Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Upgrade ram and maybe processor!
I have a msi 915glm-v mother board micro atx
pentium 4 cpu 2.66 ghz from control panel, system info
think it is a intel i 915G(ddr1) found this on a website.
Wanted to upgrade from 512 ddr pc3200 400mhz ram to a gig, but thought that if it was painless I could upgrade the processor also.
I did not want to have to loose info or reload info on the computer. This is why I did not want to change the motherboard. In addittion did not want to drop lots of money into the pc. Wife doesn't want to replace my desktop, doesnt't want to spend the money. Her laptop works fine, but I like my large sound system and 19" monitor. The system will not play a cd and let me do several other things at the same time. Wired ethernet connection windows xp pro. Do not want to upgrade op system either, very happy with it.
Do you have to change things to upgrade processor, or is it painless?
Please respond to Danbudy@yahoo.com
Thanks, Dan.
  • danbudy Feb 18, 2008
    Ok, I'm ordering ram. THanks, for the tip. I have added your name to buddy's so that I can let you know how it goes. I appreciate the help.
    Dan.
Hey, da,
I would double the RAM first with the same kind, then watch both PC and wife :), what happens. If they both smile, go for the processor but don't jump too high on the MoBo. Check the range on the board for highest speed clock before you buy a processor.
You shouldn't have to reinstall your OS, but back up your important files just in case.
Good luck Dan.
Posted on Feb 18, 2008
Want to upgraded Pentium 4 2.8 GHz to Pentium 4 3.2E GHz
Yes, it will work just fine, as you can see for yourself - on the mb's link is the third processor from the second group (Prescott).
Jun 03, 2010 | MSI PM8M-V Motherboard
why not go with a faster MB and CPU combo?
First to awnser your question yes the Pentuim 3.2 will fit the MB as long as yours is a 800 Mhz Bus speed. And the Board can be configured for the proper clock speed. I would also buy a new CPU fan and heatsink greese b4 you install this CPU. Thee are so many cheap CPU MB Combos out there its almost cheaper to just replace both and get a much faster system.
Jun 03, 2010 | ATI RADEON X1650 Graphic Card
Hello again.I have an old home pc and I want to upgrade the cpu processor without changing motherboard.Wich is my best options?I want to know if I can to upgrade to PENTIUM 4 3.00 GHz.Also I want to put...
If new processor supports your old motherboard then you will upgrade system with your old motherboard.
If its not supported to new mother board then you have to buy new motherboard to upgrade your system.
Thanks.
Happy to help you.
Apr 30, 2010 | Intel CPU
What mother board fit the Sony VAIO VGX-XL2
A micro ATX or mATC motherboard will not fit any Sony VAIO VGX-XL* model HTPC. These systems have a non-standard form factor, proprietary motherboard built for Sony by ASUStek (based on their ASUS P5 boards).
Micro ATX or mATX boards do not match the mounting screw pattern, and the case and rear panel would require major modifications (and many internal components removed and not reinstalled) for any replacement motherboard. The Power Supplty is also non-standard 18-pin version of an ITX low profile model power supply.
There are a few upgrades which can be made to a stock XL2 (up to 4GB RAM, better low-profile video/graphics card, DVD optical drive replacement with Blu-ray, a SSD system OS/BOOT drive), but the motherboard, power supply, BIOS and and OEM Pentium D processor cannot be upgraded (because of a locked BIOS microcode). The XL3 model offers a few more opportunities for upgrade (up to 8GB RAM, upgradeable Core2 Duo processor options) but the rest of the restrictions apply (motherboard, power supply not upgradeable).
Apr 09, 2010 | Sony VAIO VGX-XL2 Digital Living System PC...
I have had a motherboard failure the MS-7357 (V1.X) Mainboard... needing upgrade thinking of the MSI G41TM-E43 LGA 775 Intel G41 will i have to mess arround with the power switches with the case as this...
Boards don't come with switches. The problem with company made computers is that they get a manufacturer to make a board especially for the case they make. They do this to specifically stop you doing what you are trying to do, upgrade a machine with a proprietary board in THEIR case. You will find trouble at the rear of the machine getting to sockets and plugs.
It is far better to buy a good case, and then you can swap out components with ease. The case that held my Asus boarded P4 with the first SATA drives now has an Asus Quad Core in it with SATA 2.
MSI G41TM E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard Newegg ca
I would contact MSI direct
G41TM E43 MSI Global
Some of this might be useful
G33M - MSI
https://www.msi.com/Motherboard/G33M.html
... the app from the MSI website. Features - Automatically Detect the BIOS/Driver/VGA/Utility Update - Support Microsoft Windows XP/Vista/7 32/64bit. featurePic ...
::UPGRADE:: G33M (MS-7357) - new processor and RAM - MSI Forum
https://forum-en.msi.com/index.php?topic=125215.0 Mar 11, 2009 - 6 posts - ‎2 authors
The motherboard is a G33M (MS-7357) and has a piddly 1.6ghz processor and 1gb of generic RAM. I'm running Windows XP Home.
CPU-Upgrade: MSI G33M (MS-7357) processor support and ...
www.cpu-upgrade.com > MSI Nov 28, 2010 - MSI G33M (MS-7357) motherboard specifications ... FSB 200 MHz, L2 512 KB, TDP 35 Watt, Conroe-L, Rev A1, SSpec SL9XP, 7357v10.zip.
UserBenchmark: MSI G33M (MS-7357) Compatible Builds
www.userbenchmark.com/System/MSI-G33M-MS-7357/450 Compatible Components (from 7 PCs). Popular components in PC builds with the MSI G33M (MS-7357) Motherboard. CPU. Core2 Quad Q6600Intel $190Bench ...
Oct 21, 2017 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
Does msi motherboard P4M900M3 support this cpu Intel Celeron D CPU 3.20GHZ 512 Socket 775
MSI has two boards P4M900M3-F, P4M900M3-L.
Both of this will support your CPU
Nov 26, 2008 | MSI Computers & Internet
UpGrade
you could only upgrade the processor and RAM in this condition i.e.
you can only change your an upgraded p-III processor like 1.0 GHz, 1.1 GHz or 1.3GHz and
upgrade the RAM by changing to 256 in each slot.
that is all what u can do with ur pc
Oct 18, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
About processor
From what you posted, your processor uses socket 478. You could pop it into any of these micro atx boards
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130178
Jul 24, 2008 | Intel Pentium IV M, 3.06 GHz Pentium 4-M...
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
