Question about Vacuums
Hoover problem the wheels on the bottom of my upright have come off , i have put them back on but i do not know where the metal clip should go and also the height ajuster for the wheels does not work, any ideas thanks kevin oates
    President:
  • 1,673 Answers
The metal clip is a leaf spring and there is a slot for it, You may have to pull the cover off, may have a broken piece for the adjuster. Would help to have model number.
Posted on Feb 17, 2008
When i removed the bottom panel to clean out the roller brush, the front wheels fell off. I can't figure out how to put them back on!
I( think Dirt devil wheels are held on by a little clip, kind of round ish. Check the other wheel and see if it has that kind of set up. Chris
Feb 09, 2011 | Dirt Devil Featherlight Bagless Upright...
Getting the height adjustment to work
is this a piece of **** dirt devil? if so, even when you get it back together the design is so flawed that it will keep breaking the belts, I've already gone through 3 in a week! see my other suggestions to remedy this.
Jul 11, 2009 | Dirt Devil Featherlite Bagless Vacuum...
My upright sebox4 will not stand . It keeps on dropping down.
This is usually a matter of lubrication (or lack thereof). If you look under the base of the machine, you will see that the "clip" as you call it is part of the metal axle on which the wheels are mounted. This axle is held in place by 3 metal tabs, each held by a single screw. About mid-way along, there's a spring coiled around the axle. That spring is what holds the "clip" (the bent part of the axle) against the tube that connects to the base of the bag compartment and holds it upright.
It's possible that your spring is broken, but often the problem is that the axle is sticking and the spring can't do its job properly. Try a small drop of oil under each of the 3 metal tabs. If that doesn't work, remove the 3 tabs completely, remove the axle (noting how the spring locates, so you can put it back correctly) and give everything a good clean. Then reassemble and try again.
May 14, 2009 | Sebo X4 Bagged Upright Vacuum
Hight adjustor does not work...
I think we got this figured out . . . . the height adjustment doesn't work when the vacuum is UPRIGHT, but when you disengage and lower the handle the plastic that is blocking the wheels from receding will rotate and then it can receive the plastic on the "top" of the wheel assembly. Try it and I think you will find that it works. I thought it was the wheels that were keeping the vacuum from working well, but that's not the case. Still don't know why it's gone to heck in 9 months.
Dec 29, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
L need a print out
my vacuum is broken the nozzle height adjustment to match the surface being cleaner , I do not know how can that part and the part # , because I want to order a part.Can you help me, please.
Thank you.
Dec 11, 2008 | Fantom Vacums FM760 Twister 500DX Bagless...
Replacing leaf spring Hoover wheels
If people are still having this problem, please post here and I will take a picture of the correct placement for the metal clip.
Apr 07, 2008 | Hoover U5227-930 Elite Upright Vacuum
Can I fix height adjusment?
all i no is on the bottom of unit there is 2 smaller wheels that control the height adj. see if that the prob.
Mar 01, 2008 | Hoover U6434-900 Bagged Upright Vacuum
Carpet Height Adjusment
In addition to the tab that contacts the bottom of the slider, there are 2 protusions on the adjustable wheel plate that move through holes in the housing, but only when the handle is tilted to begin vacuuming. The wheel plate has a spring that forces the tab against the slider. As the handle is moved to the upright position, the protusions move back through the holes, taking the tab away from the slider and the wheel plate locks in its highest position. Therefore, the position of the slider has no effect while the handle is upright and locked. Hope this helps.
Aug 19, 2007 | Hoover U5753-900 WindTunnel Bagless...
Vacuums Logo
128 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
