Question about Dell Inspiron 2200 Notebook
Dell Inspiron 2200 loose DC power pin connector
Dell Inspiron 2200 Laptop DC power pin connector loose, causing screen to go bright & dim. Would like to know if possible to change/repair connecter without going to repair shop? Live in UK
  • blackhand Feb 18, 2008
    Many thanks st2malo, was hoping I might be able to attempt job myself. Blackhand
  • Anonymous Jan 17, 2009
    My dc jack is loose is it easy to replace yourself?
  • 3 Answers
It seems the Dell Inspiron 2200 DC in power jack connector coming loose is a common problem with this laptop, unfortunately. If you want to try it yourself, grab a copy of the service manual which will guide you through the process of taking it apart (as well as putting it back together). Once you have the motherboard out, check the solder points on the bottom of the circuit board. On one I worked on, there was practically no solder left, but the jack itself was solid. Be careful with the soldering process, because there's an RV1 component too close to the power jack's pins and you can easily dislodge it if your soldering iron / tool isn't precise enough. If things go well, and the solder goes where it's supposed to, that should fix it.
Some people replace the jack entirely - a call you'll have to make yourself.
Posted on Mar 13, 2014
    Problem Solver:
  • 5 Answers
Hi, the power jack must be removed by a strip out and de solder of jack and a new one fitted. I was lucky a guy took £30 for the job.
Posted on Feb 17, 2008
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
Not that hard to do the repairs yourself.....The pin assembly is usually available on the web for $ 10-$20. Take your time taking the unit apart, take notes on the dis-assembly so when you go to re-assemble the unit you know what goes where. Once you get it fixed you might think about getting a cable retention device to keep the problem from re-occurring.
Posted on Mar 12, 2009
Won't charge, purchased new battery and new AC adapter, still does not charge. AC charges other Dell I have so must be in charging circuit or connector. How do I disassembly computer to voltage getting to...
You are right, most of the situations like this end up that the charging connector fixed / soldered to the motherboard get damaged because of shaking the connector when ever we connect and disconnect it .
Mar 06, 2011 | Dell Inspiron 2600 Notebook
My dell 640m short curcuit.I check uise multimeter at the battery prob +- ( 2 side have a reading).Laptop can't on....tq
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 22, 2010 | Dell Inspiron 640m Notebook
I have a Dell inspiron 1721. The screen is dim ... when I try to adjust the brightness it won't adjust any brighter than it already is and makes some type of humming noise at the settings in the middle. ...
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Sep 06, 2010 | Dell Inspiron 1721 Notebook
Repairing power connector inspiron 2200
The connector is special to Dell, and not generally available. You may need to purchase a new power supply. The connector has 3 concentric terminals, and one is used to 'ID' the power supply as genuine DELL. A plain DC connector can be used, but the batterys will not charge.
Mar 10, 2010 | Dell (8N816) Motherboard
Dell inspirion 2200 notebook screen really dim cant see hooked up another monitor and it works . how can i fix?
If your screen is dim but still displays everything then please check if the screen's brightness has not been accidentally reduced. If that is okay, then you have a damaged screen inverter and it needs to be changed. If the screen does not display at all, then you may have to change your screen.
All the best.
Jan 19, 2010 | Dell Inspiron 2200 Notebook
No brightness to the screen background is dark.
Take the laptop into a darkened room.
Does the correct image show, but very dim ?
If so, then the "back-light" in the LCD has failed.
It's about a $20 part, and it will take a qualified technician less than one hour ($60?) to disassemble the laptop, replace the part, reassemble, and then test the laptop.
Nov 19, 2009 | Dell Inspiron 2200 Notebook
I got an Insprion 2200. It turns on, but once I move it the power cuts out. Not sure if it's the ac jack on the back of my laptop or another internal problem. Even with the battery in there left to charge,...
The DC connect on the system board may be loose. Take hold of it at the connection and wiggle it slightly. If it moves alot, the DC connector on the board is loose.
If not, take your battery out and power up the unit and see it stays on. If it does then it is the battery.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 18, 2009 | Dell Inspiron 2200 Notebook
Dell Inspiron 1505; Battery does not charge; DC jack is loose..
You have either a faulty connector plug on the power adapter which connects into the laptop or the loose power input socket on the laptop is faulty. This is because you need to press the connector upwards to make electrical contact.
Test the connectot plug on the power adapter with a multi-meter, wriggle the connector to see if your get the voltage to fluctuate, if it does not then the connector is OK anf the fault is in the laptop power input socket.
If the fault is in the power adapter plug or the laptop's power input socket, this can be repaired, a techo would have no trouble in repairing these faults.
May 22, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron Laptop powers off by itself.
This could be a couple of issues. One, the computer could be over heating and shutting down. Ask her if her laptop was warm and if the fan was constantly running. The second possiblity is the cord that plugs into the laptop has become loose and once wiggled will cause it to turn off because the battery doesn't hold a charge. Have her put the laptop on the table and with the computer running wiggle the cable. If it shuts down its a bad connector. In this case find someone with mad soldering skills and re-solder the connector on the motherboard.
Armymason
If this sounds like a good solution a high score is appreciated.
Apr 01, 2009 | Dell Inspiron 2200 Notebook
Monitor comes on very dim, I can't see
click your "fn" key and then press the brightness key on the keyboard (it will be a blue or green "sun")
If this does not work, plug an external monitor to the laptop, if the screen is good on the monitor, your LCD display panel is shot.
Mar 21, 2009 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 Notebook Logo
1,714 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
