Question about Acer Aspire 9500 Notebook
Numeric pad stop responding with numerals, off arrows and PgDn, PguUp OK
With the NumLock ON, the figures would not work. With NumLock OFF the keys are working fine.
Checked the empowering technology, checked WinXP, checked Registry (all settings OK) .
It just found it out one day. Is it possible that I triggered a hot key - working with insufficient light - not being aware of it?
Neither Acer forum has any answer, nor Microsoft
  • 50 Answers
Try this. press shift 5 times quickly. hit properties. check all areas and make sure none are on.
Posted on Feb 26, 2008
I have a gateway laptop running windows 8 and all of a sudden my number pad stopped working. I've searched and read till my eyes feel like they're going to fall out, help!!
Have you pressed/un-pressed the NUMLOCK key?
OR
You may have a stuck key somewhere on your 10-key numeric keyboard. Sometimes dirt (coffee, dust, soda) is blocking the contacts to the circuit board from the keyboard.
-GWOOD
Jul 18, 2014 | Gateway Computers & Internet
Tip
Lenovo G430/ G530 Function keys
<p><span>The following describes the features of each function key.</SPAN><br> <p><b><span>Fn + F1: </SPAN></B><span>Put your computer in sleep mode.</SPAN><br> <p><b><span>Fn + F2: </SPAN></B><span>Turn off/on the LCD screen back light.</SPAN><br> <p><b><span>Fn + F3: </SPAN></B><span>Shift to other connected display devices.</SPAN><br> <p><b><span>Fn + F4: </SPAN></B><span>Switch between wide screen and normal mode.</SPAN><br> <p><b><span>Fn + F5: </SPAN></B><span>Enable/disable the built-in wireless device feature.</SPAN><br> <p><b><span>Fn + F8: </SPAN></B><span>Enable/disable the touch pad.</SPAN><br> <p><b><span>Fn + F9: </SPAN></B><span>Play/pause Media Player playback.</SPAN><br> <p><b><span>Fn + F10: </SPAN></B><span>Stop Media Player playback.</SPAN><br> <p><b><span>Fn + F11: </SPAN></B><span>Skip to the previous track.</SPAN><br> <p><b><span>Fn + F12: </SPAN></B><span>Skip to the next track.</SPAN><br> <p><b><span>Fn + Insert/NmLk: </SPAN></B><span>Enable/disable the Numeric keypad.</SPAN><br> <p><b><span>Fn +Delete/ScrLk: </SPAN></B><span>Enable/disable Scroll Lock.</SPAN><br> <p><b><span>Fn + PrtSc/SysRq: </SPAN></B><span>System request.</SPAN><br> <p><b><span>Fn + up/down arrow: </SPAN></B><span>Increase/decrease display brightness.</SPAN><br> <p><b><span>Fn + right/left arrow: </SPAN></B><span>Increase/decrease computer volume.</SPAN><br> <p><b><span>Fn + PgUp: </SPAN></B><span>Move the cursor to the head of the line.</SPAN><br> <p><b><span>Fn + PgDn: </SPAN></B><span>Move the cursor to the end of the line.</SPAN>
on Jan 19, 2011 | Computers & Internet
How do I turn on numlock (to use an external usb number pad) on my Lenovo S405?
Did the external keyboard come with instructions to install drivers? Some keyboards will work without them, but others need additional drivers.
May 22, 2014 | Lenovo IdeaPad S405 14in LCD Notebook, AMD...
Numlock does not make numeric pad work
Hello Rich,
Please Check the Keyboard Setup in the Control Panel and make sure that you are using the right language "US or UK", if issue still presist please check the FN Key on the left handside down on the keyboard and make sure its not stuck.. and please give us more clarification about the issue and the Model you have.
KR,
Nasr
Apr 08, 2014 | HP Silver 17.3" ProBook 4730s A7K09UT...
What is nulock key?
I'm guessing you mean the "Numlock" key. It's located in the upper left corner of your numbers pad on the right of your keyboard and when it's on, it locks your numeric keypad into "Numbers Only" mode. Otherwise those keys will become disabled or become the alternate keys listed underneath the numbers (ie; up/down arrows, home, end, etc.). There is a setting in your BIOS (system setup at boot) to always have the Numlock key set to "ON" when your PC boots up.
Aug 12, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Arrow un and down key stopped working< numeric
try remove them and cleanig.but careful.
Nov 15, 2010 | Acer NSK8458AN Keyboard
I NEED A MANUAL TO SHOW HOW TO GET MULTIFUNCTION KEYS TO WORK. FOR EXAMPLE HOW DO I GET THE ALTERNATE USE OF THE "NUMERIC 6 "KEY ie THE" QUESTION MARK" FUNCTION
You must have a different keyboard selected other than the standard US keyboard My numeral 6 has ^ on it and the numeric keypad 6 has a right arrow. One generally uses the SHIFT key to access symbols that are written above the main alpha or numeric key. The numeric keypad on side of PC has a button labeled key marked NUMLOCK that is engaged to allow use of the numerals as a calculator or to also be inserted into text.
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Acer NSK8458AN Keyboard
Unlock numeric key pad on lap top
your laptop should have a blue FN key (Function) that will work in conjunction with other blue keys on teh keyboard. most laptops this is located in the lower left, next to the ctrl key. Look to the right top on your keyboard for a one labeled numlk. hold down teh left FN key and tap the right num lk key and you just turned off the numbers lock.
There is another option that is a little more intense - if interested let me know that laptop type you have.
Feb 04, 2010 | Microsoft Windows XP Professional
Latitude D600, how use FN key to have the numeric pad on
In the system setup (F2 at boot) look for Numlock settings, there should be an option to change the key combination for numlock
Mar 31, 2009 | Dell Latitude D600 Notebook
Acer Aspire 9500 Notebook Logo
140 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
