Question about Video Cameras
Playing back footage on pc
Okay. i have a mini annoyance with my mini cam! My pc is a acer laptop. I wanna play what i recorded from cam on pc. can't get usb cable to be recognized. also, which program /icon do I use, NTI CD&DVD maker 7 or cyberlink power producer or windows media...I am clueless. Read directions but am still 'uneducated'! thanks for the help. oh and i have this disc - maxell dvd-r up to8x /4.7gb/2hrs sp mode will this work to record video onto? Also even though it says sp mode, i recorded using lp mode will that matter? is this what you'd call a re writable disc? do i have to have a disc to play my footage? this sure isn't like thegood ol' fashion vcr or cassete stuff! thanks again. Have a Hitachi DZ-GX5040E DVD Video Camera/Recorder. Cannot play back camera disc footage on my PC (Windows XP Pro version 2002). Camera has neither USB connection or 'driver'. Can only play footage on TV and record on video cassett.
  • dcocksey Feb 17, 2008
    Possible confusion due to the fact that my problem(the second paragraph) seems to have been presented attached to an unrelated problem - not mine. I realised this when I first viewed my submission and have subsequently re-submitted the second paragraph.
    Scholar:
  • 176 Answers
Don't know u're cam, but usualy the camera haz to "close" the dvd sesion, so that the computer/dvd player .... to be able to play it ...
Ofecourse u can play the video on PC, using cd/dvd data recovery software, that accesses the data directly and not track based ... (that in the case that the dvd got damaged and the recorder can't finish it ...)
Posted on Feb 17, 2008
2 Suggested Answers
  • 45 Answers
SOURCE: playing back footage on pc
mini DVs sometimes can't be access using usb interface, try to look if u have a firewire interface, be sure your laptop supports IEEE1394. power dvd is the best player for dvd files. -r means recordable, not rewritable (rw). if ur not familiar with video editing, you may not be able to burn it to disc, but you can play and watch everytime.
Posted on May 17, 2007
Hi. put in a mini-dv tape recorded on a sony z1 camera, the sony dsr-45p tape deck doesn't show any footage from the tape despite the camera had playback to show that footage was recorded. Using a windows...
Try to playback with other tape recorded earlier from other camera or VTR .If other tapes are palying properly without any glitches then it might be the problem with this recording.
anand
Oct 22, 2010 | Sony DSR-45 Mini DV VCR
the issue is probably related to the format the tape was recorded in. a z1u records in hi def (hdv) the dsr 45 is standard def ntsc. not compatable, play the tape in a z1 to recover
Half the screen is blue
the lcd panel is faulty. replace it at a service centre
Oct 13, 2009 | Sony DCR-VX2000 Mini DV Digital Camcorder
Mini DV Tapes are not playing back. Nothing but blue screen when I try to view tape...no time code...nothing. Recently recorded footage plays back fine though?????
If recently recorded plays back ok, and there's no warning about low rf or head clogging problems,it seems to be electronic problem in vtr board,but usually is head problem,which is not so expensive.
Jul 30, 2009 | Panasonic AG-HVX200 Mini DV Digital...
No sound when playing back video footage
If there is an external microphone jack on the camera, it would help if you tried recording with an external microphone. Also, the mini DV's will mute the sound if the tape guides are slightly out of adjustment. You can tell if they have moved by trying a known good sound tape in the machine. If that plays with no sound also, the tape guides have moved out of alignment.
Sep 16, 2008 | JVC GR-DX97 Mini DV Digital Camcorder
Cant play back recorded footage
you have to flick the switch on the side from camera to play
Jun 29, 2008 | Canon MV650i Mini DV Digital Camcorder
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Sony dcr-hc35e
first try a cleaning tape and this will not solve the problem have a service dealer check the unit.ru the cleaning tape once and try to playback a good old recording, if it does not work try to run the tape twice before testing . do not run the tape too many times as you may damage the video heads.one cleaning session should not be longer than 10-15 seconds. most of the new cams are stopping the cleaning tape playback after 10-15 secs.
Jul 04, 2007 | Sony DCR-PC55E Mini DV Digital Camcorder
May 17, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Jvc 200u problem recording to vhs video tape, from camcorder
Yes, if the camera is a US camera then it is NTSC. That would be your problem, you are trying to record an NTSC signal to a PAL video. THe frame rates and resolutions are all wrong. I am even surprised that it is playing back on your TV okay...
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Video Cameras Logo
315 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
