Question about RCA RT2250 System
Power but no sound
I have a rca rt2250 audio video receiver. i would like to just use the receiver to listen to the radio. i have no other components hooked up. i have two speakers hooked up, i got power but no sound. can someone help me to rock and roll
  • Douglas Pfaff
    Douglas Pfaff Aug 11, 2016
    I have same issue help user manual on help need service manual.and can't find it.
  • 107 Answers
Hook up the antenna at the back and try to tune-in to your favorite radio station.
read the description at the back of your rca rt2250, how to connect your antenna.
connect it properly and raise up the antenna, put it where the signal is good.
Posted on Feb 17, 2008
  • 104 Answers
Good day, here is a link to the manual. Hope it helps!
http://support.radioshack.com/support_audio/doc61/61791.pdf. thanks
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
Rca rt2250 no sound
please give us more details, I don't know what reciever you want to use? AM,FM? or some other devices.
but if it's the am,fm reciever well you can find it in your instructions manual how to set it though.
just follow the steps and you will have it..
have a nice tunning
just don't rate me badly^^
ps:
make sure your antenna is connected properly..
Feb 17, 2008 | RCA RT2250 System
Manual for rca rt2250
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=946cc180600e1709d401c351d8b4fee8&modelid=402599&q=RCA+RT2250
Mar 02, 2011 | Audio Players & Recorders
When i plug my wharfdale digital radio in the mains it makes a loud buzzing sound yet works perfectly when using battery power
I assume you are talking about listening on the set's own loudspeaker.
The power supply for the receiver is faulty, it is not producing a nice smooth DC like it should. Is it an external supply? If so try a new one, if not there is a faulty component in the radio power supply.
Feb 02, 2011 | Audio Players & Recorders
My TV has audio (left & right) & video jacks (red,white &yellow) can I connect my Kenwood KR-V5580 to it for stereo sound If so what do I connect it to video 1 or 2, phone,etc
Audio can usually go either way to a TV. In or Out. Why someone would want to hear external audio through a TV's marginal audio electronics and speaker(s) is beyond me, but sometimes that is what they want.
Take the audio from the receiver via whatever unused Tape or Video function connectors you like to the TV's Audio L & R IN. Anything the receiver processes will be audible through the TV as long as you DON'T select that function for listening on the receiver.
Listening to TV-related audio through the receiver and its (presumably better) speakers makes much more sense, but again, the TV's marginally audio capabilites place a serious limitation on sound quality expectations. In your case, stereo is as good as it could be.
If your TV has Audio Out jacks, just run them to any convenient Line Level input (NOT Phono). If your TV has internal audio controls for volume, set it to Fixed so the TV's volume control doesn't affect the sound going out to the Kenwood.
A better TV-related audio solution would be to connect the BEST audio of whatever source you're watching directly from that source to the receiver. Cable, DVD/BD, SAT always have 2-channel analog RCA connectors as well as (unusable on the Kenwood) digital audio outputs.
VIDEO from the Kenwood to the TV:
You describe your TV having Composite (3 -RCA-style cables). The Kenwood is limited to Composite (Lower-quality, single Video RCA-style cable). Check your TV for a single Video In connection and run THAT from the Kenwood's Monitor Out so you can pass other video through the receiver.
In its day this receiver was pretty high-end but to really enjoy modern multichannel audio from video sources you might consider an upgrade to a true multichannel Audio Video Receiver. For one thing it would support digital audio and probably Component and HDMI video. You could still use the Kenwood's amplifiers to drive speakers or as a secondary system.
Apr 29, 2010 | Kenwood KR-V5580
New polk psw110 sub for rca rt2250 reciever
Hi there.
To answer your question;
There is no problem in using both subs at the same time. As a matter of fact you could split your signal in ten and have a sub for each one of them.
You`ll just have to set the subs levels so they match each other and i`d say the more sound to the larger sub.
Just try it at different sound level and you`ll find the correct setting.
Have fun Happy holidays
Dec 29, 2009 | Audio Players & Recorders
I have a DVD player, VCR player, TV all attached to an RCA RT2250 audio/video receiver. All was just fine until 2 days ago when the DVD player would no longer give sound and icons of the speaker system...
It's possibly only needs soldering of the voltage regulators. they are on the main circuit board heat sink (middle of the receiver and can be accessed by the bottom panel.
JohnW
Dec 21, 2008 | RCA RT2250 System
Need diagram to connect Motorola DVR, Panasonic DMR-E recorder, A/V Receiver, and HDTV
Your not going to be able to connect in series (not sure if thats your goal) since your limited by the type of connections you can use. Your receiver is going to have to be switched depeneding on what source you want to listen too. DVR, DVD, etc. HDMI is going to important for your TV connection. Radio Shack has cheap HDMI cables.
So... connect HDMI from DVR to HDTV this will give you sound and picture to TV. Connect DVR optical or coaxial ( RCA if you dont care about surround) to Receiver to give you DVR sound thru Receiver input.
Connect DVD to receiver via optical/coaxial/rca for DVD sound thru receiver (again RCA is not recommended for surround).
Connect Component video to HDTV(or HDMI if TV has second HDMI input) to give you video from DVD.
Connect Yellow video or S-video from DVR to DVD recorder input to allow recording from DVR. Also connect red/white audio to (same) DVD input.
That should cover it.
Apr 09, 2008 | Arris DCT2608
RCA RT2250
Make that 3. There must be some kind of date chip in the thing
Dec 22, 2005 | RCA RT2250 System
Audio and Video cutout
it sounds like you gonna break the unit eventually:) now seriously, when a problem can be handled by activating physical force, it is probobly related to loose conections or wiring. if you wanna fix it yourself, take it apart and start loking for those kind of things.
Dec 16, 2005 | RCA RT2250 System
RCA RT2250 System Logo
375 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
