Problem with HT-X250R
I have a HT - X250R home cinema, it worked for approximately 20 mins then switched itself off and now when I try to switch it on it says PROTECTION on the display and immediately turns itself off.
  • Anonymous Feb 17, 2008
    my receiver turn off by itself right away when I turn it on
  • 4 Answers
It sounds to me like it is overloaded and won't come back on because it has overload protection. Check your connections and make sure the outlet or power strip it's plugged into isn't overloaded. I would disconnect everything from it and turn the volume all the way down and try to get it to come back on. Let me know what happens.
Posted on Feb 18, 2008
Sine updating my lg bh6220s it has started to switched itself after 5 min can anyone help please
I would have to guess that the internal power supply has one or more bad capacitors. Time to take into a technician for repairs.
Nov 11, 2014 | LG BH6220S 3D Home Cinema System LG
Home cinema shuts down after about two mins it says fan chk can u help
It means the fan(s) aren't doing their job. Clean out the dust bunnies and see if that helps.
Aug 23, 2011 | Samsung HT-X20 Home Cinema 600W Theater...
I am looking for a remote control for my H&B Home Cinema System HT 6500. The old one doesn't work anymore. I live in the Netherlands. I hope you can help me! Thomas
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
There are several available cheaper on eBay . Search "HT-6500 remote" and check the 'include description' box.
This is the cheapest Buy-It-Now listed, <$20 delivered...
http://cgi.ebay.com/Sony-RMT-D144A-DVPNC655-DVPNC655P-DVD-Remote-U240-/260677288281?pt=LH_DefaultDomain_0&hash=item3cb193c159
The original model is RM-PP411
May 21, 2011 | H&B HT-6500 DVD & MPEG-4 Player + 5.1...
Samsung dvd player switches itself onto protect!
hi,i can't connect my audio tv to cinema theater dvd
Apr 02, 2010 | Televison & Video
20" cinema display will not power up
check the cable connected to power supply, try to mve it up and down while trying to push the power switch, just a little updown, if it flickers the then you need to change your cable, see also if your cord had it's own fuse on the plug itself, have it check or replace
Nov 04, 2009 | Apple Cinema Display Flat Panel Monitor...
Audio
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 21, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Samsung HT-A100 Home Cinema system plays cd only with tv on!
You need to put away the remote for your TV and use only the remote for your HT system. Your HT remote should work on your TV by default. Your Samsung HT remote should have a TV button and a DVD/Receiver button (or HT button). When using only the TV, press the TV button and then use it for just the TV and when using the HT system, press the DVD/Receiver button and then you can use the HT system.
If for some reason your TV is not set on the Samsung HT remote by default, your HT users manual should have a list of codes that you can use to program your HT remote. Hope that helps you. Gary
Mar 18, 2009 | Samsung HT-A100T Theater System
Samsung HT-A100 Home Cinema system remote interferes with tv!
Some remotes have facility for changing frequency to avoid conflict. Check yours out for this feature.
Aug 29, 2017 | Samsung HT-A100T Theater System
System switches itself off
The HT-DB120 has an automatic shut down that should turn off after 20 min of idle mode, it seems yours is malfunctioning. try disconecting the DVD from power for a few minutes.
Jan 07, 2006 | Samsung HT-DB120 System
196 people viewed this question
 Grubhead
Grubhead
