Daewoo DVN-14F6N 13" TV Logo
Posted on Feb 17, 2008
Need help changing from antenna to cable without a remote
I have cable attached to the TV. But, I lost my remote so I cannot change the TV setting from "antenna" to "cable." There is no menu selection on the TV itself. Is there any way to do this?
THANKS!
  • eddy32480 Apr 01, 2008
    way to do this?
    THANKS!
  • kelgal Sep 17, 2008
    The TV is stuck on cable between channels like 53 to 98, I can not change it from cable to antenna. I have tried several universal remotes, but they wont work with the settings. Also, the vcr will play a tape, I hear the sound but the picture his complete static.
A
Anonymous
Have cable attached to the TV. But, I lost my remote so I cannot change the TV setting from "antenna" to "cable." There is no menu selection on the TV itself. Is there any way to do this?
1 Related Answer
Anonymous
  • 105 Answers
  • Posted on Jun 23, 2008
SOURCE: Cable to Antenna Issues
You would need to purchase a universal remote, and once you program the universal you would be able to change from cable to antenna or vice versa.
Although there is a slim chance that in the setup screens on your TV (if you can access them by pushing a button on the tv) would have a selection where you could change the 'input' that is selected. If that is not an option, then it is definitely time for a universal remote.
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
1helpful
Problems setting up new Panasonic LED-LCD TV
the TV may require an special antenna for the unit or the unit is set for cable operation
TV units have buttons on the side or near the side where initial settings can be obtained without the remote
remove the antenna cable and see if that indicates an aerial problem If you go to some shops they have a geek on hand that can show you how to fix on a shop demo unit and what you will need
3answers
I pressed the menu button on my remote and went to channels then I went to antenna scan and lost all my channels how do I rectify this problem?
just go to menu and choose turbo/maunal search or go to channels and press right arrow key on your remote it will revert back to its previous settings
Sylvania television - no sound / lost digital signal
change antenna input to on air or antenna
Have cable tv and wanting to tape a certain channel
I would suggest that you disconnect the VCR from any signal source. UNPLUG the VCR from the power source [a/c] for at least one hour, more if possible. Before you are ready to plug the machine into a/c attach an antenna to the antenna INPUT, the VCR output goes to input of tv. [ DON'T attach cable box, or any such machine to the input of VCR.] Plug vcr into outlet and turn ON. Place TV-VCR switch on TV. [no remote control??] Change the channel MANUALLY, one channel at a time. If you see tv stations as you change the channel [KEEP changing until you have reached the " end of the line " of broadcast channels.] then you are good.Connecting the vcr to a cable box[ANY KIND!] you can only RECORD through the vcr what you watch on cable.
1helpful
Lost the remote
Without the Panasonic remote you can not get to those features to program these sets. I have included a link to purchase a replacement remote control. They aren't expensive and much easier to use than a universal remote. Please take a moment to rate my answer. Thanks...
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=pvdf2004&uuid=12592148630250
Cable/antenna
To change between cable and antenna on your TV,
Press Home to display the "XMB" menu.
pick "settings" on the menu
then pick "channel" on the next menu
under channel settings, select "on" for cable and "off" for antenna TV.
Your user manual is available for download and option printing at the following link :
http://129.33.22.12/release/KDL40XBR4.pdf
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
