Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius washer door wont open
Hi my washer has finished and drained all water out and has completed its cycle but the door lock light wont go out and the doorlock wont realease can u help plzzzzzzzzzzzzzzzzzzzzzzzzzzzz
  • Anonymous May 17, 2008
    my washer has completed its cycle but the door wont open ,the on /off button keeps flashing constantly and also a couple of the other cycle buttons also.
I've got the same problem, the locked symbol is showing
Posted on Jul 02, 2008
My washer dryer was on baby cycle wash and although the green light has come on to indicate it has finished, red lock key is also on and I am unable to open the door.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
How to fix washing machine door lock in Hotpoint washing machine
Opening locked washing machine door
Feb 10, 2016 | Hotpoint Aquarius WD640 Front Load...
Door will not open have wash cycle
Switch off, put in spin/drain cycle and switch back on; check water is fully drained and then check filter. If not all drained, lower hose to ground level and drain to a bowl.
Apr 28, 2012 | Hotpoint Washing Machines
Door lock light is on door is not locked and
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Thank you !!
Jun 19, 2010 | Frigidaire GLTF1040A Front Load Washer
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Door locked light stays on so cannot open door
Make sure that all the water has drained or the door will not open, lay the hose into a bowl or other shallow vessel and let any remaining water run out. Wait a for a while for lock to release,if it still does not open then the door is going to have to be opened by force.
Plz rate this solution.
Dec 16, 2008 | Hotpoint Aquarius WD63 Front Load...
Door won't open
Usual reason for this is not emptied correctly. The filter on this model is in an awkward place so try lowering drain hose into a bowl to check if water still in.
Nov 11, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Door won't open
two possibilities water not fully drained - door won't open if so handle mechanism broken - check if it too free to move or sloppy
Feb 25, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA42 Front Load Washer Logo
903 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
