Question about Canon BubleJet i965 InkJet Printer
Printer offline printer cable is connected and printer power is "on" I recently installed a linksys wireless-g router to my PC. I've since discovered a problem with the router and have de-installed the program. now i cannot print from my cvanon printer as the pc stats it's "offline". I've run out of ideas on how to fix it, and the mcrosoft trouble shooter is useless. can anyone help????/
    Genius:
  • 3,587 Answers
Go through control panel, printers, and select your printer..right click on it..bring it back online..
Posted on May 10, 2008
My router isnt sending signal to my printer
The router doesn't send signals to a printer. The Linksys transmits a radio signal recieved by the wireless adapters on other devices, if your printer has wireless compatibility it must be setup on the printer, in the wireless settings. I don't think it's a Linksys issue. It a computer software issue. If you post the Computer Make, Model, and your OS, the Printer Make, mode,l I will try to help you. Is this the first time using the Printer?
Jan 11, 2013 | Linksys Wireless-G WRT54G Router
Linksys wireless prnt server
Based on your post description, I am assuming that:
1. You can connect to the Internet through your 2241 Neptoia modem;
2. You can access your WRT54G V8 Linksys Wireless router @ 192.168.1.1;
3. Both 1 & 2 above could be done through a wireless connection from your PC.
Connect everything as they are supposed to be wired (printer, Print Server, modem, router etc)
Pls try:
a. Connect the Linksys wireless print server using a lan cable to the Linksys WRT54G Wireless AP/router. (Will tackle the wireless connection a bit later)
b. Reset your print server; &
c. Do a diagnostic print-out.
Instructions for b & c are in page 4 of your manual.
You need to verify that:
i. the Power indicator is contnously green
ii. the Ethernet indicator is contnously green
iii. the USB indicator is contnously green
iv. the Wireless indicator may or may not be contnously green
Pls post back with the generated diagnostic print-out before we can proceed with the other steps.
Additionally, try installing the Epson Stylus Photo RX600 direct to one of the USB ports of your PC. Use the installer/driver CD that came with it. Try using it as a regular printer. This will tell us status of the printer.
Good luck and kind regards.
Nov 11, 2007 | Computers & Internet
Can't install WRT400N cisco router need setup software or manual
Connect ISP modem to wireless router and then PC with cable. If that is fine you have a network. The easiest way now is to activate WPS on both devices. If this is not an option check web interface for network. Type 192.168.1.1 in web browser.
Aug 28, 2012 | Cisco Computers & Internet
I cannot get it to re-install. Somehow it keeps showing up as new hardware found. I am using the linksys wireless-g broadband router and it was working fine until my daughter cleaned her room and knocked...
you dont have to install a router. It has to be plugged in to the computer wired or wirelessly. The Code 10 is probably from the adapter you have. Try this link to see if you can fix the Code 10 yourself . http://www.instant-registry-fixes.org/how-to-fix-code-10-error/
Thanks Ranjit
Sep 25, 2009 | Linksys Wireless-G Broadband Router
Slow internet for my hardwired computer
its because ur belkin routers MTU is not properly configured in the products ... u need to lower doen the MTu speed ..
Sep 25, 2009 | Computers & Internet
No internet access with new Linksys wireless PCI Adapter
Don .bin is a firmware that can upload to the linksys router or any router.
So it seems that your unable to connect wirelessly using the linksys adapter? The Internet connection before is working properly?
*I might advise you to reinstall the driver of your wireless adapter using the latest driver that you can download in there support site.
- Check the Internet connection hardwired to the router if connection works it seems that problem is on the adapter.
Mar 07, 2009 | Linksys Rangeplus Wireless Pc Adapter
Linksys Wireless-G problem with Internet connection
Have you tryed unpluging both routers then pluging them back in?
This will refresh your Ip's
Dec 11, 2008 | Linksys Wireless-G WRT54G Router
HP 7410 off line with Vista & HPM8000 computer
Once right click on the printer icon and make it online and then clear the print que and then download and install the patch from the below webpage.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-54112-1&lc=en&cc=us&dlc=en&product=391194&os=2093&lang=en
After installing the patch restart the computer and check for the result.
Jun 18, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Linksys wireless G-ADSL Home gateway
Sometimes this happens. Installing the Linksys software for your router helps a lot. To reset the router. Unplug the power cord from the wireless & unplug all cables to it. There is a reset button on the back side of the wireless. It is very small. Using a pen press & hold for ten seconds or so. Release & connect your cables & than the power cord. Never hurts to restart the pc or notebook. If you still need help you can check out Linksys home page for wireless G routers.
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740137401B343
There is a decent ammount of help, a larning center & driver software.
Luck!
Please vote....
Jan 19, 2008 | Linksys Wireless-G WRT54G Router
Canon BubleJet i965 InkJet Printer Logo
924 people viewed this question
old marine
old marine
