Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
Refrigerator not cooling
Side by side GE Profile. Not cooling. Light come on on front panel to say
"WARM TEMP". Cooling settings for freezer and refrigerator are set OK.
    Genius:
  • 1,665 Answers
See below:
It's not cool If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
    Next, see if the compressor motor is running
    The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
    If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
http://www.repairclinic.com/0088_4_1.asp#Level1_2
Posted on Feb 17, 2008
  • 104 Answers
Good day, first you set your temperature settings to lower setting, check if your compressor is running you can hear a humming sound. if your compressor is not running try to check relay. if its running, touch the condensers at the back of your refrigerator if its cold their is leak on your system and need to be repaired by qualified technician. thanks
    Genius:
  • 3,422 Answers
Sounds like a relay is chattering on the board. First thing would be to change that circuit board, it controls pretty much the whole unit. Make SURE the clicking is coming from the board and NOT the compressor though! See item 801 b
Click HERE
Goodluck..
  • Priya darshan Feb 17, 2008
    If your freezer is not cooling and you here a click noise then the problem is with the relay as i told before.
    You can give this method a try first :
    Your freezer is probably iced up, blocking airflow to the fridge part.
    Unplug it for 2 days and let it stand open to defrost or take the
    evaporater cove off and defrost it with warm water or a hair dryer.
    Just dont melt any plastic walls/parts. This could be because a door
    was left ajar, or because your defrost system failed if it happens
    again. Good Luck!
  • GE Master
  • 19,396 Answers
There are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually the first to be noticed
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
I have a GE profile side by side and the freezer works fine but there is warm air that is blowing into the fridge part.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi, our ge profile refrigerator is having temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile TFX22PR side by side. Freezer works fine, but Refridge side is not holding cold temp and the door gasket is quite warm to the touch.
heatman101
Sep 02, 2010 | Refrigerators
The freezer is not cooling and refrigerator is not remaining cool
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfgmjfmkxf
Jun 25, 2009 | GE Profile 23.3 Cu. Ft. Counter-Depth...
GE Profile Side by Side is getting too cold on the fridge side.
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Does not stop cooling down
Door edges being warm is caused by what is called mullion heaters that operate to prevent humidity from condensing at these points.
Some refrigerators have an energy saver switch. Turn this switch if you have one to the energy saving position when the humidity is low. Is anything freezing in the refrigerator? If so setting the controls to a little higher setting may solve your problem.
May 03, 2008 | GE Profile¿ Arctica® Energy...
Ge profile Refridge...
check if the outside walls and back are hot to warm,. if not warm posible low level gas, or commpressor not pumping gas around.
Oct 18, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
402 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
