Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Setting security fetures
Where can i find setup imformation so i can change my security settings to stop out siders using my connection...any help at all...thanks
    Novelist:
  • 142 Answers
Hi chelsea
Solution: WIN XP
goto start>>
click run
type cmd
type ipconfig
check what is ur default gateway
then goto internet explorer
type the default gateway in address bar
YOUR belkin router homepage will come up
If it asks you for any username and password
U will have to contact belkin to get that...
after entering the username and password
u will be able to check the configuration setings
find the firewall settings on the router ( if ur router comes up with inbuilt firewall )and change it to "high"
It could help
Other wise keep on changing the username and password for the router
Posted on Feb 18, 2008
Cannot connect wireless on laptop
change the settings of your router if your laptop is using wpa change the security setting wireless connection of your router to wpa... their are many categories of security settings ex. wpa, wpa2, radius, wep, etch.... first configure thE WPA OF YOUR LOPTOP.. HERE IS THE LINK THAT WILL HELP YOU TO CONFIGURE THE WPA http://compnetworking.about.com/cs/winxpnetworking/ht/wpainwindowsxp.htm SECOND IS TO SETUP YOUR ROUTER CHOOSE WPA, OR WPA2
May 01, 2011 | NetGear DG834G Router
Cannot connect wireless works fine wired
change the settings of your router if your laptop is using wpa change the security setting wireless connection of your router to wpa... their are many categories of security settings ex. wpa, wpa2, radius, wep, etch.... first configure thE WPA OF YOUR LOPTOP.. HERE IS THE LINK THAT WILL HELP YOU TO CONFIGURE THE WPAhttp://compnetworking.about.com/cs/winxpnetworking/ht/wpainwindowsxp.htm SECOND IS TO SETUP YOUR ROUTER CHOOSE WPA, OR WPA2
I cannot set-up my yahoo mail on N900
Pop Email account setup steps for Nokia N900
  1. Click on the "New Account" and start the 'Account Setup Wizard' by tapping 'Next'.
  2. Select your country/region and service provider or just select 'others' and name the Account.
  3. On the 'Account setup: User details' screen, provide Name, Username, Password and Email address and tap 'Next'.
  4. On the 'Account setup: Incoming Details' screen, select Account type to 'pop3?, provide pop incoming server details, keep the 'secure authentication' option unchecked, and also keep 'Secure connection' to none(of course if you don't want to use secure connection) and tap 'Next'.
  5. On the 'Account setup: Outgoing details', provide outgoing smtp server address, select the 'Secure authentication' to 'Login' option, 'Secure connection' to none and tap 'Next'.
  6. Now you are on 'Account setup: Complete screen', tap the 'Advanced Settings' option and change the default port 25 to whatever port your server requires. Most email servers these days do not use default 25 port, rather 26 but you need to confirm this at your hosting server panel.
  7. Now tap 'Finish' and you are done.
Just send a test email to yourself and if you have setup everything correctly, message will successfully be sent and received.
Hope that helps!
THANKS FOR USING FIXYA
Feb 28, 2011 | Nokia N900 Smartphone
I need to lock the signal in my computer so people will stop using it in my building
You can change or setup a password for your router so that other people cant connect or use your internet connection. For you to setup your own password you need to access the router settings page and for you to access that you need to type 192.168.1.1 to he address bar of your browser and it will ask you for a username and password. The default username is "leave it blank" and the default password is admin. If you want to personalize the password of your wireless connection go to the Wireless Settings Page. Set the Security Type to WEP, WPA or WPA2 and put a personalize Network Key or Passphrase. Network Key serves as a password on the network so that the connection is secured.
Rate me if this helps so that i can help other people like you
Thanks for using Fixya
Jan 28, 2011 | Linksys Wireless-G Broadband Router
Wireless G Plus MIMO (F5D9230-4) Router (1010835): need to set up security to stop intrusion. do not...
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
May 17, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Recently changed to new computer connected to Sg 300 now internet connection does not work
There has been a change in the “Operating Systems.” After the installing of the new software configurations in the system was change.
“The (SG) Firewall, is identifying the Internet Connection as being a “Security Risk,” this is why is being blocked!”
The Security Setting has to be changed. The best solution is to restore the settings back to “default” settings, now that the changes have been made.
To Start, go to the “Control Panel,” you want to open the “Internet Options” window.
Check the (Home Page), if your default search engine was changed, you can type it in example: (“Google”), click “Apply,” after each change.
Note: If you are not sure of the Home Page name, click on the “Default” block.
Next, you want to change the Security Settings; to make this a safe and easy process; rule of (“Thumb”) cannot go wrong with “Default” settings, click on each security zone, and click the “Reset all zones to default level.”To setup the Internet Connection: Click on the “Connections” block, click the “Setup” button, follow all the instruction carefully. Important! Always click apply, ok, and restart the computer after making changes to the computer. “Did this solution help?”
Jan 27, 2010 | SnapGear SG300 (990126) Firewall
I want to setup a wireless connection
To set up wireless connection, first you will need to access the router set up. yhen change the wireless settings on the computer.
Secure the wireless network and then try to connect to the wireless network ?
Click Here for step by step info
Nov 22, 2009 | NetGear WGR614 Router
Stopping people from outside my house connecting through my wi fi to my internet
You have a wireless network and you want to stop people from accessing your wireless network. For this you will need to secure your wireless network. You will need to enable the security on the wireless network.
You can do it by accessing the router set up interface.
Make sure that when you will change the wireless settings on the router, your computer will be connected to the router with the cable.
Click Here for step by step solution
Nov 12, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Changing the coordinates of the autostar for meade etx 125
What are you using as a reference for "LST time"? I assume you're aware
that stands for "Local Sidereal Time", and not Local Standard Time; some
folks have confused the two. Do you have another method to calculate
Sidereal time for your location?
When you set Date and Time in the Setup menu, you need to use the time
from the "clock on the wall" without any mental adjustments for Daylight
Saving or Time Zone; those settings are made elsewhere. From your
description of the problem, it sounds like you have a time offset,
especially if your Site location values are fairly accurate.
Whether you use Zip Code or City sometimes depends on where you live
with respect to a particular city. If you live several miles from the
nearest city, Zip Code may be best .
Dec 12, 2008 | Meade ETX-125PE (500 x 127mm) Telescope
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
212 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
