Question about Canon PIXMA MP600 all-In-One InkJet Printer
MP600 / Error Code 5010
Problem EC 5010 appears and blocks every further step.
Tried kind of reset, removing power / PC connection / Ink catridges / printer head and vice versa.
Without effect!
  • 1 more comment
  • lob1223 Oct 17, 2008
    I am having issue on locating white sliding mechanism. Also we where able to located the screw on the back and the front, but after that we are total lost. Is there any way that way have a diagram sent to us as well. When we open the front gray panel we only we only saw the white slider.
    Thank You
  • Anonymous Oct 30, 2008
    I don't know how to fix error code 5010 for my Canon MP600. Do I need to take the cover off?
  • Nuhu Mamman Lafiya
    Nuhu Mamman Lafiya Nov 30, 2013
    I will try. I hope it will work this time round!
  • 117 Answers
It can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 07, 2008
I did have the same eror but i found that the wires had broken from the scanner to the printer
Posted on Mar 19, 2008
Error code 5010 on cANON MP600 ALL IN ON PRINTER
"Issue: ERROR LCD: Error Code 5010
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the <ON/OFF> button again.
3. Wait until the device has completed its cycling process before submitting another job request."
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 16, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp600 pixma; it just started doing this when I tried to print; now I can't seem to be able to do anything with it. I assumed it was due to one of the ink cartridges being out and so I replaced...
1. On the operator panel, press and hold the button for one second. (The display will go blank.)
2. Wait approximately ten seconds and then press the button again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 20, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Error code 5010
Error Code 5010: Canon recommends resetting the machine. Unplug the power cord for 10 seconds. Then press the power button to turn the printer back on. Wait until the device has completed its cycling process before submitting another job request.
Dec 04, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma MP600, error code 5010, what does it mean ? Can not turn the printer on for any other purpose, no scanning, copying or printing.
There are a few things you can try:
  1. Power reset; press and hold the Power button until it the machine starts a diagnostic mode; if this doesn't turn on the machine, unplug it for 10 minutes and upon plugging it back in, see if the error reset itself
  2. Unplug all USB devices (including the printer) and reboot the computer. Once the computer has rebooted, plug in the printer, allow it to install (it should install automatically) and see if the error is corrected. Sometimes there can be a temporary conflict and the only way to solve it is to remove all other USB devices (this can work for external hard drives too).
The overall issue with error code#5010 is a scanner malfuntion. If the problem returns, check the ribbon cable as it runs from your scanner to the main logic board. If all is secure and you still have the problem, the printer may need a new logic board.
Nov 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printer will not print, error code 5010 is
5010 is a scanner error, either worn out scan lamp or sensors. Canon only replaces the entire scan assembly, if you like I can get part number and price.
Jun 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code 5010 and 5C20
on't know this error code, but this info might help
With thanks to a canon tech Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
May 14, 2009 | Canon PIXMA MP610 InkJet Printer
Re: Error Code 5010
it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Mar 07, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Error Code 5010
it's the printer version of a blown engine(as in your car)..got a warranty, I hope.
start with printer driver updates here
Feb 05, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma MP600
Canon Error Codes
L5000,5500,7000,8000: To enter service mode Data Registration, #, Ram Clear is under #8 clear
Faxphone 20 ram clear
Turn off the power switch
Turn off the memory protect switch (located on the bottom of the machine)
Turn the power on
Press function # 2 0 start
Turn the power switch off
Turn on the memory protect switch
Fax L770 fuser gear wears out easily under heavy usage. White gear with 2 sets of teeth.
Inkjet models such as the B160 will hold faxes in memory and refuse to print if excess ink has accumulated on the pad under the cartridge's nose. Remove the cartridge and wipe up excess ink with a cotton swab.
Nov 04, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
10,214 people viewed this question
old marine
old marine
