Question about Canon EOS 400D / Rebel XTi Digital Camera
Error99... pls help!!
I own a canon 400d 18-55mm... bought it like 2 weeks back!!! today after i transfered da pics from my camera to my pc and tried formating the card... it wasnt able to do so.!!!
# i tried using another cf card too, but found no result...
the same error 99 wz being displayed!!!
# wen i tried clickin pictures... it showed a note sayin that the cf card needs to be replaced...but wen i tried formatting it showed a note saying turn off and then again turn on... and insert the battery!!! i did but found no result!!!
  • 667 Answers
Here is a link for further steps to take on Error 99: Canon info
The article refers to the 30D, but the same troubleshooting will work for your camera too
Posted on Feb 17, 2008
EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens: went on a trip to europe. took lots of pics and we...
1. There are hundreds and hundreds of programs that can restore lost files from a formatted drive... just google it
2. You cannot use a usb cable to transfer files (or at least not on my computer) with this camera, you have to take the card out of the camera and directly plug it into your computer
Hope I helped
May 18, 2010 | Canon EOS 400D / Rebel XTi Digital Camera...
My Canon EOS 400D won't switch on. No power.
Have you tried cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol? Are the batteries also 3 years old?
Dec 07, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Can't download pictures to pc
What software are you using to access the pictures. If you don't have the "canon" drivers installed it just won't do it.. You can however go get a card reader for the Flash card and that saves on the camera batteries..
Jan 29, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D not transferring photos to computer
Try installing or reinstalling the software on the CD ROM that came with the camera.
Jul 24, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Error 99
i had the same problem and i found this guide online fixed my problem
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
Apr 19, 2008 | Canon 75-300mm f/4-5.6 III USM EF Lens
Canon 400D
Use a card writer and copy your pictures to the CF card on the computer.
Jan 07, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Transfering Photos
edmerk:
In your case it seems like the software is the problem, try uninstalling it completly and reinstalling it back after a restart of your machine, also check this:
http://www.microsoft.com/windowsxp/using/digitalphotography/takeit/transfer.mspx
If this does not solve the problem then try using any other software for downloading pics from your camera or simply use the windows built in feature like:
Going to my computer, and check if you can see your camera drive there and simply copying and pasting from there. (see if this helps you).
I hope it helps you!
Dec 06, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Is my canon eos 400d broken?
This is a Digital SLR With SLR cameras you can only use the viewfinder because the image comesi nto the lens and up to the viewfinder via a mirror. When to take a pic the mirror flips up[usually with a crash] and the image goes to the CCD- afterwards you will get an image briefly in the LCD.
Sep 20, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
My Canon is displaying - Err 99 what should I do?
Just found this info which should help diagnose the err 99 issues (info direct from Canon apparently)
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 10, 2007 | Canon EOS Elan 7ne 35mm SLR Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
127 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
