Question about Refrigerators
My fridge dont work
I have an electrolux fridge/freezer and there is a red light on the top for the temp and the freezer is working but the fridge is not?
what shall i do
  • Gary Davd
    Gary Davd May 11, 2010
    You need to post your model number here so we know what we are dealing with
Check to see if the fan is working . The fan sends cool air from the freezer to the fridge.Check repairclinic.com also they would walk you through it .
Posted on Feb 22, 2008
Electrolux door alarm Won't stop. We open door to turn off alarm. Temp seems right but slight condensation at the very top of the fridge. Need to at least disable alarm until I can get a repair.
Check the back wall of the freezer, I would suspect the beginnings of or a full-on defrost failure... If there is frost on the back wall of the freezer it means the evaporator is blocked, disallowing airflow to the fridge compartment... Electrolux Refrigerator Defrost Thermostat 216731001 . If there is no blockage, but temps are still not cold enough, your Frigidaire may be leaking refrigerant...
Jul 03, 2016 | Electrolux ICON Professional E32AR75JPS...
Rm4400 freezer working fridge not
move temp sensor that's mounted in coils down or let hang if same replace sensor
Jan 19, 2014 | Dometic Refrigerators
Kenmore 795 freezer on top. Freezer working, temp lights on in fridge, but fridge not cooling and lamp out as well.
If the freezer is located above the fridge, the air from the freezer drops into the fridge to create the cooling in the fridge. So what I would look for is a blocked vent from the freezer to the fridge, which is usually located on the top and or back of the fridge inside of cores. You can get a frost or ice build up in there and block the air flow to the fridge, that is usuall the problem. I would also heck the dial for temp control in the fridge, I know my kids have changed it before on me.
Sep 07, 2012 | Kenmore Refrigerators
Fridge not getting cold
With a top freezer the cold air comes from the freezer down into the fridge. It uses a fan to blow the air down. It's possible that the fan is burned out. Does the fan come on if you turn the temp. to the fridge to colder? If not, then that may be the problem. The fix is not too easy, but can be done by an experienced do-it-yourselfer.
Mar 11, 2012 | Electrolux ER7926B Bottom Freezer...
Zanussi ZX97 temp light bleeping freezer has defrosted
It may be low on gas.There is a p.c.b. control on the top panel which has a cable going to 2 sensors to control the unit temp.If they are faulty here are the Electrolux part nos.
P.C.B. 2147187088 $93.
Sensors. $37.
Hope this helped.
May 17, 2010 | Zanussi ZX97 / 5 Bottom Freezer...
I have a westing house BJ414 and dont seen to be getting much air flow into the fridge section? the fan is runnong aand the freezer is reaching temp?
maybe too much food in top part of fridge. Cold air comes from top of fridge near light. Can you feel cold air coming from there? Put a fridge thermometer in the top section-they only cost a few $ from kmart etc -the temp should be 2-4 deg C. My thermostat is turned to warmest setting and its still in that range. Does fridge cycle on and off every 1/2hr or so? If it runs nonstop, it may be the freezer section is all frosted up, probably coz the defrost timer has stopped working or else the defrost element has burned out. Both can be easily replaced by you.
Apr 23, 2010 | Westinghouse Refrigerators
Fridgidaire Mini Fridge not cooling
pulled off back panel on inside of freezer, to find it was a solid block of ice. thawed, and plugged back in... working properly
Feb 08, 2010 | Electrolux Refrigerators
Freezer not freezing food properly.
I have a baumatic st steel fridge freezer (big one) oldish model I think but dont know any model no's. In the past day the red light keeps coming on and flashing which means its not getting up to temp I think. The Fridge seems ok and the top drawerin freezer is the worst, but others seem ok at the moment but conerned as to why this is happening as never happ before, has anyone any ideas please??
Jul 04, 2009 | Freezers
Red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Aug 27, 2008 | Refrigerators
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
