Hi, I've been trying to burn data onto some DVDs, but my burner completely fails to burn any data onto them.
In detail:
I'm using Cyberlink DVD suite and have been for about six months. It worked before perfectly fine. But lately, every time I try to burn something (whether data, an image, or a movie), it goes through the entire process and says -it completed successfully!- But then when I try to run the DVD, it says it's blank and asks me if I want to burn anything onto it.
I've probably gone through 30 different DVDs like this.
Does anyone have an idea what the problem is?
What comes to mind is that you are burning to an image file and not your actual burner. Make a small data DVD and name it something obvious such as aaaa. After completion of the disk, do a search for the file and see if it is in actuality on the computer. If it is stored as an image file, you need to select the recorder type to your actual burner.
I think first we should outrule that the burner itself may be at fault. Download a trial version of Nero and burn a disk from it and see if it works. If it does, you may need to reinstall Cyberlink. Also, do you have your program licensed to more than one Pc?
http://www.nero.com/eng/downloads-nero9-...
@proartya8765
I tried what you suggested but I didn't find any disc image. I'm certain that the program is attempting to burn to my disc drive (D:).
I should add that the drive does spin up and go through the same actions that it did when it was working. I've burned disc images before, so I know it's not that.
I should also add that it does the same thing when using DVDFab.
Does anyone have any other idea on what might be the problem?
Well it turns out it is my CD/DVD burner itself.
I remembered I had a burner on Windows7 (I'm dual-booting XP and Win7) so I tried it out there.
Same result.
Do you have any ideas on fixing the burner?
Luckily my PC is still under warranty, so if there's no way to fix it, I can still send it back for a replacement.
