Question about HP Jornada 720 Pocket PC
Hp jornada 720 handheld pc
Thanks for trying to help but I am not able to sync my desktop pc with the hp jornada 720 handheld pc - it does not recognize it after downloading ActiveSync. Any solution???
  • 3 more comments
  • swiss1970 Feb 17, 2008
    My desktop is XP. Thanks for your offer to help. Yes, I have tried a couple of different usb ports. Any assistance would be much appreciated.
  • swiss1970 Feb 20, 2008
    If you remember what you wanted to ask - please let me know. I am really getting frustrated with what I thought would be a great little thing.
    Thanks.
  • swiss1970 Jun 01, 2008
    Maybe I'm just not a tech person.I did #1 but have a list but nothing that says "Ports (COM) plus sign.
    Active-Sync 4.5 is set up on my pc because I use it for my smartphone and it works with that. I tried again connecting the Jornada via USB - all the check boxes are checked and still no connection.
    I have been so frustrated - not being able to use it all this time. If there are any more possibilities - please please let me know and thanks for trying.
  • Ekse May 11, 2010
    I forgot what I was suposed to tell you, Il get back to you later when I remember.
  • Ekse May 11, 2010
    What system are you runing? vista? xp? 2000?
    have you tryed difrent usb ports or does the pda use a com port?
    Problem Solver:
  • 9 Answers
Are you connecting from dock to USB on computer, or serial to USB via a USB-serial adapter? UBS-serial adapters are notorious for not recognizing attached serial hardware. What kind of errors are the Jornada and the computer throwing? Can you give any specific error numbers?
If you are connecting using the serial cable to a serial port on your computer you need to make sure that the Jornada is trying to connect to the correct COM port (and that the computer is allowing connections through the correct COM port). Do this by:
1. Open Device Manager (R-Click on My Computer - Properties - Hardware - Device Manager)
2. Expand the "Ports (COM)" plus sign
3. Beside each COM port's name it will say (COM#) - the # tells you which port the COM is
4. Go into ActiveSync and open Connection Settings (in the File menu in ActiveSync 4.5 - the latest)
5. Make sure all the check boxes are checked and that the correct number COM port is selected in the drop down menu under "Allow connections to one of the following:"
6. Connect your Jornada via the serial cable, make sure the Jornada is on and connected to power cable (I have had more success with the power on - may or may not affect your problem)
7. Click the "Connect..." button in ActiveSync. The Jornada should be detected.
If your computer has an infrared port you could try that, I have had a lot of success with infrared connections with my Jornada. Also, try installing ActiveSync on another computer that has a serial port and try connecting the Jornada to that computer. It may be a problem with your computer.
An older version of ActiveSync should not make a difference. The facilities are the same, just slightly rearranged.
Let me know if you need any help! Good luck - I know how frustrating it is when it doesn't work how you want!
Posted on May 25, 2008
  • Jemma Pollari
    Jemma Pollari Jun 01, 2008
    Ok, it may just be that your computer doesn't have a COM port. You can tell by looking at the back of the computer tower; the COM port is shaped like a trapezoid and has nine small holes. What cables did the Jornada come with? Are you using the dock to connect the Jornada to the computer?
    Try getting ActiveSync to connect by going from Step 4 above and making sure the "Allow connections to one of the following:" dropbox is set to USB. Also try connecting to another computer to see if it is your computer at fault.
  • HP Master
  • 13,433 Answers
Try a older version of active sync. 3.0 or 3.1
heres 3.1
http://www.tucows.com/preview/32548
Posted on Feb 23, 2008
I connect using serial cable and activesync 3.8
Posted on May 09, 2008
Dear Sir, I have problem, with my Jornada 720. The touch screen can not function corectly. Please help me. Sukarno
try to visit if you want a purchase with amazon.com/Hewlett-Packard-F4356AABA-Hewlett-Packard-Jornada...
Feb 15, 2010 | HP Jornada 720 Pocket PC
HP Jornada 720 handheld communication with pc.
This error is a communication problem between your computer and the Jornada. Try these solutions:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpia2302&cc=us&lc=en&dlc=en&product=61677
Has anything changed that caused the problem, eg, installing new hardware, using a different cable to sync the Jornada?
Feb 21, 2008 | HP Jornada 720 Pocket PC
Pc does not redcognize handheld pc to sycronize
hi there
MIcrosoft Active Synk... you can download the this form https://www.microsoft.com/windowsmobile/downloads/eula_activesync45_1033.mspx?ProductID=76 with the help of this Active synk you can explore your PDA and upload photos from your computer.
i hope this would help you
wish you luck
Was this solution helpful? Show your Appreciation by rating it:
Feb 11, 2008 | HP Jornada 720 Pocket PC
Jornada 720 & Powerpoint
As you may know, you cannot edit the PowerPoint presentation, but you can use it with an external display to make it look pretty good. HP no longer makes the VGA-out option, but does have a suggestion for an alternate
Sep 14, 2005 | HP Jornada 720 Pocket PC
Jornada 565 - Downloading software - format
Hi, MIPS, SH3, and StrongARM are types of processors used in handheld PCs. Some software requires a specific processor to run. For instance, Microsoft Pocket PC 2002 requires a StrongARM processor. The Jornada 565 has a 206MHz StrongARM processor.
Sep 12, 2005 | HP Jornada 565 Pocket PC
Jornada 525 and Windows Media Player 9
Only a hint. Did you check the small print via the downloads for Pocket PC on the Microsoft web pages? If you download from the regular OS pages they don't mention that certain Pocket PC generations are not supported. I noticed this but only on Media Player downloads fom the pocket PC pages but it takes time to find this more detailed info. http://www.microsoft.com/windowsmobile/resources/downloads/pocketpc/defau lt.mspx
Sep 12, 2005 | HP Jornada 525 Pocket PC
Deleted Items Sync
did u empty ur deleted items folder in outlook if u did to stop it from syncing the e-mails open up active sync and go to tools options and then uncheck the e-mail
Can't find drivers...
should work with active sync, let me know if you have any problems with it.
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-synch.mspx
HP Jornada 720 Pocket PC Logo
626 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
