Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
Won't show on desktop
Hi there, i am just setting up my new lacie harddrive but it won't appear on my desktop! I have a mac book running OSX 10.4.11. I have it connected with USB 2.0 and nothing is happening. Can you offer any suggestions? Thanks
Tom L
  • Anonymous Jun 24, 2008
    La Cie 500 GB appears nowhere. Have checked proposed solution using disk mgt., trouble is no unidentified ( letter) driveis shown. Device mgr shows no problem. Wires disconnected/re-connected as proposed--no solution. Tried another computer running Xp--La Cie drive doesn't show. Have exhausted just about all alternatives.
  • 3 Answers
Before you read this solution!!!! READ 3 IMPORTANT NOTES!
1. If you dropped it and it's clicking continuously sorry but it's probably trashed... When you call up Lacie about the Warranty DO NOT TELL THEM YOU DROPPED IT they will void out your warranty and you will end up having to buy another HD adding insult to injury when you lost your files as well... just say it's not working... It's not lying It's just called sticking it to corporate glutons who from whispers I've heard sell refurbished Lacie drives as new ones to ignorant customers
2. I've been doing some research and certain programs like TweakUI a program that Microsoft installs which can be found in your control panel does conflict with the Lacie HD
3.This problem occurs whether or not you use a firewire or usb or sata so if you don't have one of these sockets in your computer
don't buy extra equipment
The Meat:
Aaaaaaaaaaaaaaaaaaactually Windows regardless of XP or Vista tends to screw up when it comes to Lacie drives...
This is how you fix it for sure:
go to control panel
administrative tools
computer management console
open up the disk management section
in there....
you'll see your C: drive or what other drives you may have already set up
Buuuut
you'll see one drive that doesn't have anything assigned to it no drive letter or anything 95% of the time that will probably be your lacie drive fresh out the box
Only thing you gotta do now is enable that drive by right clicking on the grey box next to it where it should say disk and for the sake of simplicity let's say it says Disk 1 or Disk 2 whatever
Enable it then partition it using NTFS if you're only going to use it on windows and FAT32 if you want to be able to use it on both MAC and PC
If you already have things on your hard drive from before and it just started acting up:
Try doing these 3 things:
First Lacie said that the drives can be tempermental when you don't shut them down right... so you would have to
disconnect all wires
connect power cord only and plug it in
turn it on wait a couple of secs.
connect usb cable to drive then to computer
that's one way of fixing it
if that doesn't work
you can try going to control panel> system> hardware> device manager
in there try and see if you have anything with a yellow question mark or exclamation point or a red X next to a USB controller or
Composite device or to Mass Storage Device under USB peripherals
If it has either of those just right click on the device and click update driver
If not right click mass storage device> uninstall
right click composite device> uninstall
right click on icon in lower left hand corner to remove device safely
choose the drive > remove safely> use turn off switch to turn it off...
Now turn it back on and it should reinstall itself
If that still doesn't work there's a couple of tutorials on how to recover files from faulty Lacie drives you can google that and it should be able to help you out for the most part...
This may involve opening up the casing and removing the hard drive not the internals and connecting it to your desktop directly
(ADVANCED USERS ONLY)
worst case scenario you may have to repartition/format your drive and it should be back to normal at this point your going to have to call
Lacie support
22985 NW Evergreen Parkway
Hillsboro, OR 97124
Tel: (503) 844-4500
Fax: (503) 844-4508
6am-6pm i think
HOPE THIS HELPS!!!!!!!
- LTek -=oP ^v^w^v-_-Your Neighborhood Techno Freak -_-v^w^v^
Posted on Apr 08, 2008
  • LTek Apr 08, 2008
    Solution 2a for MACS
    New Lacie HD's need to be formatted to work
    There's 2 formats I would advise
    either FAT32 so you can swap it between MAC and PC
    or MAC Extended which is HFS+ After you do that it should work fine
Hi Tom,
My brand new Lacie quadra d2 harddrive decides to show up on my desktop and other times does not. When it does show up, most of the time, it works fine, but sometimes I start up my computer and it simply refuses to show up on my desktop - when this happens I don't hear the harddrive spin up (which is quite loud)  HOWEVER if you just ignore it for 5 mins you'll hear it start up and it appears on the desktop and works fine. Good luck, Sarah
Posted on Mar 01, 2008
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
My mac laptop suddenly won't recognize it
you may need to swap the usb port it's plugged in
Jun 11, 2012 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
To connect a ion PIC2PC ot a imac Mac OSX with in the USB-port. I have installed CrossOver and drivers from the packet, it is connected, but my mac cant
Hi. You won't locate the scanner using Finder - the same as you can't find a printer.
Scanners normally only show up when the software that uses them calls for them. I think, however, the problem may be Crossover. Crossover is a brilliant application and it runs most windows apps without too much hassle - it does appear though that it has problems talking to USB connected devices.
I have spent an hour or so this even ing trying to connect an energy recording device via USB but the windows software can't seem to find it.
Jan 14, 2012 | Apple iMac Computers & Internet
Have an Epson Stylus CX5000 & A new iMac. OS X. I am unable to see what levels my ink supplies are with my Epson. With my old PC I could always see which ink was low or? What do I need to do to be...
If you are running the drivers included in the Mac OSX, you won't have levels. These are generic/running drivers only.
Hit this Epson site for current drivers.
Epson CX5000
Happy printing! :)
Aug 24, 2011 | Apple Computers & Internet
My Lacie hard drive worked perfectly for a period of time. I use it to make films and store all my files and final work on it. It now no longer appears on my desktop and I cannot access it in any way. ...
> it does NOT show on ... Macbook Pro running OS X 10.6.4
> it DOES mount up on older computers running older versions of OS X
> Lacie ... said there was no problem
So, the problem is "local" to ONE of your computers.
Be sure that your computer is connected to AC power, not running solely on its battery.
Try some other USB device in the USB port, to confirm that the USB port is working.
Nov 11, 2010 | LaCie Rugged All-Terrain (301017) Hard...
Will not mount on a Mac Book Pro 17"
try to connect lacie to windows base computer if it work, there a problem, with your mac book check if device manager recognize lacie drive if not check for the fire wire port.
Apr 10, 2010 | LaCie 1TB D2 HD Quadra FireWire 400 Hard...
I backed up my apple mac osx onto a lacie 320 gig
If its a pc running a different operating system then it wont know what the files are.
Jan 21, 2010 | LaCie Hard Disk 320GB with Hi-Speed USB2.0...
Will erasing my LaCie ext HD impact any files on my Mac Book?
It will only effect thoes stores on the external harddrive. You will have to check the contents of the LaCie drive and see if it has any files you typically access from your Mac Book. Other then that no it will not effect files stored on your Mac Books drive.
Jan 06, 2010 | LaCie (300728U) 250 GB Hard Drive
Cannot detect LaCie mini hub HD.
Try a new power supply. $19.99 at Lacie. It worked for me.
Dec 20, 2009 | LaCie Computers & Internet
Mounting an external hard drive onto my I Mac
Hi, I have just checked the LACIE website, So Google LACIE, click the second result [Lacie's own site] you will get a page up with a choice box, select Australia/go click the desktop HDD. click the 500Gb usb, this will give you a page with a support and a download link. click download, here you will find a manual and drivers. Goodluck mistyman
Sep 03, 2007 | Computers & Internet
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
313 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
