Question about Nikon Super Coolscan 4000 ED Film Scanner (35 mm)
Nikon Coolscan 4000 ED SA-21
Recently a problem has arisen with the ejection of film strips from my Nikon Super Coolscan 4000 ED 1.10 @IEEE1394 when using the film strip adapter and Nikon Scan 4 . The software doesn't recognize that the strip has been removed and so prevents a new strip from being inserted by continually running the eject mechanism in the Coolscan. The problem does not occur when using Vuescan. After clicking on the eject button the progress window opens, the strip is ejected but the dreaded Mac spinning disk appears showing that the program has crashed and the Coolscan keeps on trying to eject a strip. I can then only "force" quit to get out of the program.The only way I can get Scan 4 to accept a new strip is by  switching the Coolscan off, then on again,load the film strip and then load the program, which works perfectly.As the CD i have is for version 3.1 which will not load into this Mac 2GHz Intel Core 2 Duo computer I have uninstalled and re-installed the program,which was downloaded some time ago and stored on an external HD, but the problem persists. I believe that it is either a mechanical problem in the adapter or a general firmware problem.
Nikon Scan 4 works perfectly using the FH3 film strip holder and when scanning slides.
I prefer to use film strip adapter because of the ability to show thumbnails and as it recognizes the frames in a strip more accurately than Vuescan. I should add that I have been using the Coolscan since 19/5/05.
What can be done to correct the problem,please?
Regards,
T H Connell
  • 2 more comments
  • fnikon Feb 27, 2008
    I have the same problem.
    I have taken the same steps as you.
    Many hours work.
    All to no avail.
  • modernmagic Oct 14, 2008
    same problem. your work around does not work for me.
  • Anonymous Nov 05, 2008
  • Anonymous May 06, 2009
    Same problem on the scanners here at NYU. Your workaround is what I've been doing too. It's annoying as hell.
3 Suggested Answers
computafixa
  • 317 Answers
SOURCE: trouble ejecting slide from SF200 nikon coolscan 4000 ed
open the case of the scanner, and check to make sure that the ejection mechanism is not malfunctioning, or jammed someway.  If this is not the problem, try using thinner slides as thicker ones could also cause this.  If all else fails try un plugging the scanner for a few minutes, and try again.
Posted on Jan 10, 2008
SOURCE: No error message displayed when film jams
Take it into nikon specialty shop for a service.
Posted on Aug 19, 2009
Recently upgraded from Windows Vista to Windows 7. Where can I get correct drivers to run with my Nikon Super Coolscan slide scanner LS-4000 ED model. I have Nikon Scan 3.0 twain software. Stu Milligan
Hello there.
This will help you if you have 64-bit Windows 7, because officially, there is not windows 7 64 bit driver.
Just read and do everything.
http://www.earthboundlight.com/phototips/coolscan-vista-64.html
Otherwise, if you have windows 7 32bit click here:
link
To check bits, go right click on My Computer, Properties, and you will see it.
Sincerely,
Steve TM
May 28, 2011 | Nikon Super Coolscan 4000 ED Film Scanner...
My Nikon CoolScan 4000 is not working properly. All images come with a green shade
I had the same problem with coolscan LS 50 ed, but the chromatic dominant was blue instead. What you have to do is to perform a p.o.s.t. procedure: 1) swith off the scanner and unplug it from the PC; 2) switch off the PC; 3) remove the film-holder from the scanner; 4) switch on the scanner; 6) plug it back to the PC; 7) switch on the PC; 8) insert the slide/film holder. It should work now...
Oct 02, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
Need a new driver for coolscan 4000 ED for Vista.
You can download the Vista Driver at this link: 4.0.3 full version - Vista only
If this information was helpful, please give me a big thumbs up when you rate my answer.
Feb 03, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
Aug 18, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
SA-21will not pull film strip into chamber
Put the film in after it is powered up. The unit needs to run through a power-up and calibrate cycle first. Once powered up, the until will feed the film in once it reaches a certain point into the machine.
The unit is supposed to kick the film back out when you close down the scanning software. If your film ever gets stuck try this to get it out. DO NOT force the SA-21 out of the machine with film stuck in it.
Aug 13, 2008 | Nikon COOLSCAN IV ED LS40
Trouble ejecting slide from SF200 nikon coolscan 4000 ed
Jan 10, 2008 | Nikon Super Coolscan 4000 ED Film Scanner...
USB cable from scanner to new Dell Optiplex 755
If you look carefully at the cable, you will notice it is a firewire cable (IEEE1394), not USB. You will need a firewire interface on your computer to use the Nikon scanner. It will not work with a USB port.
Jan 02, 2008 | Nikon Super Coolscan 4000 ED Film Scanner...
Nikon Super Coolscan 4000 ED Film Scanner (35 mm) Logo
147 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
David Darrow
Level 1 Expert
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
