Question about Samsung DVD-VR357
Coping vcr to dvd
Can you watch tv while you copy off vcr to dvd
  • 979 Answers
Depends on the TV/monitor and whether or not you have enough inputs to select your different sources..accordianman
Posted on Feb 19, 2008
Can I transfer a vhs to a dvd with this recorder/player?
if the tab has been removed on the back of the tape cover it
if you are trying to copy orignal some films have a code inprinted on tape so they can not be coped
Nov 28, 2009 | Emerson EWD2204 DVD Player/VCR
Connecting up Digital TV, DVD recorder and VCR
You need to hook the VCR and the DVD recorder to the scart connections on your TV.
VCR to one scart on the TV
DVD recorder to the other scart on your TV
Jan 31, 2008 | Televison & Video
When coping from vhs to dvd i get can not copy do to problems with the disk. i used 3 different disks. could it be the machine?
are you finallising the disk copmpres the vhf format best to cop is to go through you computer using a tv card
Nov 01, 2009 | GoVideo Go Video DVD/VCR Combo
I don't know how to plug it in so that it works. Do I plug it to the tv? or to a vcr?
LOOK FOR COLORED JACKS, YOU SHOULD HAVE A SET OF RED/WHITE/YELLO OUTPUTS FROM THE PLAYER, PLUG THEM INTO THE SAME RED/WHITE/YELLO JACKS ON THE TV, IF YOU DONT HAVE THEM ON THE TV YOU CAN PLUG THEM INTO THE VCR BUT THEN TO WATCH IT YOU WILL HAVR TO CHANGE WHAT INPUT YOU ARE VIEWING ON THE VCR (KEEP HITTING CH DOWN UNTILL YOU SEE LINE 1 ON THE DISPLAY
Jul 10, 2009 | Symphonic RSD200E DVD Player
Connecting TV to DVD / VCR Recorder
Appreciate the direct "Ask Me".
I am assuming that what you intend to do is:
  • record a TV channel/program/show either on VCR or DVD;
  • while at the same time watching another TV channel/program/show directly on the TV.
Yes, but only if you are not using/needing a cable decoder box. To do this, the coaxial cable from your provider would have to be made to supply both the RF/ANT/CABLE IN of the VCR/DVD and the TV. To accomplish this, you would need a 2-way splitter. One input to the splitter, 2 outputs, one each for the DVD/VCR and the TV. The DVD/VCR would have to be connected to the TV using yellow, white & red RCA cables. To watch DVD, VCR and/or what is being recorded on the DVD/VCR, set the TV to Video mode. To watch regular TV, select the channels on the TV.
Good luck and Thank you for using FixYa.
Pls be informed that due to my current rank and rating, even a Helpful wouldbe detrimental to my status. Should this solution not address yourconcern, it would be appreciated if you could just not rate it at all. Cheers.
Dec 29, 2008 | LG RC797T
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
I want to convert a DVD to a VCR tape.
Do you want copy dvd movie on VHS tape?
Use DVD/ VHS Combo Player like shown in below picture...
Oct 27, 2008 | Televison & Video
VHS to DVD recording
Yes, just turn off the tv.
Walt
Apr 08, 2008 | GoVideo VR3845 DVD Recorder/VCR
VCR, DVD, TV Connection
first let me say that a dvd player and a dvd recorder are different. the dvd player can only play dvd while a dvd recorder can both play and record dvd that is said. what i understand from what you write is currently is - out of your tv box into your dvd player then out of your player into your tv........ ok some dvd has two connections. line one and line two if your tv box is in line one then you should plug the rca cable in line two in. then you select line two on the dvd player then plug the other end to your vcr in line out so that is out of your vcr into line two of your dvd player.(some times one of the connection is at the front of your player hidden) if your dvd player only have one connection then you would have to plug out your tv box and replace it with the vcr cable and when you finish coping your vhs tape you plug in back your tv box to your dvd player. hope i could help.......... Tracy
Apr 02, 2008 | Televison & Video
Record vcr to dvd-r
This suggests that you are net setting up the DVD recorder up correctly,
Check- are you connecting to the correct 'INPUT; port?
Check have you select the correct chanell that points to this port.
Carefully go the the book- vey can be very dense to read.
Nov 21, 2007 | Zenith XBR413 DVD Recorder
Samsung DVD-VR357 Logo
Jerry Greenberg
Jerry Greenberg
