Philips hfc21 Cant set time display is blinking
  • despoina morfoniou Feb 28, 2008
    Display is blinking continuesly and does not accept to get in set up mode (a tech said that may be a power input problem. Is it reasonable?)
    Genius:
  • 1,665 Answers
Posted on Feb 29, 2008
    New Friend:
  • 120 Answers
Go to set up menu. then set date and time.
Posted on Feb 19, 2008
Philips 32pfl5332d/37 when turning on blue light for 5 sec the red flashing six times then again such times continuesly never turns on no picture no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Nov 13, 2016 | Philips Televison & Video
What do you need help with? sharp LED TV model LC32LE265M when powered On only the red indicator light keep blinking, no sound no picture no backlight.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
With some models of Sharp sets, they have used Philips main board inside. If your set is of that type, you should follow the LED blinking procedure of Philips.
Sep 30, 2016 | Sharp Televison & Video
Tv will not turn on diagnostic blinks 6 times first then the rest 7 times
Sounds your TV is fitted with Philips TV board inside. Panasonic uses that board for some models of their sets. The procedure to blinking indicates it. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Sep 11, 2016 | Panasonic TH-42PC77U TV
I have a sharp LC-60LE831U tv that is flashing a code on the power light 2 slow 5 fast. No picture or sound and factory resets I have tried do not seem to work, any ideas or suggestions.
Some model Sharp sets, they have used the Philips main board. Yours should be one like that. These blinking codes denotes it. That means; your TV is a not duplicate one. Sharp did it for some sets of their own. So, when you try to count the blinking codes of such set, you should follow the way of how to count the blinking codes to Philips TVs.
Aug 23, 2016 | Sharp Televison & Video
Philips TV don't turn on the light is white and blinking
http://electro-medical.blogspot.com/
Jun 20, 2016 | Philips Televison & Video
My Philips 60pl9200d /37 TV power light blink fast then slow about 6 times what is my problem
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 23, 2015 | Philips Televison & Video
Philips clock radio model DC29037 how do i set time
push and hold down the button on the back for the clock light, the display will start blinking, push again until the hour blinks and again for the minutes.
Oct 18, 2013 | Philips Clock Raido For Iphone/ipod
Philips 42PF9630A Not Working - Red Led Blinks 7 Times
http://homenol.blogspot.com/
May 11, 2017 | Philips 50PFP5332D 50 in. Plasma...
Plug in,time will goby then it goes blank off, trys restrting
Sounds like The main power supply regulator section circuit fault. Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Apr 05, 2017 | Philips 32PF5320A 32 in. LCD Television
Philips hfc21
unplug it for a couple hours and plug again.
Feb 17, 2008 | Office Equipment & Supplies
320 people viewed this question
jasbo
jasbo
