I have no book on the tv.i can not hook my theatre up.no soure what goes where.please help
  • fdemaohd Feb 17, 2008
    it is a olevia tv.can't hook up homethestre system model 242-s11 p/n-042000eg001
  • 5,138 Answers
You didnt give enough infor about your set in order for anyone to be able to help you with this problem Name brand of TV ect.......NEED more information! ThankYou for using FixYa. Have a Nice Day.
Posted on Feb 17, 2008
How do you get sound to come from tv out of speakers of home theatre system
It just depends on the tv you have. If you hook up the RCA jacks to the (Audio out) of the TV into one of the (AUX in) ports of the home Theatre system you should be able to geet the sound that comes from the TV to play out the theatre system. If you are watching through a cable box you will need to hook the RCA cables to the cable box (Audio out) too the theatre systems (AUX in), in insted.
Mar 05, 2011 | Televison & Video
TV Hookup
The TV is NOT a source of high quality sound.
For the best serious audio I would recommend drawing the audio-only digital feed from the Cable Box via its highest quality audio output. Then turn the TV's volume down. Also run the vanilla RCA stereo audio pair from the cable box to the TV in case you just want to check the weather.
Mar 05, 2010 | Koss C220 System
I purchased the panasonic scpt670k home theater system and hooked it up to a jvc I"art tv but when i hooked the audio out port of the tv to the auxilary in port of the home theatre systme I don't get the...
What exportable audio is originating with the TV in your scenario? I couldn't find any documentation supporting an audio output of any flavor.
Isn't the root source of the program actually a cable box, satellite, dvd or blu-ray? Wouldn't THAT be where you want the audio feed to the Panasonic to come from?
Feb 01, 2010 | Audio Players & Recorders
Connect home theatre to ps3 to 32" lcd tv
if your tv and home theatre system as all hdmi or component hook ups then follow these steps but only use all one or the other cables.
1. hook the cable from the ps3 to the home theatre "imput slot" (you choose which one you want to use)
2. hook a cable to the output slot on the home theatre system to your imput slot on your tv.
3. turn on all three systems, put your home theatre system on the correct function (which ever slots you decided to put the cables in to the input slots) then turn your tv to the correct AV channel
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
Multiple game systems through home theatre
what you need to do is hook all of your gaming systems into the "in ports" on your gameing switch, then hook the set of cables you want to use to the "out port" then the other end of those cables need to go to the "in port" on the home theatre system (you can pick which in port you would like to use, it should say which is which on the back by the ports) after doing this you need to find the out port on the home theatre system that corresponds with the cables you are using ie, rca component or hdmi. once you find that port you need to hook a cable to that into your 'in port" on your tv., lastly turn on all of your gaming systems, your tv and your home theatre system. and on your home theatre system select which ever port you hooked the gaming switch into, then turn your tv to the correct channel that you hooked the cables into the tv, lastly go through each swithc on your gaming switch to be sure that they all work, if not, you might want to use all the same cables for all connections, ie, all component all rca or all hdmi, i prefer component.
Mar 29, 2009 | Philips MX6050D System
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Sound goes off
You probably have too much power running to your power strip that you probably have your xbox, playstation, tv and home theatre system plugged into, try using seperate wall outlets for your tv and home theatre system
Dec 20, 2008 | LG LHT854 Theater System
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Dec 17, 2007 | Audio Players & Recorders
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
