own are you speaking of the green again on the screen or on the buttons if on the buttons how many blinks r you getting before a pause?
    President:
  • 1,944 Answers
Did you try disconnecting it from the power for a few hours? This should reset the TV.
  • 19,396 Answers
Which is tv brand and model?
Sony Bravia KLV-40X250A power indicator blinks once but screen is black
um u should turn your tv off for like 10 minutes , i think yourr tv is a internet tv so let it cool sometimes sony internet tvs freeze with black screen so try it out.
good luck :)
Aug 06, 2012 | Televison & Video
TV turn on late
It is a problem in the power supply of the set and when it blinks red (fails) count the blinks to see if they are in a specific sequence (7 blinks, pause etc.)
May 26, 2012 | Sony KV-XR34M61 TV
TV is slow to start up. Green light blinks for a long time.
take it to mechanic,because it not repair by a common man at home..
Jan 04, 2018 | Toymax Magnavox 37MF231D 37 in. LCD TV
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
When the tv is turned on with the remote control,the red sensor light turns into green and blinks 10 times and the tv comes on, but it goes off immediately.As it turns off ,the sensor light turns into red...
Hi, my name is John. Welcome to FixYa. You have a problem in the D board. I will post what you need to check here, such as the transistors, capacitors etc. thanks for choosing FixYa....John
Nov 30, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Turn on tv...green lamp blinks several times.lights up but no picture...press any remote button timer in green blinks...tv turns off and goes to standby
The tv "LAMP"LED light indication flashes or stay lit?The tv projection lamp been in this tv like 1/2 or 2 years?Tv been on and used like 4 or 5 hours a day?Yes,than the tv projection lamp life are over.Require a new tv projection lamp.
Nov 17, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
