Question about JVC DRM10 DVD Recorder
Continuous flashing loading
I have a problem with my JVC DVD recoder when you put power on it flsahes LOADING blue for a long time and you cant play or record anything. any suggestions please... john
  • 9 more comments
  • Anonymous Feb 23, 2008
    tried everything... got a match?
  • Anonymous Feb 27, 2008
    Same thing here. Nothing seems to work. Doesn't respond to any key, keeps flashing the same text after disconnecting power.
  • John Mar 26, 2008
    I've had mine for about 2 years now and thought it was a great machine until the last two weeks when the loading problem started. I cannot do anything with it, no buttons work at all, it just keeps flashing 'loading' for hours until I turn it off. Is it ready for the bin or is it possible to get it fixed.
  • Anonymous Mar 28, 2008
    Player wouldn't operate.Trouble shooting advised to press on/off button and hold down stop button. Since then only get "loading " flashing continuously. Tried unplugging and re-powering but flashing continues. How can I sort this?
  • Anonymous Mar 30, 2008
    We also have the problem loading. We can push every button but nothing works. Who haves the solution
    Henny
  • John Apr 12, 2008
    Thanks Colejohn, but the number you have posted does not connect. The number I got in contact with JVC was 0870 330 5000. Unfortunately, the 3 different times I contacted them, nobody was aware of any problem and just gave me the number of a repairman where I could get it fixed. For a cost of approximately £160.00 +. No thanks. What next?
  • Acltweed May 27, 2008
    I have the same problem after 2 years of good operation
  • Anonymous Jun 26, 2008
    MY dvd just when to flashing loading while watching dvd and no buttons would work to stop it even turning the pwer on and off had no effecT david
  • pete159 Jul 05, 2008
    I've just had the same problem with flashing loading anf unit not responding. Anyone found a solution yet?
  • Ad one Aug 05, 2008
    This all sounds familiar. I used to get the "loading" message intermittently, but now it has come up and won't go away even after powering down for hours???
    I will also try the JVC number in the UK (0870-330-5000)and see where it gets me. watch this space...
  • Anonymous Jan 29, 2009
    We have a Toshiba DVD doing the same thing. Our unit is 2 yrs old. We added several DVD's and all of them just continuously flash :Loading..."
Contact JVC @ 800-252-5722, the "loading" is a known bug and they will fix this defect at n/c even if it's out of warranty period.
Posted on Mar 31, 2008
I plugged it into a different outlet and it solved the problem, but only till this morning and it went right back to flashing "LOADING"
Posted on Feb 29, 2008
Same problem here. Nothing seems to work... Pressing any key makes no difference. Disconnected the power - nothing.
Posted on Feb 27, 2008
When trying to play a DVD, we insert the disc and it says loading. Then it tells us that it is the wronge type of disc.
your disk and player must be compatable, you cant play dvd's in a blue ray player, you cant use blue rays in a dvd player, you cant use ps4 games in an xbox and you cant put cd's in a record player... hope that helps!
Jan 03, 2016 | Televison & Video
Cyberhome DVD writter not decting DVDs . Getti g a disc error.
HI Johnny,
Any chance someone went near the DVD/VCR and dusted with some Pledge or any kind of dusting spray? It sounds like something has got the DVD driver chip acting crazy. May be a faulty disc tray switch telling the controller the door is opening and closing all the time. If its brand new, do you have an opportunity to take advantage of a warranty claim?
Nov 15, 2007 | JVC HR-XVC19S DVD Player/VCR
Tip
Jvc dvd vhs burner dr-mv1s and dr-m10 loading continues to flash
if you have a jvc dvd vhs burner dr-mv1s or the dr-m10 with the loading that continues to flash with no control of the unit at all there is the first step to take witch is a master or hard reset. done by holding the stop and power buttons at the same time for 10 or more seconds till it powers of then on again.
if this does not work or has no reaction to the unit at all them repairs will have to be made.
i have scowered the internet for fixes for this issue and have found a few interesting things but nothing concrete at all. but lead me in the correct area of the issue. although jvc was fixing these for free at one time they are no longer servicing them under their "free fix"
the problem with the unit is the power supply and although i found that easily on the web. i could not find what the exact problem was untill i did my own diagnostic testing and found that capasitor c5207 on the power supply board was bad and buldging/leaking. it is a 1500uf 6.5v @85 degrees witch i used a 105degree due to the temp and relating the issue with a bad design flaw. so use the higher temp rating one to insure long lasting use.
don't forget to preform the master/hard reset previously mentioned above and you will be back up and running in no time.
good luck......
on Mar 12, 2010 | Televison & Video
When we put a disc in to play it, the player just continues loading and never actually plays the disc. what could be the problem? It is plugged into a wall outlet when we are trying & we have tried...
Check DVD discs for cracks,big scratches,dirts and grims?All DVD dics are original discs like comercial movies or materials discs?Most DVD players have problems,reading and playing copy discs,because of it finaling codes of the DVD copy recoders players used it to coping it.
Feb 25, 2011 | Sylvania SDVD8732 Player
Loading keeps blinking Nothing works anymore. even power of no longer works
Check for dried up electrolytic capacitors on the DC-DC converter C5318, C5340, etc.
Nov 13, 2009 | JVC DR-MH30S DVD Recorder
Unit shows 'loading' continuously
This player is equipped to do a self power on test to all pain parts of the player to assertain everything is ok. The blue light will keep flasing until it completes its task and then the blue light will stop flashing and you you can start reusing it.....................sodeep
Jul 30, 2009 | JVC DR-MH30 DVD Recorder
Loading is flashing and can not do anything
my machine just has loading displaying in a flashing mode
Jan 29, 2009 | JVC DRMH20 DVD Recorder
JVC DR-M10 DVD Recorder not working
Mar 12, 2008 | Televison & Video
JVC DRM10 DVD Recorder Problem
This unit is showing and error message "Disc Not Recordable" with a maxell DVD-R 1-16 Speed Single Sided Recordable DVD.
Nov 09, 2007 | JVC DRM10 DVD Recorder
DVD Recorder stuck on "loading"
That's exactly the same problem as I have, any suggestions would be greatly appreciated. Used to solve it by turning off at the plug and restarting. Now won't load up at all though. I love the machine - when it works - it just isn't very often!
May 27, 2007 | JVC DR-MX1 DVD Recorder/VCR
JVC DRM10 DVD Recorder Logo
612 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
