Question about HP OfficeJet 6110 All-In-One InkJet Printer
Hp 2115 Could you please help when I turn the printer on it makes a clicking noise and then when it stops all the lights for the print quailty all flash. Have you any ideas
    Problem Solver:
  • 10 Answers
Issue with carrage , try cleaning ink carrage .
first
*unplug the power cable and press and hold power button for 1 min
*press and hold # and 6 , while holding # and 6 plug the power cable back in
*release the button after 10 sec
*wait for some time
*open carrage access door
*cleane printer carrage see for any dust in carrage
*pull the carrage to left
*turn off printer and turn it on
then try pressing OK and cancel at the same time
check for test page
Posted on Feb 22, 2008
I have a HP Photosmart C4780 all in one printer and when I turn it on, as well as before I go to print something, the printer makes a horrible, loud clicking sound. I have cleaned out the inside and...
There may be nothing you can do about it. A lot of the HP printers make a lot of noise as they start up or prepare to print. Has your printer always made this noise or did it just start?
Jul 26, 2011 | HP Photosmart C7280 Laser Printer
Why is my hp psc 2410 photosmart all-in-one make a clicking noise, when I turn it on? It seems to be stuck in a "cycle". Like the printing carriage (if that's what you call it) is hooked-up.
See if you can press the power button to turn it off, leave it for 5 minutes then turn it on again, if the clicking persists again try 1 more time, turn off, leave for 5 mins then turn back on this time there should be no clicking noise and you should be able to send a print job to the queue and it should print.
If this doesnt work then goto the hp software and purge.
Oct 27, 2009 | HP PSC 2410 All-In-One InkJet Printer
HP Officejet 6210 will print but with terrible clicking noise
Ok this Sounds Crazy but it worked for me and its easy to try. Unplug the unit and pick it up and turn it side ways and gently shake it. Sometimes a small piece of plastic has broken loose and is interfering with the works and if you can dislodge it from its current location it will stop. Be careful not to hurt youself doing it. Also, I have one printer with a missing tooth on one of the gears and has been growling at me for a long time.
Best of Luck,
RSMITH972278
Oct 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Printer makes non-stop clicking noise when plugged in. Had been printing a document, it stopped halfway through, froze, began clicking and the error light began flashing. Doesn't respond to any of the...
The rollers of the printer must have accumulated dust such as sand or something. Try cleaning with alcohol the parts which moves in time of printing. The curcuit may also be damaged. Thanx.
Aug 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Hp 2115 - clicking noise from carriage, can`t print test page
I have an HP 6110 is always has a grinding noise.No functions work. HP just want me to buy a new machine. They are bad quality 3 in one's. That is for sure.
Jun 28, 2009 | HP OfficeJet 6110 All-In-One InkJet...
''clicking'' noise started randomly- cant use printer
Hi starrz54,
Here is the HP site that talks about resolving unexpected noises (such as clicking)...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu06191&lc=en&dlc=en&cc=us&lang=en&rule=26695&product=303753
You also might try doing a full reset on the device. Here is how to do that: While switching on the scanner press # and 9 to initialize.
I
This should give you some good directions and if it does not resolve the issue, the next step would be to have it serviced or replaced.
Nov 16, 2008 | HP PSC 2410 All-In-One InkJet Printer
Black ink
Please try the following to resolved the issue:
Run a series of head cleaning
1. Make sure the printer is turned on but not printing. Make sure there are no error lights or messages appearing in the LCD.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START, CONTROL PANEL, PRINTER & FAXES then right click on CX3200 printer Icon then select printing preferences
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Mar 02, 2008 | Epson Stylus CX3200 All-In-One InkJet...
PSC 2115 error message
turn off your machine unplug the power for about 5 mins. disconnect the usb cable from back. Plug back in power, wait until machine fully boots up. Check your cartidges to make sure there in there good and are not lose. Remove them and just put them back in making sure there secure. Then try to aline the cartidges.
Feb 16, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer makes clicking noise
Make sure the printer is not out if ink. When the light flashes this may be the case. Also check the print queue. If it contains pending print jobs and there is no paper the light will flash. Here is how to check print queue: Click Start > click priters and faxes > double click printer icon and see if there is something ... If you see any print jobs delete them right away. and restart your computer. This should solve your problem.
Oct 05, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
164 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
