What is 'd Maximum PhysicalMemory 4 WinXP? How can i speed up 3DMAX Rendering?
Im workin with a DELL 690 Precision Workstation w/4GB DDR2 and 512MB PCIe video card, HDD 250x2 sata..... using XP platform i already used the 3GB switch Physical Address Extension.. What is d maximun DDR2 i can use w/XP? how can i speed up my 3DMaxrendering? what are d correct Processor Settings from d BIOS 2speed me up???
Pls. help me out guyz....
  • arnoldsilao Feb 18, 2008
    tnx hermit... as far as i knw speed comes up with teamwork betwn hardwares & softwares... XP allows 4GB max physical memory rite?i already hav 4GD DDR2 installed. with external PCIe 512MB videocrd.... 3GB PAE swith is already set....
    anyway, tnx 4 helping out....
  • Donald Roberts May 11, 2010
    ok first are you trying to over clock this system..?
Max speed depends on your M/board, dear. If the slots are empty, double what you have for a start. WIn XP doesn't care. You can go past 1 Gig.
Check Bios and open up you AGP or PCI apature to maximum allowed.
Also set your shared memory for VGA to 128 MB or more.
For your processor, be careful. Factory settings come with processor settings preset. Check BIOS first, see what it's set at and compare with listed processor speed for your machine. If they match, leave them alone; work on RAM.
Posted on Feb 18, 2008
Dell 690 powers off randomly yet frequently
This problem is common when hardware parts temperature raises over a certain point, and happens for safety reasons.
The temperature problems always come from insufficient cooling, stuck coolers, dust or missing thermal paste on hardware pieces.
You can try opening the case and cleaning the pc using a vaccum cleaner.
Hope it helps.
Jul 23, 2014 | Dell Precision Workstation 690 - 750W...
Remove front panel from dell precision 690
Hello
Usually, side casing must be removed before pulling the front panel out.
If you don't notice any screws, there are only clips, but take care when prying it off as there are some wires that lead to the front panet at the power button, leds, etc.
Hope it helps
Dec 06, 2013 | Dell Precision Workstation 690 - 750W...
My Dell Precision Workstation 690 can not boot from the Disk
try this clean it whit a brush in the tracks never ower .clean the CD-WRITER/PLAYER with caned air.
Apr 08, 2013 | Dell Precision Workstation 690 -1KW Dual...
Dell precision 690 cd stuck in cd drive will not open
Take a paper clip and straighten it out. Look for a pin hole on the CD tray and insert the clip to manually open the drive.
Dec 26, 2012 | Dell Precision Workstation 690 - 750W...
When looking into setup, dell precision 690 not showing secondary processor
using my noggin i would say bios does not support the processor you are trying to use, and you will have to change the bios.
link below has useful info bios chip compatibility and so on.
http://www.tomshardware.com/forum/261984-28-upgrade-dell-precision
Sep 17, 2012 | Dell Precision Workstation 690 -1KW Dual...
I cant get my Dell Precision 690 to recognise a hard drive
Double check the bois to ensure you have all the Sata ports turned on. I have found in some Dell computers the only ports turned on are the ones in use when shipped from the factory.
Feb 01, 2012 | Dell Precision Workstation 690 - 750W...
I am usind Branded Dell Precision 690 Desktop Machine, i have already windows xp installed in it, but i want to install windows 2003 Server in it, but its creating a lots of issues to me to install server...
Before installing a Windoze server (no matter what flavour) you always need to verify the compatibility (drivers) with the machine's hardware... A Windoze XP driver will rarely work for a server environment... Micro$oft built all servers version to run in server machine type... further more you also need to verify softwar compatibility as well... as not all workstation software is compatible with server environments... and your machine advertises that it is a WORKSTATION NOT A SERVER...
Cheers!
Jul 28, 2011 | Dell Precision Workstation 690 - 750W...
I want to add memory up to 4GB. I have 2 x 1 GBs modules. can I add 2 x 2 GB's and remove the 2 x1 GBs? Also willing to move to Windows 7 64bit in order to move above the 4GB limit. Could I then mix the...
The memory specification for your workstation is here:
http://www.crucial.com/store/listparts.aspx?model=Precision%20Workstation%20T3400
You can remove the 1GB modules and replace with 2*2GB modules to give 4GB and you are correct in that you will need to use a 64-bit operating system to fully utilise 4GB or more.
Hope this helps,
Please rate my answer,
Chris
Mar 09, 2011 | Dell Precision T3400 375W 32bit Computer...
Dell precision 670. Adding 8 gb total memory. Using Kingston KX1563-NAB; DDR2 2gb 2Rx4 PC3200 EEC, registered. Accepts 4 gb in dimms 1 and 2 (2 gb modules) and boots fine. Adding 4 more gb in dimms 3...
glenn_mullin
From what I can tell the Dell Precision Workstation 670 does support over 4GB of RAM. However when you have over 4GB of RAM installed in the system you have to have the Memory Cooling Shroud connected to keep the memory cool. Also this is only shipped out when the system is ordered with over 4GB of RAM originally. If you do not have this part you can order it from Dell buy calling 877-671-3355.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jan 27, 2011 | Dell Precision Workstation 670 PC Desktop
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
