Question about Toshiba Satellite A35-S159 Notebook
Lcd has stripes on the right side of screen, where can i get a lcd replacement screen?
  • 58 Answers
You do not have to change the lcd but if you look on google shopping option through different prices: http://www.google.com/products?q=lcd+Satellite+A35-S159+&btnG=Search+Products&hl=en&show=dd
Posted on Feb 18, 2008
5 inch wide blue vertical stripe on lcd
It can be but rarely the main board, most of these sets have either one or two boards that drive the image on the screen, different names like T-con or Y out etc. the right side board could be the problem or a bad connector or ribbon cable for that side of the screen unit.
Several possible cures and none are a snap to find in most cases.
Dec 06, 2012 | Toshiba 46LX177 46 in. LCD HDTV
The right side of the screen sometimes has veritical stripes or goes black and then comes back to full screen after time passes.
There is 1 or 2 flat cables that connect to the main circuit board to the t conn board at the top center back of screen. press these in . This may fix. If not replaced the LCD panel . probably cheaper to replace the tv.
Aug 30, 2011 | Samsung LN52A550 LCD TV
I am getting a blue line, vertical, down the right hand side of the screen. It will fade in and go away. Don't tell me my LCD is going out. I've only had it for a year.
Hope you are still in warranty, a single colored line in an LCD or Plasma is usually a screen fault, the only other possibility would be the LCD control board, however it usually generate large stripes or bad image with half the screen, a single line, 99% is a bad screen. Call Sony, screen replacements are not economical to repair.
Crampy
Nov 29, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
About 2 inch yellow stripe appears on the LCD screen
This typically is a sign of either a problem with the monitor itself, the cable, or the computer.
Fault isolation is key here. If you have access to another monitor, I would suggest connecting that to the computer, or vice versa. That way you can figure out what's broken.
If it's the computer, you might be able to purchase a replacement video card. If it's the monitor - you're out of luck, and likely need to purchase a new one.
Nov 15, 2017 | E-Machines 19" Widescreen Flat Panel TFT...
2" wide Red stripe on right side of LG 42" plasma TV screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size..
Jun 09, 2017 | LG DU-42PY10 42 in. Plasma HDTV
Green vertical stripes down right hand side of screen, no picture
Unfortunately this means that your TV may be damaged. I would suggest talking to a professional or consider replacing your TV depending on the cost of fixing it.
What it means is that the power to that line of LCDs in your screen is 'stuck' and it is generally not user-serviceable.
Jan 23, 2009 | LG 19LG30 19 in. LCD HDTV
Hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
Aug 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Philips 300wn5 green stripe on screen
I have a similar problem, what is the fix?
Mar 23, 2008 | Televison & Video
ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
Toshiba Satellite A35-S159 Notebook Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
