Question about Ovens
AEG Microwave oven MC2660E - no power.
No power, no clock even. Socket and plug fuse both o.k.
Please help
    Master:
  • 619 Answers
Hi , open open the microwave oven check the fuse , if open replace with the new fuse .
Posted on Feb 17, 2008
GE Dualwave Mirco Oven combo - Oven works fine - Micro doesn't even show the clock
There is a very good chance that it has blown a fuse. They would be located behind the control panel. Be careful around the wiring to the high voltage circuit and make sure that the power is shut off.
Apr 14, 2014 | GE Jkp90Dpbb 27" Built-In Combo Microwave...
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    My AEG oven does not heat up, nor does the grill work. The oven light and fan comes on when selected but the light located with the temperature control dial does not illuminate. This light normally...
    DearDavidgale730,
    I am supposing this oven/grille is electric, and is plugged in to a power source.
    From your description, I'd say you have a serious problem and should no longer consider turning on the oven or the grille.
    Having made that decision, take an electric meter and test the socket or wires that connect the stove/oven to the wall.
    See if the current is flowing in both legs of the plug.
    (Remember, two are "Hot", one or two are grounded.)
    If not, correct the problem with the fuses or circuit breakers that are feeling the appliance.
    If so, open the appliance up and test all circuits with that electric meter to determine the problem.
    Often the problem may be a bad socket for the oven heater element, a bad element itself, or a burnt wire going to the element socket.
    God bless your efforts.
    Jul 04, 2017 | AEG B8139-4-M Electric Single Oven
    Microwave oven cuts out after pie inside catches fire.
    When you mention the fuse, if you mean the one inside the microwave, then your magnetron is probably damaged and you should just get a new microwave.
    If you're talking about the fuse in the electrical fusebox, then you could try opening the case of the microwave and finding the fuse inside. If you aren't familiar with working on HIGH VOLTAGE, then don't do this, take it to a service tech. But if it's out of warrenty and you are experience with working safely, you can look for a fuse inside the unit. As I said above, though if you do change it and the oven still won't work, your tube is probably dead and it's not worth the money to get a replacement part.
    But again, I'll stress that the microwave has a HIGH VOLTAGE POWER SUPPLY inside, and if you aren't familiar with working on things like this then just take it to an appliance repair store.
    Feb 16, 2010 | AEG Ovens
    Microwave shows clock but blows fuse
    Microwave ovens have a transformer inside them that puts out thousands of volts in order to create the "microwave" that cooks the food, but the clock and controls are on the circuit before that transformer.
    Most of the times the transformer is bad and depending on how much you paid for it, not worth the repair bill unfortunately. But thats why you see the clock, even though the fuse blows. I am assuming you mean the Microwaves INTERNAL fuse, if not then it is a model with a battery backup to not loose data like your alarm clocks do sometimes, therefore you would show the clock but not be able to start the Microwave.
    If it is the fuse or breaker in your panel that blows, then either the breaker is weak, or the transformer it shot. If it is 120volts, try plugging it into another outlet by either moving it or use an extension cord from another outlet you know work..if it starts, then you either have a bad breaker or some other electrical issue with the receptacle and should get a LICENSED electrician out, I say that because I am a Master Licensed Electrician and just because they say they are an electrician means nothing unless you see their license,plus ins. usually wont pay if there were a problem if an unlicensed person were used.
    I hope I helped, if so please give me a thumbs up!
    Nov 09, 2009 | Ovens
    Electrical intallation
    check the wattage from the rating plate and that will tell you
    Sep 14, 2008 | AEG B5741-4 Electric Single Oven
    Aeg competence b 8139-4-m - oven not heating up
    your heating element is probably bad. all u have to do is, make sure the oven is off, pull elem. away from it's holders on the top or bottom of the oven, then pull the elem. loose from it's sockets then, straight out of the oven. take to home depot, or lowe's, or an used appliance store. installation is reverseal.
    from sid
    Apr 20, 2008 | AEG B2100-4 Electric Single Oven
    AEG Oven
    try setting the clock, it may be automatic
    Mar 22, 2008 | AEG B2100-4 Electric Single Oven
    Wiring Diagram for AEG Build-in Electric Oven B2.6L
    can i use 13amp socket for a electric oven
    Nov 04, 2007 | Ovens
    Ovens Logo
    331 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
